Old 03-16-2009   #41
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Need a pic of the FIAV blocked off
I have the BISS screw way out right now to keep it at this idle. I even adjusted the idle switch to keep the throttle plate open a little more. Plus it's an auto so when I put it in gear the idle goes down to like 650 700. So I'll probably just leave it for now, it's good enough for me.
-1990 Mitsubishi Cyborg 4WD-
Old 03-16-2009   #42
Dundars
Drives: 1g DSM
Why go through all that work to not get the idle perfect with the simple solution Halon gave you?
Dundars is offline   Reply With Quote
Old 03-16-2009   #43
Different strokes for different folks I suppose. If it's good enough for you, then great! Otherwise, it's really easy to do, and there is a VFAQ on it.
Old 03-16-2009   #44
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I know I've done it before. If I get the idle set at 750 the car will go down to 500 rpm's or so when I put it in gear. It's no big deal, It's just my daily. In gear the idle is where I want it. Some more good news.. My vacuum used to me at 11 at idle and now it's at 15 or so. Yes I know it's low but whatever.. haha
