Old 02-14-2010   #41
Re: The Voy project - ridin' durtay
Nice, boards looked good last night and so did the tails.
Old 02-16-2010   #42
I think I'm going to take your advice and keep the orange pieces in, but just tint them slightly. I don't think I'll tint them black, but kind of like my taillights so you can still see a little bit of orange, just a deep dark orange. I might do them just a hair lighter than the tails though. And I may do the orange turn signals on the side mirrors the same also.
Anyone got a small amount of nightshade sitting around or anything like that? It'll have to be just a quick spray job because I'm not going to pay a bunch to have these done professionally. I think nightshade will do the trick for these little pieces. I hate to buy a whole can just for this though. Anyone have any they'd let me use, or buy a half empty can from?
Old 02-16-2010   #43
I got a couple cans, I'll be in Isanti pretty much all day today.
Old 02-16-2010   #44
Hey thanks for the offer, but that's kind of a hike isn't it? Probably looking at atleast a 1 hour round trip I'm thinking to get there. For the amount of gas this thing sucks, I may just buy a small can if I can find one.
But, update time!!!
Got the projectors in the mail today. I was really hoping they were going to just fit right in without modification as that's what these projectors are meant to do. Problem is the size of the projector, and the size/shape of my OEM reflector bowl. They don't perfectly work together so some modification was required. I decided I wanted to try and keep the housing as unmodified as possible. I did have to grind away a very small spot, but it's somewhere that'll never be visible so no biggie. Had to cut away a couple spots on the projector bezel, or whatever the name is for the decorative outside piece. It was hitting the OEM housing in a couple spots, which is why I had to modify them. But I think those couple little mods pretty much took care of it all. I only did 1 for now, will do the other one someday soon. I don't think I'm going to completely seal the headlights back up though until maybe April which is when I'll be back home and will have the Balast kit.
Also I'll mention these came with some Halo Angle eye thingies that I snipped the wires on and removed. They were in the way, and cheesy anyway so you'll notice that is removed.
Ok enough rambling, on to the pics.
Old 02-16-2010   #45
Nice! I'm interested in how they'll come out!
Old 02-16-2010   #46
Looking good dude! I might have a little niteshades left over that you could have. I work in St. Paul and will try and remember to check tomorrow morning before I leave for work.
Old 02-16-2010   #47
Those are pretty hands.
Old 02-16-2010   #48
I should mention, that these are the G3 projectors. I think Primo has some of the G1 projectors. The G1's I'm sure would have fit without a problem as they are much smaller. But the G3's have a little better light output so that's why I went with them. But I have a feeling even the G1's weaker light output, is still probably quite a bit better than most OEM halogen setups. I still wonder if maybe I should have just gotten the G1's, but oh well.
Old 02-16-2010   #49
Cool let me know. I don't mind driving 15 minutes to get some. But any further than that, and I think I'll use enough gas to have just gone and boughten some myself.
If I buy it myself, where do you get it? I have O'Reilly, Autozone, and Napa all real close. Also Welle's is right up the road, and they always have a lot of paint stuff. Also does anyone else make a similar product for cheaper other than VHT? Walmart usualyl has a pretty big paint selection, so maybe like rustoleum sells a similar product?
Old 02-17-2010   #50
I just found it, and there isn't a ton left but I would think it would be enough. I work off Rice and University in St. Paul and will probably be around Minneapolis later on. Shoot me a PM or something so I don't clutter up the thread too much.
I picked my can up at the old MAS off of University.
Old 02-17-2010   #51
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
damn! looks like they came from the factory like that.
Old 02-17-2010   #52
Most O'reilly's stock niteshades also, at least the 3 in St. Cloud do.
Old 02-17-2010   #53
I think I may just check out the stores near by here and see how much a can is first. If a can is cheap, I'll just grab a can for myself. If not, I'll hit you up!
Old 04-08-2010   #54
OK well now that I'm back home, I can continue with some of this.
Just did a light 3 coats of niteshade on the orange reflector pieces that go in the headlight housings. And 2 coats of clear. I didn't wetsand or anything since they're going to be inside a headlight housing. Figured not worth it. The goal here wasn't to black them out, but to just give them a darker orange look. Turned out exactly how I wanted for the most part
Also got my HID kit and DRL killers from Primo!
ID:	9964   Click image for larger version
ID:	9965   Click image for larger version
ID:	9967   Click image for larger version
ID:	9968   Click image for larger version
Old 04-14-2010   #55
OK well got them to work. One of the ballasts is dead, so I could only play with one side at a time.
Some pics:
Ballast Mounting. 4 zipties for each ballast
Headlight mounted on each side:
Old 04-14-2010   #56
Here's some light output compare pics. These were all taken within about 30 minutes of each other.
You'll see that I put some tape on the garage door, marking where the 'cutoff' was on the stock halogen setup.
1st is just the stock Halogen:
Stock Halogen vs. my stock 2006 Saab 9-3 HID's (5000k bulbs):
Driver Side 4300k HID vs. Pass Side stock Halogen vs. Saab 5000k
Driver Side stock Halogen vs. Pass Side 4300k HID vs. Saab 5000k
Old 04-14-2010   #57
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
lookin' good man,
I have some spare ballasts up here if ya need a set,
Jesse-
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
Old 04-14-2010   #58
Originally Posted by mx3twinturbo View Post
lookin' good man,
Jesse-
Thanks man. I wrote Mike a PM saying one is dead. The bulb fires for a split second but then dies. Troubleshot it down to the ballast. So I wrote him a PM asking what we might be able to do. Maybe I'll just give you guys a shout tomorrow and stop by, cuz I wanted to talk about a 4bolt swap on the Talon anyway.
Old 04-14-2010   #59
Wow, that looks really good man! I wish I had the balls to do a retrofit in the Subie or the talon...
Old 04-15-2010   #60
Thanks for the new ballast Primo
