Build the X 17 56.67%
Old 06-08-2012   #2181
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Originally Posted by simulatedwood View Post
Glad you got the issue fixed.
Why does it feel like someone needs to supervise your wrenching efforts? I kid .. I kid What happened last night sounds comical and should be on youtube.
In all seriousness, the clip is probably sitting on the transfer case or cradle, worst spot ever to try and fish something out.
That is exactly what my tuner said. He didn't even question, he just said, its on the transfer case lol. It was a little comical, one thing after the other, but I kept chugging along. I'll get it yet!
lol, dust off?
You don't have a small compressor?
I assume you meant to quote me
And yes, dust off! No compressor yet, its on my list of tools to buy. The shit worked beautifully actually, I was very impressed haha. A guy on the national forums recommended it, said he carries it with him while street tuning to dial in wastegate preload, worked pretty dang slick
Old 06-08-2012   #2182
LMAO!
Old 06-08-2012   #2183
yeah, sorry.
Shawn had me cracking up though.
Buy a small one, if you ever make it to the track I can see you wanting one.
Old 06-08-2012   #2184
Murlo26
Murlo26's Avatar
E clip on stupid wastegate arm, new DW1300 MAP loaded.
Logged it. Trims within +/- 3%.
Lets do this shit.
Old 06-08-2012   #2185
Old 06-08-2012   #2186
sorry I couldn't resist.
Old 06-09-2012   #2187
Murlo26
Murlo26's Avatar
That hurts! Lol
Old 06-09-2012   #2188
:flowers:
If you are cruising around sat. night hit me up. I'll be outside working on the car.
Old 06-10-2012   #2189
Murlo26
Murlo26's Avatar
First pull in a long time with some boost...car is feeling pretty good right now. I mean the pull felt doggy as its 10's for afr's, 19-20psi, 10* timing at most and pump gas, but its progress!!
Can't wait for some more boost and then finally some E85 again.
Old 06-11-2012   #2190
Murlo26
Murlo26's Avatar
The car is pretty knock prone down low...(2500-3500) area so we are trying to dial it back there, but he thinks its just the motor noise. I guess we will know when he trys adding more fuel etc.
edit: FYI, these numbers aren't really comparable to yesterdays...different road...this one wasn't flat at all, downhill a bit, so for sure inflated. But yesterdays where I went WOT was slightly uphill so whatever lol. I am not really doing the pulls for VD, simply for tuning but yea.
Old 06-12-2012   #2191
Murlo26
Murlo26's Avatar
So tonight while doing a WOT run, the car felt like it hit a wall. I thought maybe it was IC pipe or wastegate arm that popped off...nope none of that.
Spent like an hour reviewing logs and finally found that in my map the MAF tables above 3.4V were all messed up. Found out the MAF table either got corrupted or Jon just pasted the wrong stuff in for the high volt side. Anyway, glad it wasn't anything major, I was seriously like omg wtf just happened, As the car seriously flatlined (i thought the motor was toast again ) but its just that it fuel cut essentially... but it lives to fight another day!
So, reviewed the cruise/idle logs. Mine are within 1-2%, car drives better than stock now.
It's just WOT and partial boost pulls now, no more cruising around aimlessly.
Old 06-12-2012   #2192
Murlo26
Murlo26's Avatar
So Jon also showed me this which I have seen screenshots of before but never knew what it was. $25 for this software which is apparently ECUtek hacked, but damn, it makes reading logs so much damn easier.
Here is just a few quick shots of me playing around with it.
WOT run from dyno above. (411whp one or whatever)
Same run...as you can see MAP (Speed density) is the red line, MAF calc is the grey and actual load is the blue.
Just so you can see how the Evo X ecu looks at those.
stupid jagged maf
Old 06-12-2012   #2193
Murlo26
Murlo26's Avatar
Latest pull today....car felt pretty damn good.
Still a spot during spool where I think MAF drops a bit low and it leans out a bit, but Jon will clean that up
Car honestly felt awesome for the first time in months, very smooth, and actually a bit of pep now!
Old 06-12-2012   #2194
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice! Now leave it alone and bring it to the PG
-Sebastian Vettel
Old 06-12-2012   #2195
Murlo26
Murlo26's Avatar
^Can't, must smooth out the pump gas tune a bit more. It's still very very conservative. 10's AFR's and I think I just barely hitting 13* of timing up top.
Not sure what timing is safe on pump at 10:1 compression, I am guessing 14-15 is still "safe" but I will let the professional deal with that. I think I will be close to 500whp with a bit more fuel work, bit more boost and smoothing out.
Not looking to break records with the pump tune at all.
Then comes E85 fun. I think to even be close to competitive at PG i will need an E85 tune. I don't think I will do great there but the better I do the more fun I will have.
Old 06-12-2012   #2196
93gtpeater
Drives: cbr 1000rr repsol
When you get it tuned on corn lets run. From a roll or a dead stop
Old 06-12-2012   #2197
Murlo26
Murlo26's Avatar
Sure, hopefully I will be putting corn in the car by this weekend.
oh, another bit of playing with logviewer.
Here is another shot (better) of map calcs vs. maf calcs. Look how ugly the maf line is, then how nice the map line is...then notice how smooth load follows it!
Old 06-12-2012   #2198
93gtpeater
Looks like this new set up should make for a very real tuned car. You going to break 500 at db?
Old 06-12-2012   #2199
Murlo26
Murlo26's Avatar
Don't know...I would assume. Even on Shane's conservative tune my car hit 494 at DB last fall on E70. With more fine tuning and a lil boost I don't see why not.
My real goal has always been 600whp on a dynojet which is like 520ish on DB's dyno. We will see if I get there. Not going to push it but if it happens I will be happy. If not I have a few more mods to add yet (intake manifold and throttle body) then its on to a bigger turbo if I really want to add more power which I don't think i do. My car feels like a great balance of response/top end as I could expect out of a 4 cylinder (in an evo X at least).
Old 06-12-2012   #2200
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
...My real goal has always been 600whp on a dynojet...
I thought that last year for my car too, haha.
Tags
