Old 04-05-2010   #1
SpyderGSX07
SpyderGSX07's Avatar
Drives: 97 GSX Spyder/99 Chev S-10
4g64 95% Together
This is the 4g64/4g63 hybrid motor.. keeping the turbo stock for now until i get it all working right. its a big enough project the way it is.... This is the motor almost all put together.. still need to put on the galant cam gears and timing belt. then time it..
ID:	9957   Click image for larger version
ID:	9958   Click image for larger version
ID:	9960   Click image for larger version
ID:	10078   Click image for larger version
ID:	10080   Click image for larger version
ID:	10081   Click image for larger version
SpyderGSX07 is offline   Reply With Quote
Old 04-05-2010   #2
Re: 4g64 95% Together
Neat.
I hope you are not putting a T25 on this.
omfg you are...
Old 04-05-2010   #3
cmspaz
Walls need hugs too
cmspaz's Avatar
Insta-spool at 1.5k? lolwut?
Your powerband will end at 4!
Originally Posted by Trogdor
Old 04-05-2010   #4
Please please PLEASE tell me thats powdercoat and not spray paint on all of the hot parts
Old 04-05-2010   #5
its a SRT4 neon.
Old 04-07-2010   #6
SpyderGSX07
powdercoat. yes t25 i'll upgrade later big enough project. lets get everthing in working order
Old 04-08-2010   #7
b00sted_spyder
Even the head???
Old 04-08-2010   #8
SpyderGSX07
Ok ok I high tempt it. What do you want from me! Haha but I did powder coat the parts that I could
Old 04-08-2010   #9
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Do you realize how hot your turbo and exhaust manifold gets?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-08-2010   #10
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
insta spool madness!!!!
i believe a 2.4 + t25 = fried turbo extremely fast?
and a fire from all the high temp paint perhaps?
lulz
Old 04-08-2010   #11
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Wooo, sounds like fun? I would strip all that paint off the head, that sounds like a bad idea.
Old 04-08-2010   #12
SpyderGSX07
ok we'll see what happens... what if the paint is 1200 capable?
Old 04-08-2010   #13
SpyderGSX07
and it is going to be running low psi for now until i can get it all running correctly.. clean slate before upgrading
Old 04-08-2010   #14
cmspaz
Walls need hugs too
cmspaz's Avatar
1200... C or F?
Old 04-08-2010   #15
Doesn't matter, the head doesn't get very hot. The V8 guys paint aluminum heads for stock appearing classes, so it looks a little funny, but shouldn't cause any problems.
Old 04-09-2010   #16
95tsi
95tsi's Avatar
Drives: a pos
if you want any help let me know. I live in the same town...
Old 04-09-2010   #17
x2
Old 04-09-2010   #18
DSMs get very hot, A good way to tell is go to a meet and ask people to pop their hoods, then take a non contact temp reader on some of the parts that you have used high temp paint on. You will be surprized at just how hot it gets. You can get the non contact temp readers for cheap from places like harbor freight.
It wont likely cause a fire, but it will smoke like hell with a nasty smell, then while it burns off it will look like crap.
Old 04-12-2010   #19
SpyderGSX07
okay i'll check up on it
Old 05-04-2010   #20
SpyderGSX07
got the motor in.. gettin things slowly together as i figure out whats beat up and whats good
