Old 01-28-2010   #241
Re: Whats new with Teh Gheyrod...
The only NGK copper plugs available for the IX are a heat range hotter and are from a Yamaha outboard. The iridiums seem to work very well in the Evos (as my stock ones with 46k miles prove). I just hope these Densos are as reliable and long-lasting as the stock NGK's.
Old 02-14-2010   #242
A little extra carbon fiber to go along with the COP plate:
Old 02-14-2010   #243
Woowoo! CF Gheyrod! Lookin good man.
Old 02-24-2010   #244
I got a new harness with black braided fiberglass wire sheath instead of the gray silicone sheath I also had the harnesses extended to get the plugs off the top of the valve cover.
Old 02-24-2010   #245
LingLing
AznKraut
LingLing's Avatar
Looks purty! I love the look of a leak free engine bay!
Old 02-24-2010   #246
I don't see the difference from before...
Old 02-25-2010   #247
Its tough to tell in the pictures but its very noticeable in person. The silicone sheaths were the one thing I thought looked cheap about these kits, but this braided sheath looks much nicer (plus its black rather than gray).
Old 03-16-2010   #248
Well, Teh Gheyrod has been a bit of a whore these past two week but I think we're past the pain and it once again loves me.
Two Fridays again it was spewing coolant out of the rubber turbo coolant feed hose which luckily O'Reilly had a replacement hose that fit nearly perfectly for $10. Its a small 3/8" molded 90-degree bend with a few inch long legs.
This past Friday coming home from work doing about 80mph down the tollway I was slowing down for traffic and lost a lot of pressure in my brake pedal. I got the car slowed with some pumping of the pedal and down-shifting, but I left most my ATE Super Blue brake fluid all over the road. My front driver side stainless brake line had been lightly rubbing on the shock body and finally wore through and sprung a leak. I was able to slowly get the car home then Saturday I replaced the line with a spare stainless line I luckily had laying around. My friend brought me some Amsoil DOT4 brake fluid since he is a dealer and none of the shops that stock ATE Super Blue are open on the weekends. Amsoil DOT4 is actually slightly better fluid, but at 3x the price.
Old 03-16-2010   #249
Wow, that's pretty scary about the brake line. Luckily you were able to get it slowed down.
Old 03-16-2010   #250
When installing yours just be really careful with the fitment! The bracket in the center of the line is movable so make sure its located exactly where it needs to be in order for the line to not rub on anything. I learned the hard way (luckily not too harsh of a lesson) so hopefully my mistake can remind people to be careful and at least double-check their aftermarket brake lines.
Old 03-16-2010   #251
Most people would have freaked out and slamed harder on the brakes and crashed. Good thing you had time to slow down.
Old 03-16-2010   #252
Would have been forced to slap a Toyota badge on it and blame the electronics!
Old 03-16-2010   #253
Lmfao
Old 03-16-2010   #254
Per request here is my entire mod list:
Power: Buschur turboback exhaust (straight 3” w/testpipe), Buschur ported/coated exhaust manifold, Buschur coated stainless steel o2 housing, self-ported turbine housing, Buschur intake pipe, Perrin air filter, Perrin FMIC, Nisei IC piping kit, Walbro 255HP fuel pump, DB Performance MBC, FIC 850cc fuel injectors, FP4R MIVEC camshafts, 65mm Mil.Spec throttle body, MAP Rev.3 coated intake manifold w/Magnus heat-barrier gasket and STM EGR block-off plate, Kracka vents (MAP Crankcase Vents) w/ eBay catch-can setup, and all emission systems removed.
Suspension: Swift Sport lowering springs, Whiteline 24mm adjustable rear anti-sway bar, MR BBS wheels w/ Sumitomo HTR Z III 245/40-17 tires, “RobiSpec” alignment by Jeff the Alignment Guy, RS trunk bar, eBay rear strut tower brace, and Binary seat lowering brackets.
Drivetrain: Competition Stage 3 Kevlar clutch disc, Exedy HD pressure plate w/ Mitsu TOB, Competition 10.8 lb. lightweight flywheel, Rosey billet clutch fork stopper, Energy rear differential bushings, Beatrush aluminum driveshaft bushings, Blox billet/poly front motor mount, Fidanza short-shifter w/ aluminum base bushings, Skunk2 counterweight shift knob, Speed-Source brass underhood shifter bushings, and Redline transmission fluid cocktail.
Brakes: RacingBrake ET500 pads w/Girodisc shims, Technafit SS lines, and ATE Super Blue fluid.
Electronics: SpoolinUp COP kit with Denso IKH24 spark plugs, JDM 3-bar MAP sensor, Innovative LC-1 wideband, GM AIT sensor, Nisei mini-battery tray with AMS mini-battery, Defi boost/EGT/oil pressure gauges, Apexi turbo-timer, Tephra v5.10 ECU mods w/tune by Shane at DB Performance, Kenwood CD stereo deck w/ iPod adapter, and hard-wired Passport 8500 X50 radar detector.
Appearance: Mynes hood dampers, carbon fiber COP mounting plate, carbon fiber radiator cooling plate, carbon fiber vortex generator, carbon fiber bumper exhaust heatshield, Primo Performance CAS heatshield, Primo powedercoated brackets, Perrin 2” antenna, partial wire tuck, and 35% tint by Street Scenes Tint.
Old 04-01-2010   #255
FS thread: http://mitsustyle.com/forums/showthr...092#post332092
Old 04-01-2010   #256
LingLing
AznKraut
LingLing's Avatar
:O Bummer she has to go. Good luck with everything though!
Old 04-02-2010   #257
Earlier this week I built my speed density patched Tephra v5.10 ROM and today I made the switch. I've spent the majority of my day driving around logging and tweaking the SD tables and values. It's not even close to perfect yet, but its a whole lot closer now that it was at first. I'm still working on the part-throttle cruising aspect and once that is dialed-in I'll work my way up to boost and WOT conditions.
My initials impressions do show the car to have smoother light-throttle drivability below 2,000 RPM.
Thank you to Scheides for giving me pointers along the way!
Old 04-07-2010   #258
After spending 6 days doing tons of logging and tuning...
SD ROM v27 is a success! I was just out making multiple clean WOT pulls and the car feels great! Time to order a Perrin air filter that will fit directly to my intake pipe.
Also, a special big thanks to Scheides for always being willing to look over logs and giving me pointers along the way since he's already converted 3 cars!
Old 04-22-2010   #259
I got some new rubber last night. One of my tires picked up a big bolt very close to the sidewall so it was unrepairable. Being how AWD needs all matching tires I opted to just buy a complete new set. Luckily I found a store with a set of 245/40-17 Sumitomo HTR Z III's in stock that was willing to negotiate on price to bring pricing closer to TireRack's ($103 on TireRack, got these for $115 but didn't have to pay shipping).
Old 04-22-2010   #260
Nice! I thought you were saying you wanted to try a new tire the other day?
