Old 06-02-2009   #21
Re: Over revving issue
If you are pulling the trans and the head, you might just want to pull the motor/trans together and pull it apart. Put the engine on a stand to work on it, and put the trans aside and inspect it.
Old 06-02-2009   #22
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Brandon, flywheel/clutches love to come apart or loosen up on over revs. I speak from experience and I popped my CAS plug off too!
My flywheel bolts cam loose on the over-rev. Clutch acted funny and the flywheel vibrated so badly on the over-rev that the the crank to flywheel mating surface was pitted with molten metal.
Old 06-02-2009   #23
The bearings will be replaced if they look like the need it. If they look fine, then no.
We will see more once I get things taken apart.
Jim, with your issue, what all had to be done then because of that pitting? Was the motor trash?
Old 06-02-2009   #24
No, his motor is still running! I remember jim taking the tranny off to tighten the flywheel bolts and getting a ride in it shortly thereafter!
Old 06-02-2009   #25
I've had flywheel bolt issues before. Shit was so gay.
I went crazy and used longer 3sgte ARP bolts along with nordlocks and loctite!
Old 06-02-2009   #26
Same thing happened to a S2k buddy of mine after he over-revved. His "engine" was making all sorts of noise so he figured he trashed the head and bent some valves, he had it trailered to the dealer and all they found were some loose flywheel bolts. They snugged them back up and the car was perfect again.
Old 06-02-2009   #27
TalonFiero
moonshine power
TalonFiero's Avatar
Brandon, I didn't have a ton of metal friction weld, just a few smaller globs. Most of the the metal was transferred to the flywheel from the crank so I bought another flywheel. I had to clean up the crank by hand just a little, I have seen photos of much worse from others who have had their flywheel come loose on an over-rev. I have put another 17K miles on the engine with no issues.
Also my over rev wasn't too bad I believe it was just under 9,500rpms or right around there. It was just the sudden change in rpm that shook the flywheel loose. I have the 2.4 so I don't rev it too high to begin with.
Old 06-02-2009   #28
SnoEclipse
Drives: 07 Eclipse GT
OTOH, if you're this far into a teardown pull everything apart, get the cyl walls honed, get a flat edge on the cyl head and block, etc, etc.
Pull the tranny apart, check the levers and synchros, etc.
Polish/port the intake/exhaust runs, etc.
Put together with a torque wrench.
07 Eclipse GTV6 Deep Red Pearl, cosmetic and weight reduction mods in progress, suspension and brakes come in Spring 2009. I want an LSD for the 5 speed auto!!
SnoEclipse is offline   Reply With Quote
Old 06-02-2009   #29
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Why would he want to hone the cylinders on his car right now?
Old 06-02-2009   #30
Hone the cylinder walls. Trust me, I'm a doctor.
Old 06-02-2009   #31
If you're gonna be ripping it all apart, you might as well just pull the motor and tranny all at once. It'll be easier in the long run.
Old 06-02-2009   #32
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
+1
They slide in/out very easy as one unit, even on 3KGT's.
If you need to borrow a engine stand or hoist, or need some help let me know. I live pretty close.
Old 06-02-2009   #33
I'm not going to re-hone/re-ring the motor. I don't see the point in that.
Update on everything so far:
- Got the head off. Everything on the head appears to be pretty good. Nothing jumped out as being obviouslly bad. My uncle owns an engine/machine shop in Minneapolis, where I will be bringing it for him to check out.
- Headgasket is blown in 3 spots. To all those telling me I was wasting my time removing the head, this is why the head was removed. I suspected head gasket issues for the past few months.
- I mentioned earlier that from under the car the pass axle looked goofy. Well today I got the wheel off and yeah that pass side axle is fubar'd. I didn't look at that close as today I was focusing on the head, not the tranny. Tomorrow I should get a better look at it though. All I can say right now is that I'm definately going to need a new pass side axle.
That's it for now. I'll post up pics once I get them uploaded.
Old 06-02-2009   #34
Thanks for the offers everyone. But I'm keeping the block in the car. I have a cherry picker, but no engine stand. And I really don't have that much room in the garage, so the motor is going to stay in the car.
Brian, I don't have your number. You should PM it to me sometime and I can give you a ring if I am in a bind and maybe need a hand!
Old 06-02-2009   #35
Carnage pics...
ID:	8783   Click image for larger version
ID:	8784   Click image for larger version
ID:	8787   Click image for larger version
ID:	8788   Click image for larger version
Old 06-03-2009   #36
Nice kill on that HG. Any determination as to why it blew?
Old 06-03-2009   #37
Did the axle snap off in the tranny? It kinda looks like it in the pic. That might be a bit tough to get out...
Old 06-03-2009   #38
No determination as to why it blew, other than I'm thinking I was lifting the head, and those areas are so close together that they probably just made a little path to eachother. Hopefully the new L19's can prevent this.
As fot the axle, yeah that is kinda what it looks like. I didn't spend much time looking at it as I was focused on removing the head. I'll find out more today though. Hoping to have the tranny off tonight.
Old 06-03-2009   #39
Nice carnage. Hope it goes back together smoothly!
Old 06-03-2009   #40
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Sweet, Now I'm not the only one who has broken an axle off in the tranny!
Once you get the diff pin out it will tap out easy with a drass drift punch.
