Old 07-27-2009   #821
Re: the evo 3 swap parts are coming
Got the 2nd tial on the way for the manifold and will be running 1600cc and e-85 now the new chip for the car showed up the other day. Just need a few more thingsfor the new set up. Hope I can get it all done by the cook out
Old 07-30-2009   #822
worked on the car the last 2 days
got the tranny filled back up with redline heavy weight shock. and the hella horns put on yesterday.
today dad and I got the manifold all fixed up. made a new coil bracket so it will bolt were the a/c bracket was. welded in the 10an bung to the extra oil pan I had. got the dnp manifold and the pte5031e off the car after we started the car up with no down pipe to check out the clutch and it is 100 times better than the QM was.
bye to the dnp,pte5031e
pipes and flex for the new down pipe
10an bung (on a 100 year lease )
the top mount
the huge housing that is not getting used 1.34
does clear with the hood on with the 1.34 housing with a few inch's
10an drain tube. it is a 4000psi oil,hydro hose with crimp on 10an ends.
Old 07-30-2009   #823
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Wow! This is going to be sick.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 07-31-2009   #824
Hmm, that hose and the fittings look very familiar... Why is this? haha
Old 07-31-2009   #825
I have no idea why it looks familiar
Old 08-06-2009   #826
dad and I worked on the car today. craig and kevin also came by for some beer's
got the griffin scirroco radiator fitted. just have to cut off the water neck and have it welded shut and cut the upper hose fitting and have it come out at a 45 so it will clear the turbo better. Also cut out the full top radiator surport to make room for the radiator so we made a nice flat bar to bolt in and has a 90 piece of steel in on the bottom to hold the top of the radiator.
we put in a 2g upper motor mount that we had to mod it to fit with the polly mount
got both of the tial 38's on the manifold
also picked up a set of hood pins from craig. need to use them now since the car will no longer have a hood latch on it because the radiator is now sitting there.
Old 08-06-2009   #827
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
that evo is gonna be sick Mark. lookin sweeet man.
ლ(ಠ益ಠლ)
Old 08-12-2009   #828
got the radiator and water neck back from John(Pushit2.0) to day. big thanks to him for welding them up. Had the upper hose pipe welded at a 45 and the radiator cap cut off and welded shut. On the water neck it is the evo III bottom and a 1g upper and it is also at a diffrent angle so it will clear the turbo when it get's back I hope soon so I can get the car done.
water neck
also put in the other evo III water pipe I had since I dont need to run the dented pipe any more. Also show's the new angle for the water neck
Dad worked on the radiator. cut some holes in the mounting tabs to install the oem rubber mounts for the radiator and welded in a set of bolts to hold the bottom of the radiator.
the new upper radiator support. We made it a bolt in so the radiator can be taken out with out taking the top mount off the car. It also holds the front and back of the top of the radiator so it does not move at all.
Old 08-13-2009   #829
A lot of work! Looks fun! So are you gonna just use a chip for this car?
Old 08-13-2009   #830
just the chip for now with the safc2. that is all that has been out there for the car. unless I want to run aem or power fc.
But dsmlink just got done with the firm ware for the evo I-III ecu so I will be switching it over soon
Old 08-13-2009   #831
Arg I want to see paint on this thing!
Old 08-13-2009   #832
dad and I worked on it a little today after redoing the full exhaust on the mirage hatch
got the lower radiator hose made and put on
cut off the safety latch and main latch off the hood since it hit the new radiator
in stalled the hood pins on the car
also picked up a set of tial 38mm flanges with some pipe on them already to make the dump tubes
Old 08-13-2009   #833
Constant_Project21
Constant_Project21's Avatar
Drives: E36
This thing is gonna be mean! What's your goal for it?
Old 08-13-2009   #834
500+ when I build the 2.4 that I got for free a few years ago
Old 08-14-2009   #835
Jebus, with that setup you should be hitting 500HP at about 4k RPMs haha
Old 08-19-2009   #836
got the rest of the piping today from craig. so I got the 2 dump tubes made up and on the tial 38's
got the hot side for the turbo today so the down pipe could be started. Kevin came over and helped out huge with fabing up the down pipe. it is all tacked right now I just have to weld it all together in the morring. Put the 2 bung in it for the o2 and wide band and wrap it.
Old 08-19-2009   #837
Forced Fed
Drives: FS-T
You're a master of fabrication sir! Can't wait til this is painted!!!!!!
Old 08-19-2009   #838
4seasons69
4seasons69's Avatar
agreed! looks really good
Old 08-19-2009   #839
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
wow! keep up the good work :-D
Old 08-19-2009   #840
Constant_Project21
Drives: E36
I don't see why everyone is so excited for paint..haha, either way it's a cool ass car.
