Old 07-15-2011   #281
Re: GsXtUrBo98's 2G project thread
Nice job man! I know nate was having problems with his alternator when he was tuned before Proving Grounds....he replaced it and found that he had been running ~11.8v before and now a full 14v....his AFRs were way rich (fuel pump pumping more) to the point that he was having ignition breakup. I guess what I'm saying is, check your grounds, check your alternator, and enjoy the car!
That isn't a DSM power curve man I swear, power just goes up up up!
Old 07-15-2011   #282
Nice work.
Old 07-17-2011   #283
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Might as well update this too. I went to the import vs. domestic race in Brainerd this weekend and ran a poor time of 12.4 @ 116 with a 1.7 60'.. While I was racing I broke a drivers side rear axle.. My buddy has videos of some of my passes and I ran against Mike in a few of them. I'm going to try and get his video camera from him and get the videos up.
I was getting locked out of 3rd gear and couldn't get into 2nd fast enough and was bogging down. I'm not used to this kind of power yet and need to get better at launching my car... I should have no problems getting into the low 11's with it but like I said before its driver error.
I'm going to post up a video of the damage soon but I don't have a socket big enough to get the axle out yet as my dads buddy has the big socket set...
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-17-2011   #284
GsXtUrBo98
GsXtUrBo98's Avatar
http://www.youtube.com/watch?v=TQXHH0rf_aI
98 GSX (built)
03 BBY EVO dd
Old 07-17-2011   #285
blackawdtsi
Drives: 2G DSM
I see your wobble and raise you:
http://www.youtube.com/watch?v=YAn1L...eature=related
Old 07-17-2011   #286
95talonracer
95talonracer's Avatar
You use NLTS? What rpm is your launch control set at?
Amsoil Dealer
Old 07-17-2011   #287
GsXtUrBo98
GsXtUrBo98's Avatar
Not my best run but my first one on the setup
http://www.youtube.com/watch?v=l486AS0CID0
I did not use NLTS.. I know I sould have but when I was going to turn after the run I broke...
98 GSX (built)
03 BBY EVO dd
Old 07-18-2011   #288
Wow! Great job Chris! Happy to see everything come together for you
You car should be a low 11 second car EASY.
Old 07-27-2011   #289
GsXtUrBo98
GsXtUrBo98's Avatar
Some pictures of the broken axle. I'm not going to take it apart quite yet because I'm going to take it to a shop first and let them deal with everything.
ID:	11895   Click image for larger version
98 GSX (built)
03 BBY EVO dd
Old 07-28-2011   #290
Post a dyno graph!
Old 07-28-2011   #291
GsXtUrBo98
GsXtUrBo98's Avatar
Post 273 has dyno graphs!
98 GSX (built)
03 BBY EVO dd
Old 07-29-2011   #292
Get the axel fixed?
Old 07-29-2011   #293
GsXtUrBo98
GsXtUrBo98's Avatar
I'm gonna go to proven force on Monday or Tuesday.
98 GSX (built)
03 BBY EVO dd
Old 08-07-2011   #294
GsXtUrBo98
GsXtUrBo98's Avatar
Ok so, I went to proven force and they took it apart to tell me that the axle is F*&KED... I figured that so today I ordered 2 of these!
http://www.thedsmgraveyard.com/produ...r2gaxlelsd.htm
I'm only going to do the one for now so that I can drive my car. I'm affraid about the axle being frozen in the hub and more problems so I will be swapping out he other side this winter.
Hopefully no more snapping axles for me
98 GSX (built)
03 BBY EVO dd
Old 08-07-2011   #295
mike55112
mike55112's Avatar
Drives: 04 evo
Do them both at the same time.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 08-07-2011   #296
Might as well try WMD do them both at the same time. Then you only lose fluid once
Seem like nice axles!
Old 08-07-2011   #297
GsXtUrBo98
GsXtUrBo98's Avatar
^ no because the rear is elevated the fluid isn't coming out.. so no fluid loss on taking the one out
98 GSX (built)
03 BBY EVO dd
Old 08-07-2011   #298
Fluid is cheap, fix the broken one and rip it! Back left one is the most common to break IIRC, so just get it back on the road--summer is almost over!
Old 08-07-2011   #299
GsXtUrBo98
GsXtUrBo98's Avatar
My thoughts exactly!
98 GSX (built)
03 BBY EVO dd
Old 08-11-2011   #300
GsXtUrBo98
GsXtUrBo98's Avatar
Got both of my axles in the mail today! dropped off the one at proven force to swap the inner cup from the old one on to the new one then hopefully I can pick it up after work tomorrow and have my car on the road this weekend!
98 GSX (built)
03 BBY EVO dd
