Old 07-12-2009   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Having overheating problems
I'm still overheating!!
I put spacers on the hood
Removed the thermastat " MAP recomended it "
Bought a mishimoto radiator and cap
running mostly water and some coolent
have 2 mishimoto 12 inch slim fans running at all times
REMOVED A/C
Put a heat sheild on my manifold and turbo
I had a 180 thermastat in there before I removed it, All of this has been happening since I got it back from map and I dont know what else i could do.... I think it could be my water pump because I will let the car run for 20 min at idle with a funnel and a radiator cap with a hole cut into it to suck in when needed and nothing, but when I turn the car off it bubbles and sucks some in.... the I do it again but at the end it doesnt suck any in... next step I put the cap on and move my car like 25ft then look again and my hose's are callapsed!! what could this be?
Any help would be greatly appreciated
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-12-2009   #2
Re: Having overheating problems
Have you done a pressure test on the coolant system? Is coolant disappearing?
When you bleed the system with a funnel, so you see it flowing at all?
You shouldn't run without a thermostat or restrictor plate, that can cause all kind of problems and tuning annoyances including even worse overheating in some cases. Race cars that don't run a thermostat will still run a restrictor plate to allow the cooling system to be able to build pressure easier(water boils at high temps at high pressure) and to keep from causing any "short circuits" in the cooling system.
Old 07-12-2009   #3
GsXtUrBo98
GsXtUrBo98's Avatar
No pressure test yet want to do that today..
I do not see it flowing but there is a big funnel with fluid in it on my car..
I had a 180 thermistat in there before I took it out and it made no difference but people have been telling me to put it back in, so I may do that today aswell.
98 GSX (built)
03 BBY EVO dd
Old 07-12-2009   #4
GsXtUrBo98
GsXtUrBo98's Avatar
Should both of the hoses be pressureised? Top and bottom?
98 GSX (built)
03 BBY EVO dd
Old 07-12-2009   #5
Yes. Sounds like you've tried a lot of band-aids to cover a serious problem.
Old 07-12-2009   #6
GsXtUrBo98
GsXtUrBo98's Avatar
Im till scratching my head about this... I dont have a pressure tester and would need a new gasket to put in the thermastat its a 180 degree one that map put in before and maybe drill a hole into it.
98 GSX (built)
03 BBY EVO dd
Old 07-12-2009   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Also, Is it legal to drive without a hood on your car?
98 GSX (built)
03 BBY EVO dd
Old 07-12-2009   #8
95talonracer
95talonracer's Avatar
I have in my 2.3 the same radiator as you, 190 thermostat, a 10" and 12" slim fans wired stock as pushers, no AC, and I never go over half way which would be under 200. Sounds like a water pump possibly.
Amsoil Dealer
Old 07-12-2009   #9
GsXtUrBo98
GsXtUrBo98's Avatar
Well I'm glad that someone else thinks the same thing that I do! I was just talking to my naighbor and he said that maybe the water pump is flowing the wrong way???? which could callapse the hoses, but I'm not sure that I believe him about that because the 1g's and 2g's both flow the same direction dont they?
98 GSX (built)
03 BBY EVO dd
Old 07-13-2009   #10
^ What? That doesn't make any sense to me.
I'd say replace the water pump if you can't see any coolant flowing.
Old 07-13-2009   #11
Water pump can't go the wrong way. If the blades on those are stamped steel, I've seen pumps with a nub where the fins rusted away. check the water pump.
Old 07-13-2009   #12
GsXtUrBo98
GsXtUrBo98's Avatar
the only thing is that the water pump is brand new!?!?!?
98 GSX (built)
03 BBY EVO dd
Old 07-13-2009   #13
blageo23
AWD4G64
blageo23's Avatar
The pump cant go the wrong way, unless somehow your engine is running the wrong way . What makes you think that its overheating? Just the gauge?
1998 Spyder AWD
567hp
490tq
Old 07-13-2009   #14
95talonracer
So can you see coolant flowing with the engine running and the cap off or not really? Check the actual coolant temp in a log with Link.
Amsoil Dealer
Old 07-13-2009   #15
mike55112
mike55112's Avatar
Drives: 04 evo
I have said it was the water pump since day one. I hope im wrong chris but I think map should replace it for free since you have just been buying tons of shit from them to try and fix your over heating problem.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 07-13-2009   #16
GsXtUrBo98
GsXtUrBo98's Avatar
Well I just got off the phone with Alex from MAP and I'm dropping off the car tomorrow for them to look further into the hassle of overheating!
98 GSX (built)
03 BBY EVO dd
Old 07-13-2009   #17
GsXtUrBo98
GsXtUrBo98's Avatar
I have ECMlink v3 and its set up so that when it gets to a certian temp then the check engine light goes on and when that happens the gauge is about 3/4 of the way to hot!
I cant really tell if its flowing or not because when I turn the car on the coolent level goes up and sits level with the mouth and just kinda vibrates... if that makes sense? I'm thinking that there is some sort of restriction that is causing it to overheat.
98 GSX (built)
03 BBY EVO dd
Old 07-13-2009   #18
GsXtUrBo98
GsXtUrBo98's Avatar
And spent alot of money!
I got the mishimoto radiator
F.A.L fan shroud
Then the fan shroud wouldnt fit so I ordered a MAP 02 housing and got that coated which was over 300 dollars
F.A.L fans still wouldn't fit so I bought 2 12" mishimoto slim fans
Got them to both run at the same time, and at all times and alot of money on coolent taking the radiator in and out so many times its just F-in rediculous!
98 GSX (built)
03 BBY EVO dd
Old 07-13-2009   #19
mike55112
mike55112's Avatar
Drives: 04 evo
Hope everything works out for you and doesnt cost you any more money. You have spent enough
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 07-13-2009   #20
http://www.mitsustyle.com/forums/sho...ht=running+hot
That is my thread with all the crap I had tried on my car. Might be worth scouring through quickly.
