Old 08-07-2012   #201
DSMFreak
Drives: P.O.S. beater, soon to be Evo 8
Re: Mark's 1G Winter Projects
That's awesome that its cutting that much weight. Looks like a really sweet setup!
Also just read through your thread and wow this car is amazing! I will have to check it out sometime.
DSMFreak is offline   Reply With Quote
Old 08-08-2012   #202
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
40lbs sounds like the diet is off to a good start.
Old 08-08-2012   #203
Very nice, also looking at the in car video again, I think you let off at the first cone for the final trap and ET, make sure you drive threw the markers to get a great pass.
Old 08-08-2012   #204
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
No problem. Thanks for letting me put the go pro in ur car. Whens the next race?
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 08-08-2012   #205
Hmm 40 lbs weight loss.
I wish i was fast enough to have people give me go-pros.
Old 08-08-2012   #206
Going to the track might be a better start.
Old 08-08-2012   #207
ouch, soon old timer. and I won't be stuck in the 12s, probably just damn low 11s.
Old 08-11-2012   #208
Mark Leasure
Mark Leasure's Avatar
Made a new battery mount today, I’m going move the battery back to the front of the car. Currently I have a rear mounted PC680. The battery is on its way out so I picked up a PC545, It’s 4 pounds lighter. I will be removing a lot of 2AWG going to the back of the car, the sealed box and some other stuff. It should shave off 15 pounds, at a minimum. I’m also integrating a solid state relay up front for the shut down switch.
www.maperformance.com
Old 08-11-2012   #209
Very nice.
Old 08-11-2012   #210
Mark Leasure
The diet is in full progress!
- 40 for the fuel tank
- 30 for the front STM brakes alone
- I have the molded flex-a-lite rear windows. We will see how much they shave off, they are super light.
- Being conservative with 15 on the battery move
Old 08-11-2012   #211
fuck that is awesome. I wish I could drop 300 lbs off my car total. Get it down to 2950 or less without me in it.
How much did your car weigh the last time you checked it?
Old 08-11-2012   #212
Mark Leasure
My father in-law cut up my rear rotors, he has a cnc in his garage. I need to weigh them to see how much came off.
Old 08-11-2012   #213
Mark Leasure
2870 with me in it. I weigh 195.
Old 08-12-2012   #214
Those rear rotors look sweet! So those are just scalloped stockers?
Old 08-12-2012   #215
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So that was the weight before these last few weight reductions? Or is that as of today?
Rotors looks awesome. Cool that you made your own!
So 8's next yr? It's gonna be a long winter I hope you have no plans to change to an auto.
Old 08-12-2012   #216
Mark Leasure
That was the old weight before any weight reduction. Goal is to get it under 2500. It will remain a shifted car.
Old 08-12-2012   #217
Mark Leasure
yep just scalloped stockers.
Old 08-12-2012   #218
That is light!
Badass, that thing will be crazy at 2500lbs.
Old 08-12-2012   #219
Mark Leasure
I installed my brakes today, each rear rotor is 1.8 pounds lighter now:
Old 08-15-2012   #220
Mark Leasure
I couldn't get the tank anodized they said that I would have bare aluminum spots on the inside of the tank. I ordered a different style tip over valve that I could seal up. No big deal, I also added an an6 so I could drain the fuel in the winter or when it sits too long.
