Old 03-22-2010   #261
Re: 91 Galant VR4
I've also heard good things about the QTP's for tires john.
Old 03-22-2010   #262
Re: 91 Galant VR4
the 17421 or the 17500 would work. I would have to run tubes but thats not a big deal.
http://www.summitracing.com/search/B...iew=sku&page=1
Old 03-24-2010   #263
b00sted_spyder
Re: 91 Galant VR4
Just saw this thing. Amazing!!! This will be one heck of ride. I can't wait to see the finished product.
Old 03-26-2010   #264
Re: 91 Galant VR4
I now have the 4 hood pins mounted, then I just set the height when I have a hood to install. And the hood can be removed for easy work or can be pulled off with the front clip for bigger jobs.
I boxed in the upper frame rail to the unibody structure, this will help make the front end as strong as possible. Just a little more clean up and a few more welds, then its onto painting before the motor goes back in for finish assembly.
This strip of aluminum replaces the 2lb stock blob of metal, and this does the same job but is a 1/4 of the weight. This is the rear subframe front mount to the body.
The rear bumber cover is back on, I have some tabs on the top underside lip, then the plate in the middle that holds the bottom up. Now just a few more rivits and brackets in the wheel well area and the back of the car is done minus the rear window.
It is getting closer, we will be painting this weekend, then build the dash and start to lay out the wiring.
Old 03-26-2010   #265
Re: 91 Galant VR4
I realized the other night that I rode in this car back when it had no interior and two seats. We did a pull on 694 with Ryan in his green Galant VR4. Kind of surreal seeing it take on this transformation.
Old 03-26-2010   #266
Re: 91 Galant VR4
I'm also thinking your wheel selection will be much better with a five lug conversion but you never know, there might be some out there.
Old 03-26-2010   #267
Re: 91 Galant VR4
That rear subframe aluminum piece looks scary, is that really gonna help?
Old 03-26-2010   #268
Re: 91 Galant VR4
The aluminum strip is 3/16" thick and tomorrow I will add spacers to hold the sub frame tight up to the body mount. The stock unit is 1/16" steel and just has what looks like a big washer welded to it to make it as big as the sub frame. But the stock unit tightens down on the center sleave thus not making contact with the sub frame itself.
Old 03-27-2010   #269
Re: 91 Galant VR4
Looking good dude! I love the hood design, that it can come off with the front clip or by itself.
Old 03-28-2010   #270
Re: 91 Galant VR4
We have decided to paint all the high traffic areas mat black, and the interior a grey color, the exterior will remain summit white. The idea is to keep the engine bay and trunk looking cleaner.
This will match the block and valve cover that are black also.
Old 03-28-2010   #271
Re: 91 Galant VR4
I suppose I never did post up a complete mod list, so here is updated version.
Engine:
2.0 block bored and honed .040 over
wiseco 9.25:1 pistons
Crower rods
stock 2.0 crank, balanced and polished
King std sized rod and main bearins
ARP main studs, line bored and honed with pins in the main caps
removed balance shaft
Cometic HP head gasket
A1 L19 head studs
major head port work
1mm over ss valves
shimmed crower valve springs and shaved down chrome moly retainers
Crower 288 cams
Crower cam gears
Greddy blue timing belt
Turbo setup:
Garrett standard bearing GT4202 with 1.01 divided housing (I will up grade to the Billet 4202 and Tial exhaust housing later)
custom divided top mount T4 exhaust manifold
custom REEF drag SMIM with 3 injectors per cylinder
PTE WTA intercooler core with custom end tanks 3.5" in and out
custom wta intercooler heat exchanger, 4 gallon system with ability to add 1.5 gallons of ice
twin tial 38mm waist gates
4" tube style exhaust
10lb NOS bottle, will be a 75/100 shot dry in the TB or 100 shot direct port dry
Fuel:
8 1600cc injectors (2 per cylinder) as secondary injectors
4 450 or similar injectors(factory location) for low throttle
fuel pump/s will be aeromotive A1000, aeromotive eliminator pump, or 4 Ford GT fuel pumps(330lph)
-10 aeromotive AFPR
1/2" aluminum hard line, feed and return, -10 SS braided line from pump/s to hard line and hard line to fuel rails and AFPR
pump gas fuel E-85 3x psi
race gas E98 or C/Q-16 5x psi
AEM EMS, 5bar map, GM IAT, secondary injectors ran from a injector driver box to split the secondary injector signals(4) to run the 8 1600's.
Drive train:
shep stage 4 or similar tranny
twin disk clutch or equal
stock tcase
stock 3 bolt ring and pinion
4 bolt LSD diff
stock 4 bolt rear axels
stock front axels
solid mounts on just about everything
Tire option 1 click
Tire option 2 click
tire option 3 BFG drag radials 275/50/15
Rim will be a Enkei RPF1 or similar 15x8 4x114.3
chassis:
8 point 1 5/8" .083" wall DOM chrome moly roll cage
tied in front tubular frame structure retaining factor strut location and engine mounts
1 5/8" .083 dom chrome moly dash bar
added 2" x 3" .125" wall mild steel frame rail for main hoop and D bar mounts
Kirkey race seat w/ custom mounts and 5 point G force safty harness
I will buy a Hans device when things start to get fast
K sport coil overs for a 1g
lexan rear window
removable front clip
removable trunk lid
stock breaks
EBC red pads all around
slotted rotors up front
SS break lines
new ball joints and tie rod ends
custom fabricated strut bars
The rolling chassis weighs in at 1500lbs
Total race weight with drive should check in at around 2400lbs
The fastest this car has gone is 11.66@122, as posted on DSM Times. This was 3100lb race weight and about 440awhp.
Any other questions or if you want to see more/different pics of something let me know, thanks for looking.
Old 03-28-2010   #272
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: 91 Galant VR4
That's one big ass list, looks real nice though, cant wait to see it run.
Old 03-28-2010   #273
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: 91 Galant VR4
Why a cometic headgasket? Why not a Felpro permatorque or whatever. All the HIGH hp guys are running that with L19s and love it.
-1990 Mitsubishi Cyborg 4WD-
Old 03-28-2010   #274
LingLing
AznKraut
LingLing's Avatar
Re: 91 Galant VR4
Wow, that's quite the mod list! I hope I get the chance to see this run down the track sometime!
Old 03-28-2010   #275
Re: 91 Galant VR4
I bought this gasket 6 years ago. It seemed to hold up fine last time it ran. The engine did not push coolant. If the gasket does not work out I will buy the Felpro, again I am starting low on the power and this should hold for a while.
Old 03-28-2010   #276
Re: 91 Galant VR4
That engine bay looks amazing painted.
Old 03-28-2010   #277
Re: 91 Galant VR4
This thing is really shaping up John, do you have an ETA on when you expect it to be done?
Old 03-28-2010   #278
Re: 91 Galant VR4
I can't wait to see this, I'm loving all this crazy build stuff I'm seeing lately.
Old 03-29-2010   #279
Re: 91 Galant VR4
Engine:
Crower rods
A1 L19 head studs
1mm over ss valves
Crower 288 cams
Crower cam gears
Turbo setup:
Fuel:
-10 aeromotive AFPR
Drive train:
stock tcase
4 bolt LSD diff
stock front axels
Tire option 1 click
Tire option 2 click
chassis:
lexan rear window
removable trunk lid
stock breaks
SS break lines
Don't forget last "go around" the car made 660+awhp easily on the last setup, never saw track duty.
Old 03-29-2010   #280
Re: 91 Galant VR4
The ETA on going down the track is riding on getting the cash together to finish it up. I made the list of stuff still needed for this, and its kind of a big number, a little less then I was thinking though. It might just get up and running enough to drive around, but no track duty for a while, I hope this race season it can show a little of what it can do.
