Old 08-31-2011   #541
95talonracer
95talonracer's Avatar
Re: Project Lex
When i was doing alot of reading for my car I came across something online that may help your tuning. I think your MS has a map sensor built into the box correct? So this means that you have to run a vacuum line from the engine to the MS ecu? People were saying regarding tuning like that witht he supras that it is better if you either plum a hard line for most of the run from the intake to the ecu or have the map sensor as close to the intake as possible. Can you run an external map sensor and input it into MS to work the same as the internal one?
Amsoil Dealer
Old 08-31-2011   #542
Re: Project Lex
Not sure. But I have no desire to run an external MAP sensor to be honest. It means I have to drill/tap a sensor into the intake, then run all the wires for that. I personally love the idea that I do not have to do that, and simply just need to run a vacuum line to the box.
FYI my setup actually has 2 MAP sensors, 1 which is hooked to the intake via a vacuum line, and the other just open to the atmosphere, that way it can correct for barometric differences, which is pretty sweet I think.
Old 09-06-2011   #543
Re: Project Lex
Hit the dyno today, went much better this time around. Dyno video with results will be posted in the next day or so :P Here's some teaser pics:
Old 09-06-2011   #544
Re: Project Lex
Do like!! Dew want :drool:
Old 09-06-2011   #545
Re: Project Lex
380? Or 650? Looks awesome man!
Old 09-07-2011   #546
Re: Project Lex
Woooooot!!!
Old 09-07-2011   #547
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Project Lex
So where are the graphs!?
Old 09-07-2011   #548
Re: Project Lex
Alright so here's a rundown of the dyno.
To start from the beginning, I dyno'd a week ago. Got all the cruising type tuning done, car is running and starting great. But couldn't do any WOT tuning because of what turned out to be a bad coil. With the coil replaced, I returned to the dyno yesterday for the WOT tuning.
You'll see the first run was at about 339hp. Shane did his thing, 2nd run we were already up nearly 50hp. A handful of more pulls and we stopped it at 406hp which far exceeded my expectations (I was thinking more like 360). This is on straight WG boost, no boost controller. You can see how soft boost comes on with this WG. I thought it was a 1bar spring but maybe it's more like a 10lb. Will have to look into swapping that out this winter.
I can't thank Shane enough, I'm very happy with the entire experience (as always). One thing you'll notice is a random blip in the curve at around 3500rpm. It would occasionally miss at that spot very slightly. Not exactly sure why but not that worried about it either.
So I've attached the 3 charts (HP vs. Boost vs. TQ vs. AFR). Creeps up to about 12psi at the end.
Also attached is a little video. Thanks to Kerry for taking some good footage at the dyno, enjoy!!
http://www.youtube.com/watch?v=cRN1QyANeS8&hd=1
Old 09-07-2011   #549
Re: Project Lex
Nice numbers! Thing must be fun on the street
Old 09-07-2011   #550
Re: Project Lex
Awesome car and great job. You've put a few hours into this project eh?
Old 09-07-2011   #551
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Project Lex
nice work B-Man!
Check your logs for a trigger wheel sync error at 3500RPM.... might be causing the miss.
-Sebastian Vettel
Old 09-07-2011   #552
Re: Project Lex
Thanks all. There is no sync error at that point, one of the first things we looked at. I was talking with my Megasquirt buddy down in FL, he tuned an SC300 yesterday with the exact same symptom. He said he messed with timing and was eventually able to get it to go away.
Old 09-07-2011   #553
Re: Project Lex
imp:
6 guests are checking this beast out!!
Old 09-07-2011   #554
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Project Lex
Ok, good... those errors can be pesky. I've been fighting sync issues with a 4age all last week (ms2) *pulling hair out*
Look forward to seeing her!
-Sebastian Vettel
Old 09-07-2011   #555
Re: Project Lex
lol, if you read back like 15 pages, you'll see my sync error nightmare I went through as well Finally got it 99.9% gone using the filtering in TunerStudio.
Old 09-07-2011   #556
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
Sounds like a jet in the video! Can't wait to see this in person again.
Originally Posted by Trogdor
Old 09-07-2011   #557
Re: Project Lex
Woottastic! The exhaust is way too quiet though, needs moar roar!
Old 09-07-2011   #558
Re: Project Lex
Lolz, funny you say that, because I was just thinking how it needs 1 more muffler
Old 09-07-2011   #559
Re: Project Lex
Excellent results.
Old 09-07-2011   #560
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Project Lex
Looks and sounds badd ass. Better get it out to the track.
11.35 @ 120mph
