Old 02-14-2011   #301
Re: GheyrodX - bigger, fatter, gheyer!
More:
Old 02-14-2011   #302
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Looking good, that TB is on my to do list. When you throwing yours on the dyno again to see gains?
Old 02-14-2011   #303
cmspaz
Walls need hugs too
cmspaz's Avatar
You sir need to stop posting porn without NSFW tags.
Originally Posted by Trogdor
Old 02-14-2011   #304
The plan is to dyno every step along the way:
-baseline dyno
-dyno with ported exhaust manifold
-dyno with ported IM/TB
-retune
Old 02-14-2011   #305
Murlo26
Murlo26's Avatar
-baseline dyno
-retune
Nice! But...when you doing this? Just curious
Old 02-14-2011   #306
Sex. I think I want this setup on my car. I had dreams of crazy 75mm TB, mega rev10 manifold and massive LICP but fuck, the simplicity of it is just a thing of beauty. Jealous!
Old 02-14-2011   #307
LOL he *just* got them! Look at the schedule, it'll probably be a few weeks I'm sure!
Old 02-14-2011   #308
Murlo26
Murlo26's Avatar
Knowing him he had a date set with Cobb weeks ago, lol. I am guessing he has a plan already
Old 02-15-2011   #309
Rmondoh
Minority of MitsuStyle
Rmondoh's Avatar
Drives: '08 OBP Evo X GSR SSS (Deadmau5X)
Send a message via AIM to Rmondoh Send a message via MSN to Rmondoh Send a message via Yahoo to Rmondoh
The plan WAS to have Cobb do it all as they expressed interest in wanting to do back to back tests to see the gains of each change. Kracka went to talk with the manager over at Cobb this past Saturday and basically no good deal was worked out. I believe Cobb wanted to charge us for 4 hours of labor per manifold. Kracka didn't like that so much so we're going to be installing each piece ourselves probably over the next month or two. As he scheduled out, we plan to have a baseline run first. Depending on whether SPC (our local powder coater) can get our exhaust manifolds done by Friday, that's probably the first thing we'll tackle. If they aren't done, then we'll do the intake manifold and throttle body instead and finish with the exhaust manifold the following week. Then we'll do it all again with my car and see if the results are consistent.
That's the plan...at least for now.
08 Evo X GSR - Octane Blue Pearl
Cobb Stg1 AMS 93 OTS: 305hp 291tq 20.6psi
Cobb Stg1 93 Pro: 317hp 322tq 24.5psi
Cobb Stg2 AMS 93 OTS: 315hp 323tq 23psi (LWG map)
Cobb Stg2 93 Pro: 343hp 358tq 26psi
Cobb Stg2 93 Pro: 355hp 361tq 26.4psi (ported stuff)
Rmondoh is offline   Reply With Quote
Old 02-15-2011   #310
Yup, Mondo pretty much laid things out!
I'm hoping to baseline this Thurs or Fri evening then get the exhaust manifold installed Saturday morning to be back on the dyno Saturday afternoon. If that all goes as planned then I'd like to start attacking the IM/TB the following Saturday. If, and that's a big if, everything goes smoothly and according to my best-case-scenario plan then testing/tuning will all be completed before the end of the month.
Old 02-16-2011   #311
Transfer case started howling and puked it's fluid all over the road last night.
Old 02-16-2011   #312
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
good luck! hopefully it turns out better than shawns.
Old 02-16-2011   #313
OMG, sorry to hear.
Old 02-16-2011   #314
Sad sight:
The car is currently on the lift getting inspected.
Old 02-16-2011   #315
Murlo26
Murlo26's Avatar
Let us know the outcome, I really hope you get some mitsu warranty love.
http://www.evoxforums.com/forums/sho...686#post703686
Wicked white got his Tcase replaced and he had an FPblack setup...Good luck.
Old 02-16-2011   #316
Thanks, me too. I am really trying to stay positive about this and hoping warranty takes care of me.
Old 02-16-2011   #317
Murlo26
Murlo26's Avatar
Check my previous post, I edited it, it will give you some hope.
Old 02-16-2011   #318
Rmondoh
Rmondoh's Avatar
If anyone can get it fixed under warranty, it's Don. Don is the man you want on your side. Hopefully he will pull through for you Chris.
Old 02-16-2011   #319
Eby (Don's service manager) confirmed the transfer case was overfilled with fluid and documented the fill and drain were untouched with factory paint seal intact. He also said this is the 2nd they've seen like this this week.
Old 02-16-2011   #320
Recall time? Glad you're getting it fixed under warranty.
