Old 04-08-2010   #1
Carbon Build-up causing leaky valve seats on local evos?
So, I now know of four local evo owners that had problems with valve seats/seals. First was chukee, but we're pretty sure that was an ever-so-slightly bent valve. Next was Shawn (DoughtCom), then MattD, and now Trevor. Anyone else want to come forward that's down on power and found a cylinder or three to fail a leakdown test?
When we pulled MattD's head off, I was shocked to find about 1-2mm of carbon build-up on top of his pistons, and a nice good thick frosting of it on all of his valves. His motor had 100k miles on it, but look at this:
So my question is this: is it possible that carbon build-up is causing these leaky valve seats/seals to occur? Imagine a chunk of carbon built up and not letting the valve seat all the way. The only thing that's weird about that, is that you'd think it would get mashed/swept away over time.
Next question: is it worth (or even possible) to use some sort of cleaning product to get rid of all of this build-up?
Options include:
-seafoam
-Mopar CCC
-AMSOil QuickShot SE (Fuel injector cleaner)
-Wynn's Injector Cleaner
People have been swearing by this stuff on evoM:
http://forums.evolutionm.net/vendor-...-services.html
but, since its the exhaust valves in trevor's case, is it even going to hit them?
Old 04-08-2010   #2
Re: Carbon Build-up causing leaky valve seats on local evos?
MCCC is the shit.
Old 04-08-2010   #3
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Wow!
I did the sea foam trick on my DSM a ways back. I don't know if it did any good but it left a huge smoke screen and I don't recommend it if you are still running your cat.
E85?... O wait that causes gummy injectors...
Old 04-08-2010   #4
E85 has been known to give engines a good cleaning though.
Old 04-08-2010   #5
Trevor has been running E85 for several thousand miles...10k? Idk, i'll let him chime in.
Where would you put the seafoam in this case? In the gas?
What about MCCC, spray it down the spark plug hole, possibly while compressing the valve so it is open, to get the cleaner on the back side of it?
Old 04-08-2010   #6
The carbon on my pistons came right off with the use of brake cleaner and my fingers. Worked the brake cleaner in with my fingers and then scraped it off with my fingernails. I have no reason to believe that this stuff wouldn't just fall off when the time was right and get stuck on a valve seat. In a couple of the valve recesses on the pistons they were filled in pretty well with carbon, and in that picture you can actually see that the valve hit that carbon.
Old 04-08-2010   #7
The only way I've used MCCC is to spray it in the spark plug hole to let it soak on the piston (could do the same with SeaFoam, always change the oil right after this method) or to spray the MCCC into a vacuum line while the engine is running (you'll need to hold the idle around 3k RPM to keep it from dying).
Old 04-08-2010   #8
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Got about 13,000 miles with E85.. I think Shane looked at the top of the pistons really quick not sure what he told me about them tho...
Old 04-08-2010   #9
If they look like that, and you're running E85, I wonder if you don't have some kind of oil leak or something else getting in your combustion chamber. I run E85, my cylinders aren't shiney new clean, but pretty clean overall. Nothing like that!
Old 04-08-2010   #10
They used to make these one cars, I think collectively they were called DSMs there is even a site with VFAQs on them I am sure one included how to use seafoam and MCCC to clean your engine.
Strange.
Old 04-08-2010   #11
RS98GSX
RS98GSX's Avatar
Drives: White on White 98 GSX
Where is he filling up on E85?
RS98GSX is offline   Reply With Quote
Old 04-08-2010   #12
Guys, the picture above is my car. 100,000 miles on 93 octane. Never a sign of oil leaking, the head gasket looked perfect.
Old 04-08-2010   #13
RS98GSX
RS98GSX's Avatar
Ok still where do you get your gas from?
Old 04-08-2010   #14
Strange.
Nice :P
http://vfaq.com/mods/MCCC.html
Trev, what do you think, wanna try this?
Old 04-08-2010   #15
Yeah but it sounded like he was saying Trevor's was the same, and he was running e85. Did I interpret wrong?
Old 04-08-2010   #16
t-revzr
FLOSSEN
t-revzr's Avatar
Nice :P
Im down! Im going to call Ron tomorrow and see if he will let me borrow his scope you were talking about. Then we could really see in there since its a camera!
Old 04-08-2010   #17
Yes because we haven't seen inside Trevor's cylinders yet. Regardless he has an exhaust valve leaking and so far no one has had a burnt or bent valve so that really only leaves us with the carbon buildup option.
BP mostly unless I don't feel like driving to one and won't be beating on the car then it's whatever 92 octane is nearby.
Old 04-09-2010   #18
How dare you compare an Evo to a DSM. They share nothing in common! One has 2 doors the other has 4 doors. It's just a coincidence that they pretty much have the same motor, ecu, drivetrain, mas, owners, pistons, rods, cranks, lifters, and rusting problems.
Old 04-09-2010   #19
t-revzr
FLOSSEN
t-revzr's Avatar
I hope this stuff works!
Scheides, Matt D and I will be tryin this out on my car Sunday..
Old 04-09-2010   #20
RS98GSX
RS98GSX's Avatar
BP and shell are the best places to fill up. holiday or SA would do that
