Build the X 17 56.67%
Old 02-26-2010   #121
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Dave's Evo X Build
It's dropping a bit at redline, 25.5ish
Old 02-26-2010   #122
mlomker
*Resting In Peace*
mlomker's Avatar
Ask Shane where your IDCs end up at when you're done. Did you up base fuel pressure?
Old 02-26-2010   #123
Murlo26
Murlo26's Avatar
Coupler pooped off
Old 02-26-2010   #124
Moar moar!
Old 02-26-2010   #125
Murlo26
Murlo26's Avatar
So one coupler was leaking slightly (the whole time it looks like) and then when we hit 410 two popped off and one was the LICP one off the IC. So the bumper needed to come off but we didn't have time.
SO basically, back to square one, well not that far but I am going to pull the bumper tomorrow and leave it at home and tighten everything. Then we will tune bumperless to avoid this again.
Took us a bit with the boost leak test...everything was going so smooth. I am thinking 420whp should be possible on this turbo but we will have to see. Spool was about 700 later at 25psi.
I will post up a few graphs later.
Old 02-26-2010   #126
Get a wrench on those t-bolts and be manly about it! If you feel the pipes are too slippery rough them up a bit with sandpaper, but I've never had to do that before.
Old 02-26-2010   #127
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
30psi and 450hp possible?
I want to see how broad the power band is on a X compared to a IX.
This thread delivers!
Old 02-26-2010   #128
Or ask to use some of Shane's hairspray.
Old 02-26-2010   #129
probably, but he's on the stick clutch still!
this this!
Sorry about that man, but the numbers sound promising! Sounds like you are really close to complete, prepare for awesomeness on the road!
Old 02-26-2010   #130
Murlo26
Murlo26's Avatar
I am thinking when I get my clutch in and we crank it up to 32ish psi that 430-440 is what we will see.
I could be wrong though, might make more. If i do some valve springs/retainers and we rev it out to 8000 we could get there i bet.
Old 02-26-2010   #131
Murlo26
Murlo26's Avatar
Here you go, last good run before kaput:
Old 02-26-2010   #132
Murlo26
Murlo26's Avatar
Compared to stock, if you look at 25psi, lost about 700 as i said. Still not a laggy turbo, people who call this laggy need to ride in a 35r car.
Old 02-26-2010   #133
Wow I'm still amazed how power on the X's just goes up up up! Looks like a set of springs could really help your peak whp by 20whp or so, depending on how high you rev it and when it starts to fall off.
What was peak wtq?
Old 02-26-2010   #134
Murlo26
Murlo26's Avatar
353 I think. At less boost than before though. Didn't loss too much torque, 376->353, 23, meh.
Old 02-26-2010   #135
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Graph looks good! I like how it doesn't fall off at the top!
Old 02-27-2010   #136
Murlo26
Murlo26's Avatar
yea i just wish i could actually drive it...still don't get to boost. DAMN!
Old 02-27-2010   #137
Wow, nice power band! Get that coupler tight, throw some springs in the head, upgrade the clutch and see what it can do!
Old 02-27-2010   #138
Murlo26
Murlo26's Avatar
Grabbing a new set of plugs tomorrow just in case. Then some hairspray on the couplers, take the bumper off and hit the dyno sunday.
Springs will come later, because it looks like the power isn't dropping so revving it should help for sure.
Old 02-27-2010   #139
mlomker
*Resting In Peace*
mlomker's Avatar
Old 02-27-2010   #140
get an electric impact after that coupler, or even a nice drill. that should do the trick
Tags
