Old 01-28-2012   #101
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Evo IX MR Winter Projects
I was busy this morning and knocked out the upper intercooler pipe and modified the ETS intercooler outlet to increase the size to 3".
Old 01-28-2012   #102
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
This is sexy!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-29-2012   #103
santa
Boost Spike
santa's Avatar
Getting close to being done! When are you going to fire it up?
Old 01-29-2012   #104
Mark Leasure
It should be done at the end of Feb. I need to get 2150 injectors, fabricate the exhaust and finish the electrical mods for the AEM. This thinkg should rip!
Is your 1G ready for next year?
Old 01-29-2012   #105
DSM_421
Looking good brotato, keep up the good work!
I'm going to need a ride in this this summer.
Are you going to drive this on the roads? Or strip only like the DSM?
Old 01-30-2012   #106
Mark Leasure
It’s the summer car! It’s going to see the street, maybe the track once since I would prefer to rage the DSM at the strip. It’s the summer car! The DSM sees the street too, I drove it almost 1500 miles last year & burnt through 55 gallons of E98!
Old 02-02-2012   #107
santa
Boost Spike
santa's Avatar
Yeah, I drove it a few weeks ago. Gave the gf her first ride in it!! Ha!
Old 02-03-2012   #108
Only 55 gallons on e98? I put 75 threw my car, I guess I drove a lot more then I thought, or my MPG was not that good.
Anyways looks good man, someday I want a fun summercar like this. And I would have no issues running that white corolla this year.
Old 02-03-2012   #109
DSM_421
1500 miles on 55 gallons is 27 miles a gallon!
Old 02-03-2012   #110
Mark Leasure
I ran some tanks of E85 through it in the spring before I procured the E98 barrel! I think it gets high teens for mileage on E98, I haven’t measured it exactly tho.
Old 02-03-2012   #111
Mark Leasure
Thanks man! It should be a blast. How fast is the corolla?
Old 02-03-2012   #112
Mark Leasure
Picked up my FIC 2150 injectors from MAP yesterday, Thanks Chris! I'm going to start my exhaust project this weekend. Its all coming together so fast!
Old 02-03-2012   #113
DSM_421
Keep it up, excited for ya man!
High teens isn't bad either for E98 and that power level.
Old 02-03-2012   #114
Its that white one that ran that really low 9/ high 8 at proving grounds.
Old 02-07-2012   #115
Mark Leasure
I finished up the electrical work for the new small battery integration, new Injector connectors, MAP sensor, AIT sensor, connecting the wideband to the AEM EMS, and to finish it off the way the second 255 is staged in. I made my own radius cut weld in bung for the AIT sensor, it cost all of about 20 cents in material! I extended the battery connections and matched the entire factory AWG wiring. Soldered all of the joints and used adhesive lined shrink wrap to cover the solder joints. I finished the job up with split loom that was the factory size. I also machined a little bracket for the MAP sensor mounting, of course overly complicated. This took all Saturday to accomplish and the result turned out great. You cannot tell the any modifications have been performed! I ordered a new T-bolt clamp for the Boomba TB, since all of my 3” style clamps will not fit since they are too small. I turned the motor over with no ecu connected to make sure everything was sound. All is good!
Next steps:
·Fabricate exhaust & oil catch can
·Make a start up calibration for the AEM.
·Bleed the ACD
·Fill the cooling system with antifreeze
·Start the car!
Old 02-08-2012   #116
DSM_421
Looking good! Do you plan on coating or wrapping the exhaust manifold / exhaust housing on the turbo, since they are so close to your radiator?
Old 02-09-2012   #117
santa
Boost Spike
santa's Avatar
What ignition box are you going to run??
Old 02-10-2012   #118
DSM_421
You should thermal disperse coat the radiator, intake manifold, and FMIC like a boss.
And ceramic coat (like I already mentioned) the header, exhaust housing on the turbo, and downpipe... squeeze every damn HP out of it!
Old 02-12-2012   #119
Mark Leasure
I have the non-CDI coil on plug setup. I've seen some posts on EvoM with guys making high 7 and in to the 800WHP dynojet range. It's a weak point, but I'm going to give it a shot! I'm trying not to go absolute overboard unless I'm absolutely sure I need it. I’m still using the AEM twin fire garbage in the 1G, they work great until they fail & never misfired, and you?
Old 02-12-2012   #120
Mark Leasure
Nope no finish treatment on this car, all natural! For the exception of the exhaust wrap on the downpipe to protect the WG, that’s it. No fluff here!
