Old 09-16-2009   #21
2bar1g
Drives: .
Re: TDO6 Frank 4 60 trim w/o2 housing and WG
Yep mitsu housing. Stock lines bolt up; may have to bend the water feed. There isn't much info on the frank turbos, but it's said the comp wheel can do up to 50lbs per min. It's similar to the fp green, a little slower spool because the frank turbos are outdated. Obviously spool time varies from setup to setup but the frank 4 would be around 4000-4200. These were the models that came out before the green and red.
2bar1g is offline   Reply With Quote
Old 09-19-2009   #22
2bar1g
Drives: .
Old 09-23-2009   #23
2bar1g
Drives: .
Bump, still have this
Old 10-03-2009   #24
2bar1g
Drives: .
Bump, make a reasonable offer
Old 10-13-2009   #25
2bar1g
Drives: .
Bump, bump the thread, bump it up, get this thread bumpin.
I'm not looking for any trades.
Old 10-13-2009   #26
2bar1g
Drives: .
I see I deleted all the info on the first post.
Tiny bit of side to side shaft play, but will go away once oiled.
Has a clipped tdo6 turbine wheel
Garrett e60 compressor wheel
3" inlet
40mm hks wg w/15lb spring
3" o2 housing
http://www.turbochargers.com/tech/
Rated at 750cfm, fp green is at 730.
Old 10-13-2009   #27
matt j
im interested, let me see what all i can sell to get some cash would you take any trades?
matt j is offline   Reply With Quote
Old 10-14-2009   #28
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
-1990 Mitsubishi Cyborg 4WD-
Old 10-14-2009   #29
2bar1g
Drives: .
No trades. I don't own a dsm and don't plan on getting back into them for a while. I'd say this a pretty good deal for someone, considering I'm losing a few hundred off it.
Old 10-14-2009   #30
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I still really want this.. I'm thinking of putting my new rebuilt small 16g up for sale but I'm not sure. Would you do a payment plan? haha
Old 10-14-2009   #31
2bar1g
Drives: .
It's pending sale
