Old 12-23-2010   #261
Re: Project Lex
1000cc should be good for 1000hp Then take like 30% away for E85. so with 900's I'd say good to 650-700hp. And if I start to run out of injectors, I may just do something to the fuel pump setup to allow me to run a higher FP which should allow the injectors to flow more than 900.
Old 12-23-2010   #262
95talonracer
95talonracer's Avatar
Re: Project Lex
Ok cool where did you find out that info that 1000's = 1000hp for the 2jz on pump? Just wondering.
Amsoil Dealer
Old 12-23-2010   #263
Re: Project Lex
For a 3.0L 6cyl motor, that's just the general rule of thumb. 500cc = 500hp, 1000cc = 1000hp, etc.
Old 12-27-2010   #264
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: Project Lex
High or low Z?
Old 12-27-2010   #265
Re: Project Lex
High-ZZZZZ
Old 12-27-2010   #266
munchgsx
munchgsx's Avatar
Re: Project Lex
Oh nice, they over clock pretty well with more pressure.
Old 12-27-2010   #267
Re: Project Lex
Yeah that what's I'm hoping. Once I push them out of their range, I can just alter my pump setup and run a higher pressure and get more out of them.
Went and drove the car about a mile today just to make sure all is still well after the ABS delete. Car drives great so far, and GPS still works
Parked it and decided to start making progress on the next task, which is Megasquirt.
The ECU is located on the floorboard/firewall under the passenger side carpet. My helper and I (my 20+ y/o cat Freckles) got it removed. Going to go grab some solder and heat shrink, and will then start tapping into some of these wires.
ID:	11184   Click image for larger version
Old 12-30-2010   #268
Re: Project Lex
Phase 1 of the MS3 install is done. All I did was install all the wires that were "tapped" into the existing wires (meaning I didn't do any of the wires that required me to cut them). This was simply so the car would still start and be running completely on the stock ECU, but the MS3 should turn on, and I should be able to play in the software. Here's some pics:
Work area setup
Wires tinned
Soldered, heatshrinked/elec taped
Quality Inspection performed by Freckles
Dangling for the time being. This is where it'll be mounted however. Not completely hidden, but out of the way for the most part, and easily accessible if need be which was my goal. You can see the strips of masking tape with little dots on them. That is where it will be once it's installed permanently:
And last but not least, a little startup vid. Like I mentioned before. I'm trying to go 1 by 1 with the car here. So since everything I hooked up so far was non-intrusive so to speak, all I'm doing here is making sure that I didn't mess anything up while I was down there, and that the car starts up with no problems and there's no magic smoke coming out from anywhere
http://www.youtube.com/watch?v=GAh9RnbQE6k
http://www.youtube.com/watch?v=GAh9RnbQE6k&hd=1
ID:	11186   Click image for larger version
ID:	11187   Click image for larger version
ID:	11189   Click image for larger version
Old 12-30-2010   #269
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
Awesome progress!
Also, meow.
Originally Posted by Trogdor
Old 12-30-2010   #270
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: Project Lex
niiiiiiiiice
ლ(ಠ益ಠლ)
Old 12-30-2010   #271
munchgsx
munchgsx's Avatar
Re: Project Lex
Open the garage door your going to die. Great work! Now you need a blower.
Old 12-30-2010   #272
Re: Project Lex
Don't put it there. Nice progress.
Old 12-30-2010   #273
Re: Project Lex
The garage was open about 2 feet Don't wanna let out all the heat, my poor little heater is already getting worked pretty hard!
And sorry Aaron, that's where it's going I spent a couple hours trying to figure out where else to put it, while keeping it still accessible, and that is the best I could come up with.
Old 12-30-2010   #274
Re: Project Lex
This thing run 10's yet?
Old 12-30-2010   #275
Re: Project Lex
I still love you.
Old 12-30-2010   #276
Re: Project Lex
You could push it across the finish line...
Old 12-31-2010   #277
Re: Project Lex
Looking good.
You still owe me a 10 second car Spilner.
Old 01-04-2011   #278
Re: Project Lex
Been working with Jordan (2JZ Megasquirt Guru) recently. With phase 1 of the install done, we got my laptop communicating to the MS via TunerStudio. Got some baseline settings put in for logging. So far everything is working, except having a hard time keeping sync with the cam signal below 1600rpm. Once I get that worked out, I will be wiring in the fuel and ignition control (as right now it's hooked up as purely a logging instrument). Once I get that done and a baseline tune running, will be setting up an appointment at DBPerformance for a complete baseline tune on the stock setup.
Huge thanks again to Jordan @ Powersquirt for guiding me through this.
http://powersquirt.com/
Old 01-04-2011   #279
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Project Lex
Stop working on this thing. I'm WAAAYYYY behind.
Old 01-04-2011   #280
Re: Project Lex
Woohoo, got the sync issue worked out. There were a couple jumpers & pots that needed to be changed / adjusted on the MS3 and MS3x boards. Everything is logging perfectly now
Hopefully this weekend I'll wire in the injector & ignition wires, and MS will then be in full control of fuel and ignition, and be just about ready for Shane
FFIM DIY:
http://my.is/forums/f221/diy-kinda-i...alysis-363346/
