Old 02-17-2011   #1
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
WTF happened?
well i got my car back from primo the otherday with the trasfercase seal and yoke/ujoint replaced, and my new exhaust i love it only issue is while driving to work today i went to accel thur the intersection and nothing happend..
It was in gear, and clutch pedal all the way out but nothing happend. I looked at all the easy stuff, slave cyl, master cyl, they both work fine, shifter cables the move fine, it goes into gear but when you let out the clutch nothing happens it has a brand new clutch and there is no burning clutch smell at all.
I feel like its something inside of the tranny its self, but that would lead me to think i would atleast have one gear that works but none do, idk how thes trannys work on the inside so idk let me know what you think it is
thanks,
Ryan
Originally Posted by 311evo
Old 02-17-2011   #2
Re: WTF happened?
So does the car rev like it's in neutral? Please explain "nothing happens".
Old 02-17-2011   #3
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
yes it just free revs like its in neutral
Old 02-17-2011   #4
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
yes i can start the car in gear i can shift into "gear" without pushing the clutch in
Old 02-17-2011   #5
93gtpeater
Drives: cbr 1000rr repsol
Re: WTF happened?
Can you shift it when its running with out pushing the clutch in? How does your pedal feel? You sure your fork is moving?
Old 02-17-2011   #6
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
possible, i think i would have hurd this though there are no strange noises at all.. ill see if i cant take off that plat on the bottom of the tranny and look into the bellhousing to see if i can see anything
Old 02-17-2011   #7
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
yes i can
like it always has
100% positive
Old 02-17-2011   #8
Re: WTF happened?
Maybe it pumped up and isn't allowing the clutch to engage. Try adjusting your pedal to grab lower, towards the firewall.
Old 02-17-2011   #9
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
tried pumping it, but its as if there is no clutch i think the pressure plate bolts backed out the peadle it adjusted to grab as low as possible
Old 02-17-2011   #10
Re: WTF happened?
No, I meant sometimes after a clutch install the pedal grab point can creep up to the top, but if you've adjusted it as low as it can go then nevermind. Time to take off the transmission.
Old 02-17-2011   #11
Re: WTF happened?
Remove the tranny, and the problem should become much more apparent.
Old 02-17-2011   #12
Re: WTF happened?
Have you checked your shifter cables at the tranny?
Did they disconnect something?
Old 02-17-2011   #13
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
primo is coming to get it tomorrow, if its install related they will warrenty i will let you know what the find is
Old 02-17-2011   #14
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
yup just checked them they are connected
Old 02-17-2011   #15
cmspaz
cmspaz's Avatar
Re: WTF happened?
Did you make sure they're moving at the tranny, too?
cmspaz is online now   Reply With Quote
Old 02-17-2011   #16
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
yes i did
Old 02-18-2011   #17
Re: WTF happened?
Sounds like a clutch disc failure.
Old 02-18-2011   #18
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
yes it does but you would thik i would have smelled some clutch
Old 02-18-2011   #19
Re: WTF happened?
Does it make any kind of rattling noises? I would think if it was a disc failure or some other kind of mechanical issue it would be making all kinds of noise. Sounds to me like maybe the piston in your slave jammed at full extension?
Old 02-19-2011   #20
19TsiAwd90
19TsiAwd90's Avatar
Re: WTF happened?
no noises at all, no clutch smell pedal feels fine... slaves rod moves with no issues, primo has the car atm and they are looking at it, we will see lol im fudging boggled on what the heck it could be..
me and mike thought maybe a cracked clutch hub but idk that would make lots of noise.. we will see i guess
