Old 03-26-2010   #161
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: 4g63tcrazy's new setup for 2010
Finally got around to installing my prothane motor mount for the front. Reason I haven't done it, is cause it's for an AWD so it mounts differently and same for the rear mount.
Here is what I did. I'll let the pics do the talking.
I did the same thing with the rear. I also put my stock mounts back in on the sides. My car shakes so horribly I couldn't stand it anymore. Front and rear is all you really need so I'm hoping the car doesnt rattle my teeth anymore!
I got my L19's in the mail today too!
-1990 Mitsubishi Cyborg 4WD-
Old 03-26-2010   #162
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Ummmm.....I was able to change mine out from fwd to awd in my garage. A little over-kill? lol
If it works, it's all the same. Just hope the welds don't break under all that powah.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 03-26-2010   #163
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Not sure how you were able to mount them. You can see the mounting points are completely different. The rear mount was also a lot taller or shorter. Cant remember which..
Old 03-26-2010   #164
123abc's Avatar
Drives: Loud cars
No, the insert. I was able to change the insert from the fwd metal mounts to the awd metal mounts. I had to use a saw to get the old rubber insert out, but the poly inserts should go in by hand.
Old 03-26-2010   #165
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Ohh I see. I didnt want to deal with any of that BS so I just cut and welded haha. My rear mount has been in the car like that for the past year and it's fine.
Ordered a timing belt and BS eliminator kit from partsdinosaur this morning. Also an intake heat barrier gasket and front case gasket from MAP.
Old 03-26-2010   #166
Wow, that site is awesome. Some really good prices there!
Old 03-28-2010   #167
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yeah I've heard nothing but good feedback about that site.
I've been rolling around with a black bumper on my car cause the old one no longer works with the new front mount. Finally had some time to paint it today since it was so nice out. I used a can of spray paint mixed for my color code from carquest once again. It turned out really well.
Here are some crappy cell phone pics.
Old 03-28-2010   #168
123abc's Avatar
Drives: Loud cars
Hopefully that bumper will match good. Paint looks good though!
Old 03-28-2010   #169
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I put it up close to the car and it looks pretty close. Same paint I used on the firewall. Either way it's better then a black/grey bumper!
Old 03-28-2010   #170
123abc's Avatar
Drives: Loud cars
No doubt man.
Old 03-29-2010   #171
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Put the bumper on today. It's not as shiny as the original paint but it still looks nice. I think it needs a clear coat but the guy at Carquest said I can't use a clear on it? I also finished running the rest of the harness inside the car and put all the panels back together, waxed the rest of the engine bay to match the shiny firewall and a few other little things.
Pics of bumper. (I know it's crooked in the pic but I did straighten it out)
My timing belt and BS elimator showed up today which is amazing since I ordered it Friday. I also got an aluminum radiator on the way now.
Old 03-29-2010   #172
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
This car is really nice. It looks really clean. i Love The Red and Black Color Combination under the hood. Personally im starting to go with Black and grayish silver look.
Old 04-02-2010   #173
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
^^Thanks!
Time for another cell phone pic update.
I prepped my block surface and installed the L19 headstuds. I then started taking everything apart for the balance shaft eliminator kit. All I need to do is pick up my gaskets from MAP and the balance shafts will be done.
My car has never been so apart all at one time. I feel like I have a LONG ways to go before it gets back together. Hopefully I don't run into too many problems and everything goes back together nicely.
Old 04-02-2010   #174
I know the feeling man.
Old 04-05-2010   #175
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Picked up most of the gaskets I need so I can start putting the front case back on. Got some supertech valve stem seals and dropped them off at Primo. I have the day off tomorrow so I'll probably get the BS elimation done and maybe start the wiring for my fans.
Old 04-05-2010   #176
You're gonna do the BS elim in the car? Sounds like a pain in the ass.
I think you should clear that bumper.
Old 04-06-2010   #177
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yes I'm doing it in the car. I already have it done just need to put it all back together. It's not fun at all sitting in the wheel well for hours at a time..
I don't know what I'm gonna do with the bumper yet. I think it needs a clear too.
Old 04-10-2010   #178
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Little update.
I got the BS elimation completely done. The car is just sitting there waiting for a head to be put back on it. Hopefully that will be done Tuesday..
In the back of my mind I have been pondering the idea of getting new rims. New rims as in a nice set of 16" wheels so I can put some meaty tires on and have more traction then my 18's. I looked on craigslist for a couple months and never saw anything good. Then it hit me.. What about FD RX7 wheels? Light, 16's, wide. PERFECT.
So I searched the classifieds and Lor (turboimports) actually had a set for sale! So I scooped those up from him today.
The plan is to repaint them. But still keep them black. Then put on some 235/55r16's - 245/50r16's not quite sure yet. And more than likely some 10mm spacers.
Old 04-10-2010   #179
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
wow. very nice! you should do 255-45-16 fronts and 225-50-26 rears...lol. jk. lookin good though man! wish i had the time to do what you're doing.
ლ(ಠ益ಠლ)
Old 04-10-2010   #180
123abc's Avatar
Drives: Loud cars
They're going to look sick on there. I wish I had some FD rims...
