Old 12-21-2011   #61
Re: after 10 years its coming back to life
some parts showed up the other day. 1000cc injectors I got them in a trade. hts 45 and 90 coupler. just need the 45 and they were new on ebay together and I ended up getting them cheaper than just buying a 45 coupler. Also stm s.s. full clutch line it was the only black fri thing I bought.
got the boost,oil gauges hooked up and the aem wide band hooked up.
ran the oil line through a pair of stock holes in the car
I had some extra 3in pipe and 3in couplers laying around so I made a extra pipe to make a cold air intake for the car. It fits though the stock smic hole
got the broken bolt out of the tranny so I could mount the shifter cable bracket and get them on. After I got them on and the speed sensor in I got the upper piping on the car.
It is getting really close now
Old 12-21-2011   #62
Maybe I just missed it, but what are you using for airflow metering? Speed density? I'm glad to see this thing coming together!
Old 12-21-2011   #63
it will be on SD. The upper pipe had the ITA in it already.
just need to sell some parts to buy link for it and the SD cable
Old 12-21-2011   #64
Sweet!
Old 12-22-2011   #65
You'd just need a map sensor and the wiring wasn't that hard from what I remember. I just bought a iat pigtail from napa for a few bucks and wired it up myself.
Looks good though! Can't wait to see it running around this summer
Old 12-22-2011   #66
I have a cable for a maft set up to run it in the car so I think I will just cut it up to make the SD cable. It would be just like the one dsm link sells.
Also today I took the intake out,sanded it down and painted it. It is now hanging down stairs in front of the fire place drying Will get pics in the mooring.
Old 12-23-2011   #67
johnson
johnson's Avatar
Drives: 90mitsu
Lets get this bad boy up n runnin!
Old 12-23-2011   #68
painted the intake pipe in the basement shop last night and used the gas fire place to get it to cure between coats. also cut about 2in off the cold pipe were it comes through in to the bumper the filter was lower than the bumper.
used some vac hose to make a buffer so it does not rattle on the frame
intake all back in
Old 12-26-2011   #69
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Looks great so far!
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 12-26-2011   #70
Yee haw! Lookin good!
Old 12-26-2011   #71
thanks.
took the dash back out today to see what is going on with no lights when the door opens,no home link,no map lights. found a broken wire and got it fix but still no go. Got the wiring fixed for the front windows now they work. Still have to figure out the pass rear window since it does not work. also the top switch is not working.
I did start making a oil catch can. Took it out of the hatch and rewelded it since who ever made it did a crappy job. just have to get fittings to weld on and then paint it.
Old 12-28-2011   #72
got the catch can all done and in the car. Just need to get some more clamps for the lines.
also got the 1000cc injectors in,switched to a 1g fuel rail and put the sx/br afpr on also
Old 12-28-2011   #73
nice
Old 12-28-2011   #74
rx_08
rx_08's Avatar
Looking great man!
rx_08 is offline   Reply With Quote
Old 12-28-2011   #75
Sweet! Any news on the job front?
Old 12-28-2011   #76
have a 2nd interview tomorrow mooring at 930. over at the old ASIG bld for a GSE job with service air. with the site manager to see if I want it and the hours and days off.
Old 12-28-2011   #77
Sweet. lmk how that goes.
Old 01-08-2012   #78
cut the top off the sub box to give me more room in the trunk. did not want to take it all the way out if I ever want to put some kind of 10in sub in it. It had a 15in flat ppi sub back in the day. just have to make a new floor since the one I have for it is cut out for the sub.
also took the tan carpet off the front panel and put black carpet on it.
Old 01-10-2012   #79
got the white face over lays installed on the cluster and hvac controls
now it match's the auto meter and aem gauges
got all the green led's in the car also
took out the rear seat belt guides since I took the belts out of the rear years ago and plasti diped them
Did some cleaning in the garage and found a few parts I will put in the car.
found a set of boston pro 4.5 that will go in the rear. It has boston pro 6.5 in the doors already
was going to buy a 10in fan for the a/c fan but found one in a box
also found a set of cam lock black 4pt belts that were in my brother's old talon that I might put in the car. I would have to make a harness bar for them.
Old 01-14-2012   #80
johnson
johnson's Avatar
Drives: 90mitsu
No talon spoiler?
