Old 03-08-2011   #41
golden763
Drives: 95talon tsi
Re: 95 Tsi Awd PPPPPProject
I on my phone so. It does that t9 crap where it spells stuff how ever it wants lol
Old 03-09-2011   #42
golden763
Drives: 95talon tsi
Ok so here my part list if ya got any of this and is close let me no lol
radiator and upper mounts
stock shifter
knock sensor
little clip that holds the shifter cable on the tranny
oil press sensor
if any body has any of this would b the biggest help
Old 03-09-2011   #43
I have a stock shifter base in good condition.
Old 03-09-2011   #44
golden763
Drives: 95talon tsi
I just need the handle or Watever lol how much pm me and i can give u a call
Old 03-09-2011   #45
I'm glad to see you can at least work on your own car. Yes, it sucks when shit doesn't go right. Keep on trucking, and eventually it will all be worth it.
Old 03-13-2011   #46
golden763
Drives: 95talon tsi
Sov here the dealio got it all done and put it back together amd went to start it and so here the story turns over kinda slow and o yea I bypassed the relay behind the radio with a wire from the start wire straigjt to the starter so turns over gets gas cause it stinks my whole garage up like it and pullef the plugs and gets spark on allllllllll so no idea could I have the injector plugs mixed up would it do that it just turns o9er and every once and a while pops out the intake hmmmm I wounder wat it could b
Old 03-13-2011   #47
wat?
Old 03-13-2011   #48
golden763
Drives: 95talon tsi
Sorry about my grammer,puncuation,spelling etc. all I got it my phone so I apologize to all
Old 03-13-2011   #49
golden763
Drives: 95talon tsi
Ok ill write slower lol got the car all back together today. Went to start,it and all it does is pop out the exhaust every now and than gets spark and gas. I pulled all and checked and also gets gas cause I can smell it. If the injector plugs were on wrong would it cause problems? Also the coil mounted to the strut tower would I have to run them in backwards like 3214 or not? Any help would b very grateful again sorry bout puncuation
Old 03-13-2011   #50
golden763
Drives: 95talon tsi
Ok so on the exhaust cam gear there two marks which one should I use or should the dowels on the cams both be pointing up or opposite
Old 03-13-2011   #51
When all the timing marks line up on everything, the cam dowels should be pointing up.
Old 03-13-2011   #52
Check your ignition base timing.
Old 03-13-2011   #53
golden763
Drives: 95talon tsi
Uhhhh ohhhhh poop I made a opppps lol
Old 03-13-2011   #54
Uh Oh meaning you alligned the cam gears wrong? If so, you better cross your fingers you didn't bend any valves.
And to answer your questions above, yes if you have the injectors plugged in wrong, and the plug wires hooked up wrong, then yes of course that would cause problems lol.
Old 03-14-2011   #55
golden763
Drives: 95talon tsi
Ya the exhaust cam is 180 off. : / ugh lol and I dunno harness is really kinda hacked so its hard with the injector deal. With it had a sbc lol I got many of them lol
Old 03-14-2011   #56
1999Gst
Drives: 1999 Eclipse,
hey who ever owns the car now, wanna tell me how much vibration u have from the front moter mount be welded?? im thinking about doing the same thing.
Old 03-19-2011   #57
golden763
Drives: 95talon tsi
To b honest I dont think its bad at all
Old 03-22-2011   #58
golden763
Drives: 95talon tsi
Ok so been driving the car around a lil lately. I think I screwed up on hooking up the bov up? Where and I suplosed to hook up the vacumm line for it?
Old 03-25-2011   #59
golden763
Drives: 95talon tsi
So heres a good question been drivin my car around a lil and when it warms up it starts blowing air out the blow off valve just sits there blowing air out. Also where should the blow off valve be hooked up to any help would be very appreciated
Old 03-26-2011   #60
golden763
Drives: 95talon tsi
So everyone wanna get my mustang done how much do u all think this car is worth lol
