Old 04-29-2009   #261
95talonracer
95talonracer's Avatar
Re: My Talon
My 6 puck sprung with a 2900 held up real well tonight at 27psi on my new setup and pulled extremely hard so I think you should be good with your new disk.
Amsoil Dealer
Old 04-29-2009   #262
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: My Talon
Good results for the boost and stock intake manifold on a 2.0L. Hey what brand dyno was this on?
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
Old 04-29-2009   #263
Re: My Talon
Dyno dynamics, the heartbreaker.
Old 04-29-2009   #264
Re: My Talon
I can drive around right now and haul ass, my clutch doesn't slip. But when I did two launches/pulls immediately right after each other, it slipped the 2nd time.
Old 04-29-2009   #265
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
yep. what, is it, 18% lower than a DJ? 400hp / .82 = about 490hp on a dynojet.
Matt
Old 04-29-2009   #266
Re: My Talon
I don't think it's that high?
Old 04-29-2009   #267
Re: My Talon
DynoJet reading 18% higher than DD != DD reads 82% of DynoJet.
400 * 1.18 = 472
400 * 1.16 = 464
(it seems a lot see between 16-18%, so between 460-470)
Good luck with the new clutch setup.
Old 04-29-2009   #268
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
About 18% lower on DD puts you at 490hp. Click. 275.8hp on DJ. 224.7hp on a DD. And, 224.7 / .82 = 274hp. DJ read 275.8hp.
18% less than 100% = 82%
82% X dyno jet numbers = DD number
DDnumbers / .82 = dyno jet numbers
400hp / .82 = 490hp
Regardless, all the numbers are good. No biggie. 470whp is nice.
Matt
Old 04-29-2009   #269
Re: My Talon
Enough math, where's the damn dyno sheet?
Old 04-29-2009   #270
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
1 page back. That's where the 400hp number came from . 402hp, right?
Matt
Old 04-29-2009   #271
Re: My Talon
Don't be ghey, that's shane demonstrating his MS Paint skylz
Old 04-29-2009   #272
Re: My Talon
Ah, I see you took the nasioc stats of DJ reads 21-22% higher than DD. Just personal experience I guess, I don't think we've seen quite that high between our two dynos here in Minneapolis. But another good reference.
+1 for a real dyno sheet!
Old 04-29-2009   #273
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
It looked funny. Why I asked which brand dyno . . .
Matt
Old 04-29-2009   #274
Re: My Talon
A DJ in SAE correction in AWD mode seems to around 15%-17% higher than our Dyno Dynamics. It's around 17%-20% for a DJ in STD mode depending on weather conditions. I am only talking AWD cars though. And it still depends on weather, strapping, how each dyno is run, etc.
There is a big difference in the math between saying X reads 18% higher than Y compared to saying Y is 18% lower than X. For example 550cc injectors are 22% bigger than 450cc, but 450cc are 18% smaller than 550cc.
Old 04-29-2009   #275
Re: My Talon
I was misinformed about the AWD vs. 2WD thing previously, but I think that's because I always talked to you crazy evo and dsm people!
Old 04-29-2009   #276
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
Hence, my link to the nasioc dyno results showing that a DD reads about 18% lower thana DJ. Not that a DJ reads 18% higher .
If a typical DJ reads 18% higher than your DD, then you're DD could read a little higher than other typical DDs. No big deal. Just an observation. All dydnos even of the same brand will read different by +/-2 to 3%
Matt
Old 04-29-2009   #277
Re: My Talon
I wouldn't try to compare a Subaru as directly though with the way that those ECUs control timing, they aren't the most consistant cars from one run to the next.
The numbers from a DD will depend on inertia settings and load settings and the numbers from a DJ will depend on the correction used SAE, STD, DIN, Uncorrected, etc and the smoothing factor used.
Old 04-29-2009   #278
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
Ah! I know just the silhouette of the scoobie platform. Makes sense. We can all agree the difference is over 17% however you want to do it. not bad. . . If the results are REAL . I'd like to see that dyno sheet too. Very interested in the curve shape.
Matt
Old 04-29-2009   #279
Re: My Talon
Well I emailed that guy above (Ecoli) to get my graph but no response haha. I GUESS I'll call DB just so I can get it emailed to me.
Old 04-30-2009   #280
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
Hey, just take a pic of your paper copies and uplaod the pics to photobucket or something. Easy enough.
Matt
