Old 11-22-2010   #641
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: beaterX project thread
Originally Posted by mlomker View Post
I'm not sure what Shane was running for timing on my car but it certainly sounds do-able. I can't really complain about the BBX.
I saw your post discussing fasteners. I'm debating what I'm going to do since I already own the APR splitter. I might ditch it for an undertray and a non-Aero splitter. I'm not going to make a decision until Spring. I'll see what you end up with.
With the tubular mani 400whp on pump sounds possible, but it won't be easy. We haven't seen enough setups like this to say for sure though...so who knows.
Old 11-22-2010   #642
mlomker
*Resting In Peace*
mlomker's Avatar
I'm assuming when he gets S2s in there that they'll outperform my MX1s.
If I end up pulling my motor a year from now then that little error will get corrected. It'll also give me some time to let other people spend their money to figure stuff out. I can't afford to be a trendsetter anymore. heh.
Old 11-22-2010   #643
bananas
bananas's Avatar
Drives: A4
bananas is offline   Reply With Quote
Old 11-22-2010   #644
I spy three n00bs. Nice progress again, and as for being a trend setter/first to do something, it's not about the cost and time it takes, it's about knowing you were the first to do it. I love that feeling.
Cliff notes: put a carbed v8 in it.
Old 11-22-2010   #645
Is that a terrorist? Oh wait wait, it's just Spaz
I keed I keed.
Old 11-22-2010   #646
Lookee what showed up today
Stock LICP kinda hangin there but it lines right up and is juuuust shy of 2.5", probably about 2 3/8" OD and flows very nicely:
Also, found this chunk of lead behind where the FMIC mounts, it seriously must weigh almost 7 pounds. Goodbye!
Old 11-22-2010   #647
Murlo26
Murlo26's Avatar
My lead weight is sitting in my garage...wait no, the basement, lol. I think it was there to try to maintain 50/50 weight distribution as best as possible, screw that!
Oh, nice FMIC! Looking sharp
Old 11-22-2010   #648
cmspaz
Walls need hugs too
cmspaz's Avatar
I keed I keed.
LOL!
I was told on another board that we need to stop having Chuck Norris jokes and instead have jokes about things hidden in my beard.
No Shave November is almost done so I'll attempt to improve that situation as soon as it ends.
Originally Posted by Trogdor
Old 11-23-2010   #649
mlomker
*Resting In Peace*
mlomker's Avatar
I'm going to do weight reduction as one of my last projects, so good to know.
Old 11-23-2010   #650
sweet i have this week off work if you need hand sometime, i need to start getting out of the house for winter.
Old 11-23-2010   #651
I'll be in Florida With family till next tuesday, go nuts!
Old 11-23-2010   #652
lol, back in the day, they didn't need to add weight to make the car equal weight front to back. Crazy, modern manufacturing techniques.
Old 11-24-2010   #653
mlomker
*Resting In Peace*
mlomker's Avatar
Off-topic for this thread, but scheides' old BBK is looking good on E85.
http://forums.evolutionm.net/service...-toxicfab.html
Old 11-30-2010   #654
Murlo26
Murlo26's Avatar
Next Tuesday is here
I see you are on the forums...hopefully epic updates!
Old 11-30-2010   #655
That is so badass! I love that mrfred has my old turbo. Great numbers for only 27psi too!
Indeed it is. A week with Anna's fam was a good break that I really needed. Drank, ate, and relaxed on the beach, Sanibel Island is pretty damn nice for being 'only' florida! Saw some lambos, ferraris, and endless porsche's up close and ripped around in a bitchin grand marquis (3+3 seating and a 4.6L V8 son!.....a 220hp v8...le sigh). Check out this huge bird that swooped down and wanted a sip of my dunkin donuts coffee...he just chilled there for 10+ minutes:
The new Kelford cam is in, I'm swinging up to DB tomorrow night with my cam cap to make sure it slides on easily, then back home to keep movin. If the cam doesn't fit, I'm not sure what I'll do. I have several days of fiddling around to do either way, but I'm not ruling out putting the stock cams back in, returning the kelfords all together and ordering an aquamist kit w/ the cash. S2's or a set of the kelfords can go in next spring if I'm feeling soucy :P
Head is coming off, I will be putting in the little screen thing and re-torquing it with a fresh headgasket, that also comes in tomorrow.
I'll post more info when I get it!
Old 11-30-2010   #656
Dumb question, but why wouldn't the cam fit?
Old 11-30-2010   #657
Where the cam cap goes over the cam, one of the journals on the cam is machined to be 'snug' to (I assume) keep the cam in alignment. I can put the cam cap on my stock cam and it slips right on all the way, but on the original kelford it only went on about 80% of the way and got tight, then at 90% it'd nearly bind, and when torquing them down the cam couldn't even be turned over
Hopefully the new cam will fit just right and this sillyness can be over. I want my car back!
Old 12-01-2010   #658
mlomker
*Resting In Peace*
mlomker's Avatar
After what happened on my cap, I'd be nervous at that point.
Old 12-02-2010   #659
CAMS ARE HERE!
So here's a pic of cam cap #3 sitting on top of the first cam I got. Note how it doesn't quite sit down all the way on the cam:
Thanks to Shane at DB Performance for helping me get this sorted so quickly! He measured the new cam when it came in and was doubtful it would fit...so I brought the cam cap up with me and it slid right on! It was hard even for several sets of calipers to decipher the difference, so who knows...maybe it was out of round or something?
New cams:
Got home, slapped them in immediately:
Enjoy them in there because they're coming right back out, time for some math!
The 4b11t has buckets that sit on top of the valvesprings, then the cam sits on top of the buckets, like a honda. You put the cams in, measure all 16 clearances, then take them out, measure all of the buckets that are out of spec (with the new cams, springs, valves, ported head, its not surprising!), then figure out if you either want to rearrange all of them and try to make them fit, order new ones, or a combination of the two.
I was able to bring all but 3 of the intake valves into spec (.008" +/- .001"), and the other 3 are only another .001" out of spec on the loose side. I would almost feel comfortable running them like this buuuut the exhaust side was just a mess. One had a gap of .003". The spec on that side is .012" +/- .001 so it was waaay out of spec.
So after some extra time with the outside micrometer, shop manual, I had to choose between 47 different tappets to order, all are stepped up about .0006" from each other (.005mm). The ones that were far off I ended up ordering two tappets each, just to be sure I don't have to wait for extras. At $8.50 a pop this was another quick $100+ down into this thing, but this *should* be the last thing I need to put everything back together! I paid an extra $20 to get them overnighted so its gonna be head down this weekend and see how far we get!
Old 12-02-2010   #660
I dealt with those buckets on a friend's Focus, worst fucking idea in the world.
