Old 05-17-2004   #1
john
Business as usual
john's Avatar
Anyone know how to check the waterpump and thermostat? I am not sure how to check and I thing one of the two is going out. Thanks
**This is ghettostyle under John's name
97 Viper GTS
Old 05-17-2004   #2
The only thing to go out on the water pump are the bearings and seal. If it is leaking from where the shaft is, or if you can wiggle the shaft itself then it's shot.
The easiest way to know if your thermostat is bad is if your car is running cold and never heats up. The thermostat is designed to open up at a certain temp, but when they go bad they will open up too soon or get stuck open so your car will never get to operating temp.
Old 05-17-2004   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
That is true assuming it is a "fail safe" model. I have encountered older thermostats which are not "fail safe" and they will not open when defective. This is never good, when buying a new thermostat from anyone but Mitsu ask if it is a "fail safe" unit, if the clerk gives you the deer in the headlights look(swanny knows what that looks like ) shop somewhere else from now on.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 05-17-2004   #4
john
Business as usual
john's Avatar
You dumbass, I just posted a similar thread for you.
Thanks for the help. I am guessing he has one of the older thermostats. I will check the water pump for play. There is oil all over it though along with everything else under the timing belt cover. Not sure where it is coming from. Most of it seems to be on the block and down. Maybe a bad HG or something. We will probly replace that now also.
97 Viper GTS
Old 05-18-2004   #5
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Thanks for the help. I have new plans for the car now. Please disregard this post.
7/25/09
