Old 10-05-2008   #101
Re: FP RED for evo 8 & 9
No. If you want to really push the limits with this turbo, you'll need to build the bottom end.
Old 10-06-2008   #102
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
still really impressive! ugh...i just want an Evo now. Someday.
ლ(ಠ益ಠლ)
Old 12-22-2008   #103
http://forums.evolutionm.net/6325638-post4.html
2005 Evo RS
TBE no cat
Comp 280/280 cams with stock gears
RC 1200cc
Walboro
AEM intake
AGP FMIC
GM 3 port with ecu-controlled boost
FPred (steveoSpec porting)
Titek tubular 02 housing
SteveoSpec ported exhaust manifold
Forge WGA
Upper/lower IC hardpipes
Wilson/Indy Cali-spec intake manifold
Stock long block
Stock ECU
Car weighs 2700lbs
Road racing tune
110oct
30psi across
2006 Evo SE
COBB 3" TBE
MilSpec 100 cell cat
Cosworth 280/272 M3 mivec cams
HKS exhaust adjustable gear
RC 1200cc
Walboro
ARC intake box
3.5" ETS FMIC
Forge WGA
Nisei Upper/lower IC hardpipes
Stock long block
Stock ECU
Road racing tune
100oct @ 27psi:
I am seriously torn, this or the BBK....I'm still leaning this way, I think. It edges out the BBK up top. Both need more E85 numbers....
Old 12-22-2008   #104
Hands-down BBK.
Old 12-22-2008   #105
BBK cuz it has the blingin blue compressor wheel. hahaha
Old 12-22-2008   #106
That looks like an awesome bolton turbo.
Old 02-05-2009   #107
I'm pretty sure I'm NOT getting one of these now, just because a 2 month wait time is typical. But man, they sure do make pretty sweet power:
E-85 Fuel
Buschur 2.0L Motor
Buschur Stage 3 Head
Cosworth M3 Cams
Driven Innovations Intake Manifold
Buschur Ported Exhaust Manifold
Buschur Race FMIC
Sparktech COP Ignition
FP Red Turbo
EPM 02 Dump
Shep Trans and Tcase
AEM Tuning By: Crispeed
Built by: AWD Motosports
http://www.youtube.com/watch?v=U71Hxf0lDnk&hd=1
Old 02-05-2009   #108
mike55112
mike55112's Avatar
Drives: 04 evo
I want a red so bad, seems like they keep making more and more power. If I didnt already have the 40R, I would have one of these now.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-05-2009   #109
Look at this car, very 'typical' car, not your standard balls-to-the-walls build.
2006 EVO9
BR 3" turbo back
custom i/c pipes
manual boost controller (not sure of brand, never seen one before)
Stock 2 liter
Stock head
GSC cams
FP red
SS 02 housing
Ported exhaust manifold
K&N filter kit
Walbro fuel pump
SMC alky kit
FIC 850 injectors
AEM EMS, 3.5 bar map sensor, air temp sensor
No wide band
ETS 3" FMIC
The car came out good, he was also running Valero "93" octane gasoline which is the worst fuel you can buy in the country.
The car was tuned at 29 psi of boost. It was in the mid 20's here today and I use no correction on the dyno.
438 whp and 372 ft lbs of torque
http://forums.evolutionm.net/evo-dyn...-meth-red.html
Old 02-05-2009   #110
If he used weather correction, then the numbers would be lower.
Old 06-06-2009   #111
Bump, there's at least 2 locals with this turbo now making ~425-430whp on shane's dyno w/ E85, they need to post up
Old 06-06-2009   #112
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Old 06-06-2009   #113
Good numbers!
Does the boost taper off like that with most of the aftermarket stock frame turbos?
Old 06-06-2009   #114
On high boost, yes. Some are better than others at pump gas levels. The green/red still taper a bit, but the BBK can be set to hold pretty flat (with ecu controlled boost). Either way, most don't taper nearly as bad as the stock turbo does. IX's are the worst.
Old 06-06-2009   #115
IX turbos aren't that bad with a proper setup. I set my MBC to peak at 25 and it tapers down to 21 at ~7500 RPM.
Old 06-06-2009   #116
TalonFiero
moonshine power
TalonFiero's Avatar
The IX head/Mivec breathes better than the VIIIs. A IX turbo doesn't taper nearly as bad on an VIII compared to a IX.
Old 06-06-2009   #117
Heh ya that's kinda what I meant, sorry
Old 06-09-2009   #118
dont mean to get too OT with this question, but what would be the DSM equivalent of this turbo.
Unless I can cut some major spool of this HX35 i am looking at 3052s or GT3076s to be HTA'd down the road.
How much boost is that on the dyno graphs?
Old 06-09-2009   #119
Maybe an FP RED. It's got the same name. An FP3052 is probably the closest though as far as power.
Old 06-09-2009   #120
The FP RED uses the same comp wheel as the HTA3076 (except reverse scroll). That's the closest thing out there.
I think I already said this earlier in this thread:
http://www.mitsustyle.com/forums/sho...6&postcount=28
