Old 05-04-2012   #21
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: E85 Blends
I will try to bring one as well.
Old 05-04-2012   #22
Re: E85 Blends
62% doesn't meet the EPA's requirements for E85 so my initial thoughts are to verify the accuracy of the testers since they could face huge fines, plus it just doesn't make sense economically to blend at that level.
Old 05-04-2012   #23
Re: E85 Blends
That is my thought. I figured either it was old/diluted E-70 winter blend or the tester isn't accurate.
Old 05-04-2012   #24
Re: E85 Blends
I have heard of multiple people having low readings from all over the place, I don't think its the testers. Weren't there a lit of low ass numbers at b4b too? Maybe this crappy e85 could be why? E70 to e85 made like a 15-20 HP difference on my Evo.
Old 05-04-2012   #25
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: E85 Blends
maybe this is why mine only put down 407 and 355 a few weeks after my initial tune, same boost, same timing who knows
2006 WW IX RS 396/404 - SOLD
Old 05-05-2012   #26
blackrosenova400
blackrosenova400's Avatar
Re: E85 Blends
I tested e85 at the Kwik Trip in Shakopee (Near Walmart), Holiday at 169 and 41, and at my hometown Kwik Trip in Belle Plaine, they were all at low 60%.
I also tested the e85 at the local Cenex in Belle Plaine and found its was about 50%!
20g Mafia
Old 05-05-2012   #27
Re: E85 Blends
Looks like this isn't being regulated well. Gas is cheaper than ethanol, so the lower percentage there is in the gas, the more money someone is making. Just have to figure out who the "someone" is that is messing things up!
Old 05-05-2012   #28
Re: E85 Blends
No it's not, RBOB gasoline is currently $0.77 more than CBOT ethanol per gallon (as of market-close 5/4/12). This is why blenders are all currently blending at the 10% maximum allowed by the EPA in gasoline. E15 has actually already been approved too, but they're still in the process of rolling that out; expect to start seeing it at some stations in a few select states such as Kansas and maybe Iowa as early as July. I'm sure Minnesota won't be too far behind either...
Old 05-05-2012   #29
Re: E85 Blends
Yea, the 10% ethanol blend is actually cheaper than the non E10 gas here in Iowa. E85 is still under $3.00 as well. I'll have to get one of those testers to see what Kum & Go has for a percentage right now (main chain that sells E85 here).
Old 05-05-2012   #31
DavidPHumes
Drives: Turbo LSx FC RX-7
Re: E85 Blends
Dustins car only put down 618 at B4B but yet he previously made 600 on RS' dyno... go figure...
DavidPHumes is offline   Reply With Quote
Old 05-05-2012   #32
Re: E85 Blends
Originally Posted by blackrosenova400 View Post
Corborns Belle Plaine e85 ethanol content, 70% woohoo!
Nice! While that is a drive for me, if I buy a full tank it may be worth it.
What is the price per gallon?
Old 05-05-2012   #33
Re: E85 Blends
Yea Bryce's car only made like 570ish too, it had made 580ish at DB two months ago, and 660 shootout, which is damn close to MAP numbers. Shane said he tested the Rogers E85 at 77% yesterday. Spaz filled up there and made some pretty decent power today.
Old 05-05-2012   #34
blackrosenova400
Re: E85 Blends
3.19$
Dont be feeding off of my gold corn stash!
20g Mafia
Old 05-06-2012   #35
Re: E85 Blends
So does everyone constantly change their tunes for the mixed blend?
Or is everyone's numbers changing purely because the mix changes and in turn the AFRs?
Old 05-06-2012   #36
Re: E85 Blends
Just the mix and AFR's mostly. With my Evo the car was tuned on E70 for around 11.2-11.3 AFR, but when the full blend got to the pumps, it would lean itself out to about 12.2-12.3. On my car it was about a 20 HP/TQ difference
Old 05-06-2012   #37
Re: E85 Blends
Shane tested fuel from my rail yesterday on the dyno - 72%. Came from the Holiday downtown minneapolis by the twins stadium.
Old 05-18-2012   #38
Re: E85 Blends
Where do you get these testers?
Since '06 i've never tested it, just tune rich on the shitty stuff or tune good on the E85 and let it get rich as the blend gets weaker.
Would it make tuning easier?
Old 05-18-2012   #39
Re: E85 Blends
Well, you would know what you're dealing with at least I guess. Buschnuts has them on his website for like $15. Seems to be about the going rate. I have one also, but its packed away with all my shit in the storage unit I think.
Old 05-18-2012   #40
Re: E85 Blends
no locals sell it?
