Old 03-22-2012   #221
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Evo IX MR Winter Projects
That is his dd evo I think with FPred on stock motor. He doesn't even need the torque!
edit: I take that back, I think his DD one is gray haha. Low end torque indeed lol.
The silver one is the stock motor daily, the built one is graphite grey. Evo's have plenty of power to tow stuff.
Old 03-22-2012   #222
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Are you using the E98 just for the talon? Or does your evo get that shit too! Also how much is a drum of that stuff?
Old 03-22-2012   #223
Mark Leasure
It's to mix real E85 for the beast evo, until the real thing is available in late May or early June. I will always run E98 in the dsm.
Old 03-23-2012   #224
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Very nice numbers
2006 WW IX RS 396/404 - SOLD
Old 03-24-2012   #225
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Out of curiosity where did you buy the E98 from? Sort of looks like MAP in the picture.
And were they your drums or did you buy them full of fuel?
I might be tempted to try E98 in my car when I'm home in the summer just because.
Old 03-24-2012   #226
Speedfreak
Drives: four tires
Pretty sure from MAP, and they come in barrels of their own AFAIK.
Old 03-24-2012   #227
User tip, do not fill race car while hung over, I am just saying.
Old 03-24-2012   #228
Mark Leasure
Haha I agree. I just opened one up yesterday and it smells like I was transferring vodka into the car.
Old 03-24-2012   #229
Mark Leasure
Yep, it was MAP. There is a drum deposit charge tacked on too, so yes the fuel comes with the barrel. I would only use it if you need to, 98 percent of people only need 85. Unless you have a setup that is capable of sky high boost, like 40+psi then 98 provides a knock safety factor.
Old 03-24-2012   #230
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Assuming we have the good E85, not winter blend crap. I like the idea of mixing e98 with 93 octane to make e85.
Old 03-24-2012   #231
Just don't mix your own E85 and expect the E85 from a pump to be anything like it.
Old 03-30-2012   #232
bramagedained
Drives: EVO IX SSL
My car should be capable of the same sort of thing as yours once it comes back
Old 03-30-2012   #233
Kind of like brewing your own beer and then getting store bought stuff, DIY Alcohol is always better
Old 05-06-2012   #234
Mark Leasure
dyno day video from May 5th.
http://www.youtube.com/watch?v=HV8TVTLkyeI&hd=1
Old 05-06-2012   #235
mondale
Drives: 1g dsm
Was that a 4th gear pull? Also forgot to ask yesterday, what kind of transfer pump are you using for the e98 barrels?
8.59 @ 158
mondale is offline   Reply With Quote
Old 05-06-2012   #236
Mark Leasure
The pull was in 3rd. And I use this pump:
http://www.ebay.com/itm/30-55-Gallon...aad219&vxp=mtr
Works better than what you would think!
Old 05-15-2012   #237
Consummate
Drives: Hybrid
Longest 3rd gear ever... Sure that wasn't 4th?!
Consummate is offline   Reply With Quote
Old 05-15-2012   #238
Its a load based dyno. It uses a electric eddy current brake to load the car. You set a ramp rate which is how fast the car accelerates. You want to slow things down to get a better sample rate for tunning.
Car sounds good man, was shoot out mode?
Old 05-15-2012   #239
Mark Leasure
Thanks John. The 656 was uncorrected. The shootout mode number was something like 765whp, close to the 771WHP it made on MAP's dyno.
Old 05-15-2012   #240
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
crazy numbers on that dyno! must pull pretty darn good!
ლ(ಠ益ಠლ)
