Old 06-03-2012   #661
DSM_421
Re: GheyrodX - bigger, fatter, gheyer!
Heat shields look great!
I always love the way you mod and maintain your vehicles. Straight perfection IMO.
When you are ready to sell this car, hopefully I will be in the position to make an offer on it.
Old 06-03-2012   #662
Thank you!
Old 06-03-2012   #663
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Looks really nice! I'm impressed with the progress. Keep up the good!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-06-2012   #664
New MAP/Turbosmart WGA for my EF2X!
Old 06-06-2012   #665
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Looks great!
Picking mine up today
Old 06-06-2012   #666
Pretty sweet looking internal gate.
Old 06-06-2012   #667
Murlo26
Murlo26's Avatar
Just got mine over lunch...some assembly required I guess lol.
You are sticking with the 18psi spring I assume Kracka?
Old 06-06-2012   #668
Correct; that is the proper spring for pump gas. The other is a secondary spring that can be added for those attempting to run only high-boost.
Old 06-06-2012   #669
Murlo26
Murlo26's Avatar
Correct, the other one is added for 25psi, thats what MAP said.
I figured you were going to stick with that one, was just curious though as I thought you were above 25, but I agree it makes sense for the 18.
Old 06-06-2012   #670
I run 27psig peak, but I want to make sure the WGA arm is able to have some pre-tension on it, I need some downward correction available for a 91-octane safe map, plus I don't want to combat any creep or spike issues. MAP's standard 25psig WGA has shown itself to be too stiff for my needs.
Old 06-06-2012   #671
Murlo26
Murlo26's Avatar
Too stiff, giggity.
Old 06-09-2012   #672
New MAP Turbosmart WGA installed and retuned with Cobb AP TEPHRA MODS!!! It's nice having knock CEL and 93/91 map-switching back
Ported exhaust manifold: 411/367 @ 26psig
Short-runner exhaust manifold: 416/374 @ 26psig
Gains are gains, I'll take them! I think this really proves that my stock cams are pretty much maxed out and the bottleneck in my system at this point. Chart coming soon.
Old 06-09-2012   #673
Tell Kevin to crack the whip over there so we can get graphs to look at haha
Old 06-10-2012   #674
Murlo26
Murlo26's Avatar
Was that you that texted me this morning, well sat morning?
I was confused haha.
Old 06-10-2012   #675
That was me
Old 06-10-2012   #676
Before and after (MAP short-runner exhaust manifold & MAP Turbosmart WGA):
There is a noticable increase in the mid-range, that's where I'm really feeling it. Plus, the turbo seems much more responsive with this new WGA which makes sense since the WG was able to be properly tensioned, I wasn't able to run any pre-tension with the original 25psi WGA. Although spool does appear a touch slower, torque picks up a little bit quicker.
Knock CEL is setup at 3 counts (slow) and 5 counts (fast), but I've yet to see a single flash even with two pulls to 140+ so far
Old 06-10-2012   #677
Tachyon
Tachyon's Avatar
Drives: Icarus
Very nice pump gas setup, Chris!
-Sebastian Vettel
Old 06-10-2012   #678
I was just out ripping around some more and this car is seriously the ultimate DD street car! Handling is spot on, it rips through the gears, reliability has been decent, and it drives smooth as stock.
Old 06-10-2012   #679
Murlo26
Murlo26's Avatar
Looking good buddy!
Bout time Cobb got the Tephra shit. Too bad they dumped tephra too, but you got the important stuff
Old 06-10-2012   #680
No Moar tephra @ Cobb?
Looks like perfect daily driver power! Time to leave it alone now!
