Old 05-30-2011   #901
Re: beaterX project thread
Took some time today to play with teh beater. Here's the new injector adapter on the left, old one on the right. See the two kinda 'wings' on the side on the new one and not on the old one? That is what helps keep it straight in the plug and not necessitate zip tie racing :P Also the 'hook' on the top is bigger so it seems to hold more snug. The EV1 connector (dsm/ct9a evo-style) is revised as well. It is more sold too, although seating them and getting them off is tougher as it is tighter:
Here's the new spacer setup installed. The one end of the fitting is machined a bit so it slides into the fuel rail or IM properly, and the outside donut (see previous pictures) helps keep it flat and properly supported. The injectors fit absolutely *perfect* now, I am SO HAPPY! These things are fidgity when installing and I always drop them, so I went ahead and put a few little dabs of RTV inbetween the three pieces to just keep them from falling apart on install (and hopefully uninstall whenever that day comes):
Cobb BOV installed, that took all of 3 minutes! Only item of note is that the boost source nipple faces 6 o'clock and the stocker points to around 10:30 so I had to adjust the hose for that:
Driving impressions? I am *really* impressed so far, even turning it about 3/4 to full tight (I think) it is stock-like driveability on the freeway and around town and it seems to hold boost just fine, I'll be reviewing logs this week.
After everything under the hood was buttoned up, I decided to yank the fuel hanger. Spaz got me some 30r10 hose and I had to see if it would fit.
First item of note, the filter/screen is bent but NOT kinked, so no fuel blockage there:
Then I removed the bendy hose and test fit the 30r10...bad news. Even if it was long enough it just wants to fold over on itself once the pump is where it would be in the tank. Boo. Really need the cobb-style S-shaped fuel line for this I think...maybe it wouldn't get kinked and I guestimated placement wrong...but still it is close and it wants to kink flat.
So back in with the bendy-straw hose, I routed it more smoothly this time:
Notice how it doesn't get kinked when the top is compressed as it would be in the tank:
Also took apart the little return filter that lomker linked to in his thread, mine is debris-free but I can see why people might want to mod that stuff, its like a needle-hole!
Back together it runs like a champ! I even put the engine cover back on, I am officially done messing around under the hood for a while.
Originally Posted by mlomker View Post
I offered to let scheides test the Jays 340 pump. Not sure if it's enough difference or not.
I just need to figure out how to rewire the stock plug for it and I'm all over it. Do the pins on the stock plug pull out easy, or did you have yours hardwired?
Also noted the guy from evomn.net who simply re-wired his Jays 340 pump and is using the stock FPR....tempting to say the least!
Old 05-31-2011   #902
mlomker
*Resting In Peace*
mlomker's Avatar
Interestingly enough, I got everything you could need on hand...a relay for a rewire, the Jays pump, and a 40amp BAP.
Old 05-31-2011   #903
Ooooh, right, now that you have the new biggie pump in you won't need the BAP anymore? Sounds like we need to team up for a weekend on each other's cars
Old 06-01-2011   #904
Oops!
Old 06-01-2011   #905
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Oh really? Lomkers old one?
Old 06-01-2011   #906
Nah, he wants to hang onto his for a while and I don't blame him. I wanted pretty badly to put this off and just enjoy the car as-is but between the new BOV causing the car to lean out even quicker and some bday money I decided to just pull the trigger and get it over with. I really wasn't planning on spending more money on the car right now but I think everyone has been in this position.
As much as it sucks (hehe) I'll be happy to have the fuel system done and get the car tuned and ready for MAP Proving Grounds!
Old 06-07-2011   #907
Took some long drives (with plenty of boost) this weekend to Northfield (college reunion) and then Wilmar (helped Kody reinstall his tranny), the car got 18.4mpg. Not bad I say!
In other news, BAP installed. Here's the package. Lots of wires but really the install is dead simple.
Goes inline with the power line to the pump:
And mounted in the trunk, I used a stock bracket, a big hose clamp, and some fuel line for a nice soft but secure mount:
All the wires heat shrink wrapped and sealed spade connectors for easy reversion if need be. I had planned on replacing the rheostat dial that lets you run stock voltage or up to 17.5v with a simple resister setup. Dan @DB says that is the only fault with these things, the dial itself dies after a while, so they usually just hardwire them to max voltage. I thought I'd go easy on the pump and use a 3.3k or 1.8k resister and one of these nice DIY RCA plugs, maybe run it at 15 or 16v:
But I did hook up the dial for initial testing, and I set it right in the middle. I didn't measure, but this should be around 15.75v to the pump. I just turned the boost up and let'r rip. It is not the most beautiful boost curve, but it doesn't matter, I have more fuel now
Again, ignore spool-up, these were started at different RPM. My main concern is 6000+rpm where boost is now 2-3psi higher and AFRs are about the same. YAY!
I am still pretty much maxing this setup out so I think I'm going to just crank the BAP to max and let'r buck. I have an appointment with Shane @ DB next Wednesday...
Old 06-07-2011   #908
woo
Old 06-07-2011   #909
I can first hand attest to those voltage controllers going bad over time. My old car would have a very weird afr curve then go super lean up top, ripped out that controller and hardwired the two wires together and fixed the issue.
Good luck with it!
Old 06-07-2011   #910
Good luck with it!
Cool, thanks man! I basically have it hooked up for testing purposes and then it'll get the heave-ho. It's not hard to imagine it failing over time, it is light as hell and does not feel very substantial. Not the kind of part that belongs in a car, esp hooked up to the BAP itself which is beefy and tough!
Old 06-07-2011   #911
Looking forward to updates! Sooooo, 430? 440whp-ish?
Old 06-07-2011   #912
mlomker
*Resting In Peace*
mlomker's Avatar
430? 440whp-ish?
460 wouldn't surprise me. I did 450 but I'm conservative with boost and my motor has low compression.
Old 06-07-2011   #913
Oh snaps. Well shit might as well crank it to 11 and shoot for 500!!
Old 06-07-2011   #914
Awesome. With the BAP going inline with the fuel pump for power is there any worry about either pump lacking voltage? I would have expected it to need to be hard wired.
Old 06-07-2011   #915
mlomker
*Resting In Peace*
mlomker's Avatar
I couldn't get the BAP to work predictably when wired inline. My suspicion is that it doesn't like the dual-voltage that comes from the car. I used the wire from the car to trip a Bosch relay so it was fed from the battery. The BAP can also draw some crazy current to maintain the higher voltage and the stock wiring didn't look that confidence inspiring to me.
Old 06-07-2011   #916
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Oh snaps, can't wait for the numbers!
ლ(ಠ益ಠლ)
Old 06-07-2011   #917
Murlo26
Murlo26's Avatar
500 is awfully tough for a stock frame on the X...the black barely gets that, but I think 450-460 is the area he could see if everything works great.
Great work though Scheides, can't wait to see your results...I will need another ride!
Old 06-07-2011   #918
Right around 430 is all I want, that's what my evo8 had and I was very happy with it. If it makes more, then well...we'll just call it gravy
I hear ya, I thought about it quite a bit but half the reason I bought the BAP was so I could maintain the stock dual voltage setup. Now I have a tri-voltage setup! 8-14-17.5 Down the road I might look into a FPR setup and see about eliminating other restrictions in the fuel system and then rewire it as you described. It may not be needed now but there's still plenty more mods to do on this thing--ported IM/TB, bigger cams, bigger turbo....who knows what the future holds!
Old 06-07-2011   #919
mlomker
*Resting In Peace*
mlomker's Avatar
Right-o, I forgot about the return issue since I wasn't on the stock hanger at that time. I was just annoyed that it couldn't be tested at idle (it can't make the leap from 9->17volts) so I rewired it.
Old 06-07-2011   #920
380
