Old 03-21-2012   #81
awdxtc
Drives: 90 awd
Re: The car simply known as "The Talon"
HAHAHAHA
awdxtc is offline   Reply With Quote
Old 03-22-2012   #82
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Originally Posted by evotuner View Post
just went through the build pics and well....i have an erection
Couldn't of said it better! Looks good! I mean real good
Old 03-22-2012   #83
awdxtc
Drives: 90 awd
Thanks, it's getting there.
Old 03-23-2012   #84
awdxtc
Drives: 90 awd
I should have most of the wiring done next weekend.
Old 03-23-2012   #85
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I saw this on tuners, I am horribly jealous of that clean black 1g...
Old 03-23-2012   #86
awdxtc
Drives: 90 awd
I have to say I really miss driving this car. I can not wait t get it on the road.
Old 03-25-2012   #87
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Very Nice its gonna be a beast no doubt!
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 03-27-2012   #88
awdxtc
Drives: 90 awd
Should make good power and run some good times.
Old 03-27-2012   #89
Mark Leasure
Mark Leasure's Avatar
How close are you to starting it up?
Old 03-27-2012   #90
awdxtc
Drives: 90 awd
I have a few things left to do, most should be done this weekend, but some will not. I have to get bung welded in the intercooler pipe for the AIT sensor. That will not be done this weekend. There are a few other things here and there, but for the most part it will all be done by Sunday. I am a Nursing student and i work 20 plus hours a week. That equates to an average of a 12-14 hour day, so my free time is really limited.
Old 04-10-2012   #91
awdxtc
Drives: 90 awd
So after asking people where/how they mounted their MSD DIS2 I decided to come up with my own solution. I wanted something that was sturdy, something that was no held together with duct tape and zip ties. This is only a rough version of the final product. I made it out of a piece of 1/8" thick steel plate. I would like to use aluminum but it is expensive for such a thick piece. the reason for the thickness is to have to the two main mounting bolts countersunk. The MSD unit is held onto the plate by four allen head bolts.
Here is a picture of how the unit looks bolted onto the car with the MSD in place
Notice the lines drawn on the plate, the center section is going to be cut out to save weight. The outer lines show where can material can be removed to make the mounting plate a bit more atheistically pleasing.
Here you can see the mounting bolts are countersunk into the place.
The plate mounts to the car via a set of stainless bosses. The system works like this. There are two broached studs, each boss is threaded. The boss threads onto the studs and can be adjusted to fit the contour of the fire wall, adjusting in or out to make the plate level. The two main mounting bolts thread into the boss. Here is a picture of the bosses.
Old 04-10-2012   #92
Lol @ $5500 clutch but aluminum plate is too expensive! Looks good tho
Old 04-10-2012   #93
awdxtc
Drives: 90 awd
Aluminum plates does not have as much functionality a the $5500 clutch lol.
