Closed Thread
Old 04-11-2010   #41
Twitch
Twitch's Avatar
Drives: 2005 GTO, 2006 Duramax, 92 turbo civic, 85 Grand National
Send a message via AIM to Twitch
Re: Mitsubishi Mirage Pics
You are so full of shit. And were the fuck is my 80.00 for th tach or I want the tach back.
Im so full of shit?..You can ask Alex (iceminion) about the deal and then see who is full of shit.
Twitch is offline
Old 04-11-2010   #42
I want my 80.00 for the tach or the tach back. I have built so many engines and I do know what I am doing. How the hell do I know what you did to it after you drove it out of the drive way. And the turbo never came apart it came from a style member and was put on the car. You are still a young kid that does not know much about a modded car and don't start on ice he drilled holes in is engine to vent the crank case
TkrPerformance is offline
Old 04-11-2010   #43
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Drilled A Hole Into His Engine!!? LOL Its hard to admit mistakes, but we learn so much more if we are humble and let the senior members teach us! Pay up the cash deal is a deal. Plus why would TKR give you something that on purpose is broken. . . ? look at his rep he is a good guy that KNOWS WHAT HE IS DOING!
Better get chimms wheel back trust me he dosnt play around when it comes to his wheels lol!
Alpha D is offline
Old 04-11-2010   #44
Twitch
Twitch's Avatar
First of all if you wanted to get the tach back you should answer my pm's shoutbox messages, texts, and calls instead of avoiding me!
Twitch is offline
Old 04-11-2010   #45
Ok, wait. How the hell does RTV get sucked through the screen for the pickup tube? Let alone a piece big enough to clog an oil port? One more thing. A clogged oil squirter will not choke off enough oil to send a rod through the block. All the oil squirters do is spray oil at the bottom of the pistons to cool them off a little. They don't do anything for lubrication of moving parts.
Kevin 1G Drummer is offline
Old 04-11-2010   #46
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
additionally, if in fact your engine was starved for oil, wouldn't that cause the turbo to wear really quickly? The turbo was probably fine when he installed it.
Style's automotive engineer
s1ngletracker is offline
Old 04-11-2010   #47
cmspaz
Walls need hugs too
cmspaz's Avatar
Jesus fucking Christ can we be done with the drama over this? Calm the fuck down and quit pointing fingers. Jake, you're the one who put 1000 miles on the car on the break-in oil, not Mark. It realistically doesn't matter if he or anyone plugged up the oil squirters that effectively do nothing anyway, you pretty much sealed the deal sooner or later on that motor by running it with all the assembly crap mixed in there for 500 miles past what the engine builder (or anyone, for that matter) recommended. If you'd gotten that motor from a reputable shop, they'd be telling you to fuck off as well, you didn't follow the explicit instructions that were given.
I trusted Mark multiple times with my Talon, and I'd gladly trust him with my Evo. The truth is, he's only human, and humans can and inevitably will make mistakes, just like the mistake you made that fucked up your engine. Sure the experience left a bad taste in your mouth, you gotta wash it out and keep fucking eating.
Car's obviously done, so [/thread]
Originally Posted by Trogdor
cmspaz is offline
Old 04-11-2010   #48
LingLing
AznKraut
LingLing's Avatar
Twitch, don't be sour because you blew your motor up. I didn't bitch and point fingers when my transmission went out. Shit happens to modded cars. Deal with it and quit bitching or GTFO.
LingLing is offline
Old 04-11-2010   #49
fwiw iceminion is not high on my list right now, he's not returning my PM's either. I think everyone's busy right now and should man up and stop waving fingers and fix their shit, get it driveable, end of story!
scheides is offline
Old 04-11-2010   #50
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Originally Posted by Twitch View Post
Ok so i know a lot of people think i might be being rude to mark and sayin that it could not have been mark that made my engine throw a rod but i have proof that it was in fact mark. Recently i purchased a new block from Iceminion. He insisted that he help me take my old engine apart and put my new one back together. When we were taking the old engine apart we found chunks of RTV blocking oil squirters. the RTV was put on in large amounts around the oil pan and sucked up through the pickup tube so my motor was getting little oil. Also the 14b turbo he gave me (which he had taken apart and did god knows what to it before he put it on my car) was shot and had 1/4 of shaft play. I was told thats what mad the whining noise so i also had to buy an Evo III 16g.
Wait... Did Mark know about this before you posted this or is this something new to him?...
I am so confused on whats going on now....
Andrew7dg is offline
Old 04-11-2010   #51
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
I agree plus chunks of rtv through the oil screen that would take effort to sift flower through come on. If anything would have happened it would be a bearing failure on a rod that could be cause by a number of things including unchanged oil or just a bad part.
craig is offline
Old 04-11-2010   #52
I have seen personally RTV in rod oiling holes and other areas of engine lubrication areas where it shouldn't have been, so I believe it's possible.
I have heard a lot of negative things about this Twitch guy, but who is to say that mark didn't build a shitty engine?
Sounds like you bought this car with a freshly built engine with under 1000 miles on it. I would never trust anyone enough to buy a car with an engine with so little miles on it. You have no idea if it was assembled correctly, broke in properly, etc. Even if this kid maintained the engine better, broke it in better, still could have failed regardless, we'll never know.
sleepydsm is offline
Old 04-11-2010   #53
You took a chance when buying a swapped car with a freshly built engine in it. Buying a used car, especially an older modified one, is "buyer beware" and frankly you were in way above your head. You know nothing about these cars and it would have been a much smarter idea to just buy a nice stock 1G (as everyone told you to do). There is also no reason you couldn't have gotten an inspection done prior to purchasing the car.
If Chim doesn't have his wheel back or Mark his tach (or appropriate payment) within the next month you'll be gone for good. I'm really getting sick of your posts, you've already been warned about bashing members; if you have a problem with someone then make a feedback thread in the appropriate section with honest information posted in a mature manner.
When you're back, if you play by the rules, I may consider unlocking this thread.
Kracka is offline
Closed Thread
