Old 01-27-2011   #301
Re: Project Lex
Originally Posted by Andrew7dg View Post
I know you are not the first to do this. The 2jz and the 7m have both been MS by version 1 2 and MS3 (the MS3 is the most interesting to me though. Lots of options and thought put into that standalone) Myself, I am not familiar with MS ing a 2jz but after building a couple for a couple of different cars, it is really easy to understand how any ECU works on any car. My best description is "It is like hooking up a stereo to your tv, dvd, ps3.... There are inputs and outputs plus you must make sure it is plugged in. " Hopefully I am not sounding rude at all when I make comments. Just trying to help a fellow MSer
Don't worry about sounding rude. I'm a newb to MS, so I have lots of learning to do as the most complicated system I've ever used before this was DSMLink
After I asked the question I googled it and found out it does use two vr sensors, one is a 12 tooth wheel and the other is a Top Dead Center trigger so ms knows which one to fire on for sequential injecton. You should be able to tap into it with the MS and stock ECU both in place if the stock wire wasn't shielded, it really doesn't matter if the MS is shielded. Rarely is there noise by the stock ECU. it is usually in the engine bay by the coils.
The way I understood it, the 2jz-ge (non-turbo) uses a 24 tooth nippon style wheel (no missing tooth) with one sensor (NE) for crank position, and a 2nd wheel that has one tooth and two sensors (g1 and g2) for cam position. All within the dizzy. I have the NE signal coming into the tach input on the MS3 card, and the G2 signal coming into the crank input on the MS3x card. Both signals are simply tapped, so both the ECU and the MS are seeing them.
TS is just reporting what MS actually sees and yes the MS is loosing sync, I can even hear it in the video when it misfires.
You don't have the wires for the 12 tooth and TDC switch because if you did, it wouldn't run at all
I don't think I ever questioned if I had them backwards. I'm certain they are hooked up correctly.
My comment is that it has to be down stream somewhere because your stock ECU is also loosing sync. Most often for me when it is loosing sync like that, it is because the builder of the MS soldered something inside the case wrong and so MS looses sync. Tach usually reads just fine besides the dip when it misses.
Your case is different. My guess is that your tach on your dash gets a signal from your stock ECU. So both the stock ECU and MS are receiving a bad signal somewhere down stream from the ECUs. It could be that you have to recheck the solder that you made when you tapped in to the signal cable.
It could be that your VR sensor in the distributor is going out when it idles and can't pick the signal up.
My understanding is that the 2JZ-GE tach signal does not come from the ECU. It's a distributor setup and that I believe somehow provides the tach signal, not the ECU. And after talking with Jordan, he agrees with my thinking. MS is losing sync. When that happens, my ignition output shuts off. That is why you hear the car miss in the video when it loses sync, and that's why the RPM's drop on both the laptop and on the actual car tach. Because it is actually missing, and the rpm's are actually dropping. The sync loss is what is causing all this, so I need to just get that sync issue fixed and that should take care of most of this.
Bah it is easier to hook them up at the same time so shane can give you an optimum tune on the car
Yes when I bring it to shane it will have injectors and timing both hooked up. I was saying I may hook the stock ignition back up as part of my sync issue troubleshooting process.
It is the spark map that usually needs to get tuned on the dyno. if that is dialed in correctly tuning the VE table is something that can be done on the fly most of the times. I ran someone elses tune on my eclipse for sometime
I'm going to have shane do whatever it is he has to, to make the car run as good as new as he can.
I use MS2 as that fits my needs for most 4 cylinders (and works pretty well for V8 also). I modified the MS chip so that it would do 4 cylinder sequential injection with the help of an "adder board"
TS is pretty universal with both. I don't have any need dashboard sorry to say. I usually stick with the standard gauges and fit which ones I need to see on the dash. Looking at the green one with bars gives me a headache but Ricers LOVE it. "hey you have a standalone on your car!" now I need to find a warning flasher or something that says my manifold pressure is too great....
GET THE FULL VERSION OF TUNERS STUDIO, there is a tune as you go option that is not on the free ware. Pay the money it isn't that much and that will help you tune as you drive. It helped me dial in my VE table. (it is really hard to tune with only myself in the car...
Yes I have the full version. I started with the free version, but since I have these sync issues, I decided to get the full version so I can use the trigger/tooth logger function.
Old 01-27-2011   #302
Re: Project Lex
Yesterday I was able to work on the car for about an hour. All I did was pull the carpet back and add some additional electrical tape to the wires I tapped into to ensure no conductors were exposed. The sync problem still remains however My next plan is going to be double checking some settings in TS. If that doesn't fix it, then I am going to double check the ground wire, and maybe see if I can't improve that. Then I will rehook up the stock ignition wire, and see if the sync issue goes away. Then just keep working my way back trying to figure it out...
Old 02-01-2011   #303
Re: Project Lex
Well today got a little bit done. The original vacuum source I was using wasn't very good (kPa value would freeze soon as the TB closed). So I found a different spot and tapped it from there.
Also decided to work on the sync issue as well. I was told to double check the base ignition timing on the car. So I looked up how to do it and went to it. Should be set to 10*. I found mine was sitting at about 12*. Clocked the dizzy and set it up right on 10. Here's a little how to if anyone ever needs to know how to set base timing on a 2JZGE.
SETTING BASE TIMING ON A 2JZGE (1992 SC300)
- Find the diagnostic port in the engine bay, and jumper terminals TE1 and E1 with a paperclip.
- Connect the timing light to the battery, and to plug wire #1
[img][/img]
- The timing marks on the plastic cover will read | 10 | 0 (this is in increments of 5 so it read it as 15 10 5 0 ). With the pins jumpered, you want it set at 10.
- Point the timing light and look for the line on the crank. It should line up at 10. If it does not, there is a single 12mm nut you need to loosen on the distributor. Clock the dizzy until the mark lines up.
- When you're done, tighten the nut back up on the distributor, and check the timing one last time to ensure it didn't budge while tightening the distributor. Remove the jumper. With the jumper removed, you will notice the timing will advance a bit automatically which is normal.
ID:	11282   Click image for larger version
ID:	11283   Click image for larger version
ID:	11285   Click image for larger version
ID:	11286   Click image for larger version
ID:	11288   Click image for larger version
Old 03-08-2011   #304
Re: Project Lex
Well it's been forever since I've updated this. Mainly because there has been nothing to update as life has been quite hectic since the beginning of the year.
Today I finally got some time to continue troubleshooting the sync problem. Put a scope to the Cam and Crank inputs as noise was suspected as being a possible cause of my sync/tach issue. Here's a nice vid. Looks clean to me. It's a 24 tooth (no missing tooth) crank signal, and I have just a single G2 cam signal coming in. You can see pretty clearly that they look pretty clean. You see the single Cam trigger, then 24 Crank signals. I'm no expert but it doesn't look like there's much noise on there at all.
What I do notice is how close the cam trigger is to the crank trigger. From what I understand, you do not want those to line up perfectly. The cam trigger should come in between two of the crank triggers. Maybe that is my issue?
If anyone has any advice, feel free to share! And big thanks to Shane at DB Performance for lending me the scope. Greatly appreciated!!
http://www.youtube.com/watch?v=gs2vCC5x3KY&hd=1
Old 03-10-2011   #305
Re: Project Lex
OK did a little bit of playing today per the advice of some gurus. I played with the Zero Crossing pot, and with the different edge triggering options. See pics below.
BEFORE Adjusting Zero Crossing pot log.
AFTER Adjusting Zero Crossing pot log.
- Zoom to see where the cam trigger falls in comparison to the crank triggers. Ideally it should fall exactly between two of the crank pulses. I played with the different edge options. This pic shows the best combination I could get which is Falling Falling.
So the cam signal is much better now. But I'm still having the same problem. The cam pulse appears to be as steady as can be, so the crank signal has to be the cause of all this. Will continue this battle this weekend and hopefully get this thing working!!
Old 03-11-2011   #306
Re: Project Lex
Wow, seeing you deal with all that makes me feel a little better about the crap I had to go through to get my truck running.
Old 03-11-2011   #307
Re: Project Lex
Ha, there definately is a learning curve, but everyday I'm figuring it out a little more. Hopefully have this worked out this weekend.
Old 03-14-2011   #308
Re: Project Lex
Had a couple minutes to look at some more stuff. In this video I'm reading the raw cam signal (G2) coming in, and am reading the processed cam signal on JP2 pin 18 on the silver MS3 board. In a nutshell MS just takes the sine wave signal, and creates a square wave based on where the raw signal crosses the 0V line. Thanks again Shane for the scope, I wouldn't be able to do any of this if I didn't have it.
http://www.youtube.com/watch?v=t3eBiVhBgWo&hd=1
Old 03-16-2011   #309
Re: Project Lex
All this signal checking crap has finally convinced me to buy my own scope. Big thanks again to Shane for lending me his as it's proving to be a huge help, and helping me learn a ton about how MS works. I'm hoping he'll let me hang onto it for a little bit longer yet until I get the hang of my new scope.
http://www.hobbylab.us/default.aspx
That's what I got. $129 It's a USB based device that you use with your computer (I'll just use it with my little netbook). It's been used by a few of the MS guys and they've all said it works quite well. It's a 2ch Oscope, and a 16ch Logic Analyzer. The software is apparently pretty easy to navigate as well. I heard the probes that come with it leave a little to be desired, so I picked up some better ones off Ebay for $12 shipped.
Someday eventually I'd like to get a true standalone scope w/ 4 channels, but for now this seemed like a great starter unit for a decent price. But in the future, if I could find some old analog Tektronix 4ch sucker for cheap on Craigslist, that'd be cool
Old 03-16-2011   #310
Re: Project Lex
Checked signal at J1 which is the crank square wave. Here's a vid of the crank signal. Was hoping I'd find a smoking gun on this today and be able to work it out with the filtering function in TS, but nothing really caught my eye.
http://www.youtube.com/watch?v=SD4od1097tA&hd=1
After looking at the square waves of both the Crank and Cam, it seems like the correct settings for this in TS would be Rising & Rising.
Starting to run out of ideas here as so far nothing has stood out to me as being an issue thus far. I'm going to take another video comparing the square cam & crank to show how they match up. After that, I really am starting to run out of ideas. I just ordered up a HobbyLab USB scope so I should be able to take some logs with it with the Logic Analyzer function that might be able to tell us more than this old scope meter.
Old 03-16-2011   #311
Re: Project Lex
Is it an ignition or fuel problem, or a problem at the root of both systems? If it could be one or the other but not both, have you thought about working backwards straight from the ignition or injectors?
Old 03-16-2011   #312
Re: Project Lex
I have unhooked the ignition, so the ignition is being run by the stock ECU again, and MS is only controlling the fuel. MS is losing sync, which is all driven off the Cam and Crank position sensors. MS needs to see 24 crank pulses, then 1 cam pulse, then 24, then 1, and that's how it stays 'synced' with the motor. When it loses sync, it shuts off the outputs to be safe (so in this case, fuel) which is why you hear the hesitation. The sync error code I receive is 17 which means something like "wrong amount of crank triggers before seeing the cam trigger". Whether or not it's something in the hardware that is the issue, or a setting in the software, I am really unsure of. Support from the guru's are starting to fade little by little as well which doesn't help.
And here is a vid of the crank vs. cam square waves.
http://www.youtube.com/watch?v=kfUace3pZzM
Old 03-16-2011   #313
Re: Project Lex
OK well just took a wild stab and it seems to be 100 times better, although not completely taken care of. Since earlier some signs were telling me that the crank trigger was the likely cause of this, I decided to enable crank only filtering. I used the Tach Rejection feature, and set it to 30% as that was a value I had seen thrown around in the filtering documentation on here. And what do ya know, the issue seems to have 99% gone away. You'll see in this video that it still lost sync a couple times under WOT, but way better than before. I will play with filtering a little bit more and hopefully be done with this issue.
One thing I did notice was that in the composite log, the crank now shows up as a square wave instead of just a single edge as it did before. No idea what that means however.
http://www.youtube.com/watch?v=EZPwl3fj34I
Old 03-17-2011   #314
Re: Project Lex
Played with the filtering a bit. I have the global filter time now set to 5uS. That basically means, any pulse that is less than 5uS in length gets filtered out. Anything longer than that is considered good and is used. So basically goes off the assumption that good signals are long, and noise is short.
I then set the rejection percentage to 70%. That means that it predicts when it should see the next pulse. So anything that happens within the first 70% of that time gets ignored. For example say it predicts it'll see the next pulse in 100ms, it'll wait for 70ms until it even starts looking for it again. So any noise that is occurring in the first 70ms is completely ignored.
Car is running like a champ!!! Goint to hookup the ignition again and make sure she's running good still. If so, I may start talking to Shane about getting a quick base tune before the turboing begins!!
Old 03-17-2011   #315
Re: Project Lex
^Awesome.
Old 03-17-2011   #316
Speedfreak
Drives: four tires
Re: Project Lex
Bman, the new MS guru.
Old 03-17-2011   #317
95talonracer
95talonracer's Avatar
Re: Project Lex
NICE!! Turbo'd by dyno day?
Amsoil Dealer
Old 03-17-2011   #318
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Project Lex
Glad to hear you sorted it out...was getting worried there for a while. Looked like a tough little cookie of a problem haha.
Old 03-17-2011   #319
Re: Project Lex
Glad you figured it out, cause that shit was way over my head haha!
Old 03-17-2011   #320
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
I understood a lot of it, and I'm glad it was you doing it, not me.
Good work sir.
Originally Posted by Trogdor
