Old 11-08-2010   #1
Goodhart's Performance Part-out!
Old school Buschur Racing 3” Turboback Exhaust w/ Dynomax muffler and 3" V-Band connection
(all 1 giant piece AFAIK, maybe 2, not my doing...) -$200 OBO
^^It's in there, garage was a mess lol
-10 AN Pushlok Turbo Oil Drain with extra straight -10 fitting (more than $40 worth of fittings alone LOL)-40.00
Other small stuff:
good condition 1g coolant overflow $5
1g interior door panels (grey in color, good shape, both sides, no carpet) make an offer
Freedom Design Front Strut Tower Bar -make an offer
-3 Stainless Braided Turbo Feed Line -$20.00
Ebay Rear Strut Tower Bar -make an offer
2 or 3 sets of stock plug wires : make offer
SOLD:
Primo Performance 2.5” Aluminum Intercooler Piping -$200.00 OBO perkal8tr
Random 1g lower intercooler pipe $25perkal8ter
6 bolt ARP's -$25 perkal8tr
Headlights- $100 x-pride
n/t throttle body w/ FIAV bypass plate-$100 - b00sted_spyder
Clear Cam Gear cover -$50 - b00sted_spyder
JM Fab coil pack relocation bracket -$30 - b00sted_spyder
TiAL 38mm External Wastegate w/ dump -$130.00 GnArKiLl
Eibach Sportline Springs -$100.00 eagle talon guy
Smoked 1GB clear corners -$20 eagle talon guy
A1 Technologies Headstuds $150 Chang
Fel-Pro permatorque $35 Chang
Crower Stage 2 Cams (272's) $180 s1ngletracker
2.5" Catco High flow cat BNIB $50 95tsi
Brilliant 1G/2G HID kit w/ slim ballasts$75 95tsi
Koyo aluminum radiator with 2 slim fans attached -$100 samysnake
1g center vent gauge pod $25 perkal8tr
EPROM ECU w/ custom chip -$150 mikefromMN
KYB AGX Shocks -$150.00 Momin (speedfreak)
Shortblock$500 Chang
Shaved And Powdercoated Valvecover -$30 cornfed2.4
1G Head minus cams, Supertech dual valve springs - $250.00 OBO Chang
1g n/t thermostat housing $10 Chang
Competition Stage 4 Clutch -$250.00 Chang
Forced Performance cast 4" intake w/ recirculation tube for BOV -$65 DSMINMN
Custom Cold Air Intake (comes with the massive K&N filter also) (will work for 1g or 2g) -$100.00 DSMINMN
black top CAS $20 Dan Chang
1g fuel filter (x2)$5 Dan Chang
NRG Adjustable Fuel Pressure Regulator w/ fuel rail connector and gauge -$100.00 Dan Chang
Corbeau 3 point harnesses (universal) -$50 cornfed2.4
DIY Dual Walbro 255lph HP pumps -$100.00 Chang
Stock 2g MAS -$40 spaz's buddy
Home Made Small Battery Tray -$20 GG_IX_SE
NOS Nitrous bottle with some solenoids, line, etc $100 carltalon
1g FWD KYB GR-2's w/ Eibach Prokits springs -$120 OBO some kid
Taylor 10mm Thundervolt plug wires (brand new) -$50 Chang
Primo Performance vacuum distribution block -$20 obo DSMPARTSGURU
1g radiator hoses (brand new) Ling Ling (with shell)
GReddy type RS Blow Off Valve (like new)-$150 fran05
Stcok Evo IX FMIC -$50 Perkal8tr
T3 SC-61 Turbocharger w/ Primo Performance Ceramic Coated O2 Housing -$600 mnsc kid
28x11x3” Dejon Tool Front Mount Intercooler (Swifty's old one) -$150 Ling Ling
Suspension Techniques Add-On Front Sway Bar (comes with all the poly bushings)-$20 OBO Ling Ling
LaCroix "REEF" SMIM- $500 Andy Nash
knockoff EWG $40
Golan filter/fuel feed line/1G rail $75 Alpha_D
[B]ACT Streetlite 6-bolt Flywheel -$85.00 rabeb25
T3 Manifold-$150.00 OBO x-pride
Corbeau CR-1 microsuede seats with Corbeau brackets for 1g $650 Dan H.
Old 11-08-2010   #2
Re: 1994 Talon TSi AWD (Highly Modded) $6,900 obo
Reason I am parting it:
Well, Friday night when I attempted to pick it up, I thought I had fried the transfer case. I had it towed back to Primo because that was my only option at 11:30 Friday night. Today they looked into it, I had already sourced a new transfer case over the weekend, I figured bingo bango put in new t-case, and be done. WRONG. It ended up being the transmission. Mike pulled the drain plug and very little fluid came out.
It developed a leak somewhere while I was doing vacuum pulls on the way back, it still shifted just fine, but it started to howl leading me to think it was the transfer case. I pulled over into a gas station as soon as I heard the noise, and by that time apparently the fluid was almost all gone. Mike said when he pulled the drain plug, it had a burnt smell and there was a thin coating of fluid all over the bottom of the car. Makes me wish I would have picked it up in the daylight so I could have possibly seen this, Primo is currently trying to figure out where exactly it leaked from to see where I should go from here as far as the warranty from TRE. Once we know where/what it leaking from, I will contact TRE and go from there.
Either way, I'm done with DSM's.
Old 11-08-2010   #3
Garage cleanout part 1
delete please.
Old 11-08-2010   #4
OMFGeofffff
OMFGeofffff's Avatar
Drives: '90 Talon Tsi AWD
Re: Garage cleanout part 1
Pictures of the short throw?
OMFGeofffff is offline   Reply With Quote
Old 11-10-2010   #5
Re: Goodhart's Performance Part-out!
Threads moved/merged, let the part-out begin!
Old 11-10-2010   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
dibs on the coil pack relocation bracket, and i'll probably want a few other things.
that throttle body is brand new? Does it have a new ISC? If so, i'm likely to take it.
Style's automotive engineer
Old 11-10-2010   #7
Can i get some pics of the FMIC and the piping, if the car is at primo I'll be in that area tomorrow.
Price me on those 2 items they seem awfully high compared to the rest of the deals, I know you just paid new for them too.
Good luck.
Old 11-10-2010   #8
Yep, brand new from ThrottleBodies.com. Was pressure tested with no leaks just last week. Not sure on the ISC, but I know it works.
Good luck.
FMIC is Swifty's old one if you remember what that looks like. Car will be at Primo till I can pick it up/get down there to tear it all apart. You can check all the parts out tomorrow if you want.
If you buy 3 or more items I can cut you a small deal.
Old 11-10-2010   #9
Ok, I'll go check it out, i don't know anything about swifty's old fmic I'll have to ask.
Old 11-10-2010   #10
Edited some. I decided to keep the valvesprings and retainers for the Evo, so the engine will be getting taken in half. Prices adjusted.
Old 11-11-2010   #11
s1ngletracker
Drives: A BMW
i dont think that is the right website... it looks european. What is the advantage of running a non turbo throttle body?
Old 11-11-2010   #12
Sorry, just realized the site's name is spelled goofy, and not in plural form.
http://www.throttlebodys.com/
Advantages? No need for a throttle body elbow if you just use a 45* coupler, and there is one less potential boost leak. If I'm not mistaken they are a hair larger also. You probably won't find any HP from switching to one, but for me it was worth it just to have one less spot for a boost leak to form.
Old 11-11-2010   #13
s1ngletracker
Drives: A BMW
ah, so I suppose that TB won't work with stock intercooler piping then eh?
Old 11-12-2010   #14
Sorry for the late reply, I'm working on getting a pic.
Old 11-12-2010   #15
If I'm a dumbass I might be interested in the shell.
Old 11-19-2010   #16
eagle talon guy
eagle talon guy's Avatar
Send a message via AIM to eagle talon guy
you are a dumbass. buy it!
-Michael
(^^very old pic!)
6 Bolt build in progress
eagle talon guy is offline   Reply With Quote
Old 11-21-2010   #17
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
I need the valve cover. Please give me a call 612 298 5313 names tyler.
dsm_talontsi is offline   Reply With Quote
Old 11-21-2010   #18
derekvr4
derekvr4's Avatar
Drives: galant vr4
hay dude ill take the poly mounts shoot me a pm with your paypal info
derekvr4 is offline   Reply With Quote
Old 11-21-2010   #19
Ok everyone, here is the deal. The car is still sitting at Primo because I haven't had a chance to grab it and drag it back to my parent's house yet. As soon as I get it back, I can start taking parts off. Soon as I get it back, I will keep those interested in parts informed as I start tearing it apart.
Old 12-13-2010   #20
Bump. Still haven't gotten to tear it apart yet, but I have been removing parts by request. Don't be afraid to make offers!
Tags
keep checking back, prizes!!!!!!!!!!!!!!!!!
