Old 05-19-2011   #661
Re: 91 Galant VR4
I was going to use a nice turbo XS MBC, but the cheap DB one came threw again for me. Some day I want to put in a BCS for the AEM to control stuff.
Old 05-20-2011   #662
Re: 91 Galant VR4
Sweetness.
Old 05-20-2011   #663
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: 91 Galant VR4
Are the shakedown passes happenening tomorrow at grove creek? If so what time, I really wanna be there.
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 05-20-2011   #664
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Re: 91 Galant VR4
Jesus man, I was there right after it made t he 806 and I was blown away. I knew this car was gonna pwn but I that's damn good power. I would love a ride in it sometime
2010 Evo X GSR
1997 Subaru GC8 STi
Old 05-21-2011   #665
Re: 91 Galant VR4
No 60' testing is pushed off to next weekend on the 28th at Grove creek due to weather, then I hope to get back to Rock falls on June 4th to back up the 60' testing then try for some full pass testing.
If you go by the tried and true domestic fail ET and MPH snake math calculations the car could and I mean COULD run in the 8's at 157mph, but I think it has a 9.2-9.4@ 155mph in it at this power level.
Then if the 60' holds out to the head lifting power or 800+ and I have 26.5" tall slicks the car could run in the mid 8's at 165-170mph.
Old 05-21-2011   #666
Re: 91 Galant VR4
Snake math is most impressive. I predict 7's.
Old 05-21-2011   #667
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: 91 Galant VR4
Damn your making me want to change my weekend plans. and test my car that weekend too. I really want to see you car make some passes.
11.35 @ 120mph
Old 05-23-2011   #668
Re: 91 Galant VR4
Good luck this weekend at the track!
Old 05-25-2011   #669
Re: 91 Galant VR4
I took the car out for a drive tonight. Its making the 39psi just fine, intake air temps were around 75-80deg, and it only took just under 6 seconds to go from 6600rpm in 3rd to 9000rpm in 4th.
Old 05-25-2011   #670
OMFGeofffff
OMFGeofffff's Avatar
Drives: '90 Talon Tsi AWD
Re: 91 Galant VR4
I wanna ride in that bish.
OMFGeofffff is offline   Reply With Quote
Old 05-27-2011   #671
Re: 91 Galant VR4
I just added 2 -8 lines from the valve cover to my catch can thing. Then I added a 1.5" inlet breather filter with chrome cover.
This should help with some of the crank pressure I was seeing on the dyno and my test drive.
I still plan to head to Grove Creek this saturday for 60' testing if its not raining, we will see.
Old 05-27-2011   #672
Re: 91 Galant VR4
How did you know you were seeing excess crank pressure? Just dipstick coming out, or do you have a way to actually log/measure it?
Old 05-27-2011   #673
Re: 91 Galant VR4
I do have another map sensor I was going to put in the crank case and see what the pressure is, but oil was blowing out the dip stick tube.
Old 05-27-2011   #674
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: 91 Galant VR4
What time do races start at grove creek tomorrow? the evo is down for a new clutch , but i plan on being there anyhow.
Shane Tune@ DB
Old 05-27-2011   #675
Re: 91 Galant VR4
There test time is from 9am to 4pm. I am going to check out the weather yet again. If its not raining in the AM I am going.
Old 05-27-2011   #676
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: 91 Galant VR4
Nice looking forward to seeing this thing in action
- Kody
Shane Tune@ DB
Old 05-28-2011   #677
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: 91 Galant VR4
Where are you? Its beautiful here! I'm hope I'm blind and just havnt seen you yet.
Shane Tune@ DB
Old 05-28-2011   #678
Re: 91 Galant VR4
I showed up around 10:10am or something. I did get 1 run in before the car decided to break something. So it has gone 3 for 3, goes to the track and breaks something.
edit: I forgot to say it was the water pump gasket that pushed out the bottom of the water pump, wtf.
But I did run the 2nd best 60' with the car.
RT .641
60' 1.785
330 5.174
ET 9.017
MPH 59.14
This was at Grove Creek 1/8 mile. And until I have full slicks and better suspension I do not think I would go back.
I launched somewhere around 6k and hit 2nd gear and it went straight to revlimiter sping so I shut down and coasted.
I would guess it hit revlimiter spining in 1st about 3 times, when I get the laptop to work again I will down load the log.
So my next plan is to play with the 2 step settings and try to leave the line at 5500rpm or so with 10-13psi of boost.
Old 05-28-2011   #679
95talonracer
95talonracer's Avatar
Re: 91 Galant VR4
Dam let us know when you figure out what broke.
Amsoil Dealer
Old 05-29-2011   #680
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: 91 Galant VR4
Its was the waterpump gasket that let go.
Shane Tune@ DB
