Old 03-16-2011   #81
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
They weren't crazy expensive for buying new. And your welcome to come over anytime.
Old 03-16-2011   #82
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Jim you can help me run my boost-a-pump! I received it today along with n AEM wideband. Thanks alot Andrew.
Old 03-25-2011   #83
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Dropped off some stuff @ Primo today. Fuelrail, FPR, and blinged oil cap. Hoping for a blacker engine bay.
Old 03-25-2011   #84
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: My 95 talon
they do great work, they wont let you down!
Originally Posted by 311evo
Old 05-15-2011   #85
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: My 95 talon
Lets see some progress!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-15-2011   #86
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: My 95 talon
I think he is getting it tuned this week.
Old 05-15-2011   #87
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Yeah tuning on Tuesday! Just been crazy busy. I'll update when I get back from DB.
Old 05-15-2011   #88
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Gauges installed and wired up!
Old 05-15-2011   #89
Re: My 95 talon
Looks clean!
Old 05-15-2011   #90
Re: My 95 talon
Love the gauge setup!
Old 05-15-2011   #91
TalonFiero
moonshine power
TalonFiero's Avatar
Re: My 95 talon
Mans been busy! Looking good!
Old 05-16-2011   #92
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Also did black dash top/door inserts/and switches. Ill finish filling the area by the shifter once its back from Shane! Im pleased with how the interior turned out, and glad I grabbed matching gauges instead of just buying sending units!
Thanks guys.
Old 05-16-2011   #93
GsXtUrBo98
GsXtUrBo98's Avatar
Re: My 95 talon
Good luck tomorrow at DB! let us know how she does!
98 GSX (built)
03 BBY EVO dd
Old 05-18-2011   #94
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Things didn't go as planned. I missed my appt. at DB due to stupid me ordering the wrong NGK br7es, and not the brp7es. Yes theres a diffrence, but i didnt know till I googled it.
So threw in the right plugs, acted a little better but through a p0300 (multiple misfire) and now need to trouble shoot from there.
Plans are to
Buy new wires a new set of BRP7ES. Then see if that fixes anything.
If not Ill check coil and power transistor. I am geting spark and fuel across all 4. So that rules out a little.
Old 05-18-2011   #95
Re: My 95 talon
I think you mean BPR7ES?
Old 05-18-2011   #96
Re: My 95 talon
That sucks about the plugs!
My old car used to throw that multiple misfire code when I first got it running. I think all I did was check the little "don't check for misfire code" button in dsmlink and it solved all my problems. Maybe something to look at?
Old 05-18-2011   #97
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: My 95 talon
Scheides as long as the P is in there I'm good. I think the misfire isn't checked in link o look again.
Old 05-18-2011   #98
Re: My 95 talon
You get that code with a 6-bolt in a 2G. You just turn it off in Link.
Old 05-18-2011   #99
Re: My 95 talon
The difference in those plugs is just how far the tip protrudes into the combustion chamber right? We ran both in a locals car last week and it didn't make a difference. The gap made a bigger difference than the plug did.
Old 05-18-2011   #100
Re: My 95 talon
Yea, the BR7ES are typically a nitrous plug. They will foul out easier than normal projected tip plug.
