Go Back   MitsuStyle > Tech > The Good Stuff
Old 03-10-2009   #1
How Twin-Scroll Works
Found this on the net, thought I'd share:
A twin scroll turbine housing uses dual side by side passages into the housing. When coupled with a pulse converter manifold that separates exhaust pulses as many crank degrees in the firing order as possible, a twin scroll or divided housing works to reduce lag, decrease exhaust manifold backpressure on the top end, reduce the potential for reversion, and increase fuel economy
The twin scroll is based off the same theory a tri-Y 4-> 2 ->1 header uses: keep spent exhaust gases out of an adjacent cylinder drawing in fresh air. At high rpm on a turbo car, exhaust backpressure is usually significantly higher than atmospheric pressure, and often higher than intake manifold pressure as well. A divider between each of the two volutes allows the cylinders to expel the exhaust gases without it interfering with the fresh air for combustion. Since there are two openings, each a smaller overall volume than a single scroll design, the exhaust velocity of each pulse can be maintained. This also spins the impeller more easily because lag is a function of the scroll area.
A single turbine housing opening isn't as efficient in the larger turbo applications since cylinders on the exhaust stroke of the 4 stroke cycle contaminate the cylinders that are on overlap with exhaust gas, thus a conventional turbine housing is not as effective in using exhaust pulse energy to help spin the turbine up to speed since it does not exploit the energy contained in the pulses as well.
Old 03-11-2009   #2
Re: How Twin-Scroll Works
Thanks for that, much appreciated learned some more about divided housings.
Old 03-11-2009   #3
badinblack
badinblack's Avatar
Drives: 96 talon, 2.4L & 3582r
good information is always apreciated
badinblack is offline   Reply With Quote
Old 03-11-2009   #4
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Good bit of information. Thanks for posting.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 03-12-2009   #5
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Interesting, thanks for posting.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
