Old 07-23-2009   #1
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Stroker? 2.0? WTH?
I'm really really confused, i should of took a pic of the bottom end when i had the oil pan off, but, it looks like eagle rods and je pistons bored .020 over or 85mm i think it's what it said, with arp rod bolts. The block has oil squirters also. Anyway, looking at my cam gears, it has a oem 4g64 cam on it? the block itself says 4g63 unless i'm misreading it.
Old 07-23-2009   #2
95talonracer
95talonracer's Avatar
Re: Stroker? 2.0? WTH?
how does it have oem 4g64 cam gears
Amsoil Dealer
Old 07-23-2009   #3
How about some pics and we'll help you decipher
Old 07-23-2009   #4
It could be a 2.3l stroker.
Old 07-23-2009   #5
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
It's possible. The 4g64 cam gears are the same except the pin is drilled in a slightly different spot.
Old 07-23-2009   #6
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Maybe they are just 95-96 cam gears, sometimes people just guess that they are 4g64...sometimes. Do they look like this:
Mwolf83 is offline   Reply With Quote
Old 07-23-2009   #7
tehehodi
Braaaaaaaap!
tehehodi's Avatar
^^^they look like that, exactly! is it ok that it's on a 1g head? my whole motor is 1g.
Old 07-24-2009   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
I don't see why that wouldn't be fine. Are you 100% sure that you have a 1g head?
-1990 Mitsubishi Cyborg 4WD-
Old 07-24-2009   #9
tehehodi
Braaaaaaaap!
tehehodi's Avatar
1g head because it has the bigger intake ports. I would take pics, but my blackberry is dead, and i can't charge it, and a camera i got, the cord doesn't work. Also the CAS i beleive is a green top, i'm not sure, its got some surface rust on it
Old 07-24-2009   #10
Do the cam gears say D20 or D24 on them?
Old 07-27-2009   #11
tehehodi
Braaaaaaaap!
tehehodi's Avatar
d20
Old 07-27-2009   #12
Those are 2.0l cam gears then.
Old 07-27-2009   #13
tehehodi
Braaaaaaaap!
tehehodi's Avatar
thanks!
