Old 08-16-2012   #481
Re: Big Brown's Automagic - The last episode in my DSM story.
I have one that should be in, tomorrow am. I'll do it tomorrow night I guess.
I might just RTV it to at least test the car out. But I would prefer a gasket.
Old 08-16-2012   #482
blackrosenova400
blackrosenova400's Avatar
The only problem with rtv on an automatic is any excessive amount will get into the tranny fluid and could possibly gum up the valve body. I seen it once with an Allison automatic. The company installed an aftermarket pto and used rtv instead of a gasket. Bad move since the pto should have been shimmed. But there biggest mistake was they used so much rtv it destroyed there transmission.
20g Mafia
Old 08-16-2012   #483
I have a few on order locally, but it will wait till saturday when I have a gasket. No point doing it tomorrow since i work 10-1030.
Only thing is whether or not the car will work or what issue will come up next.
Old 08-16-2012   #484
1/2hr work day? sheeeesh...
Old 08-16-2012   #485
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Just did a search, OOOOreillys in Crystal on West Broadway has a filter kit. NOt that it makes a difference now.
Converted to LS
Old 08-16-2012   #486
I bet its not the right one.
Old 08-16-2012   #487
cmspaz
Walls need hugs too
cmspaz's Avatar
I bet there's someone on here that can find you the right one.
Originally Posted by Trogdor
cmspaz is online now   Reply With Quote
Old 08-17-2012   #488
I wish he would.
Old 08-17-2012   #489
munchgsx
munchgsx's Avatar
Who?
Converted to LS
Old 08-17-2012   #490
blackawdtsi
Drives: 2G DSM
Aaron contemplating RTVing where a gasket should be? Times have changed.
Shoulda torqued every bolt ya touched too.
Old 08-17-2012   #491
lol, i forgot to tell you I went and bought all sizes of tq wrenches so that I can do that.
But well the car will be together for 3 months.
Old 08-18-2012   #492
Well same issue. Not sure what the culprit is now.
Old 08-18-2012   #493
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
you could try wireing it up kiggly mod or 2 switch style to eliminate valve body/solinoid issue. I'm sure its the first thing you did but I would also double check all the plugs and harness' and that the shift linkage is adjusted properly. Theh 2 plugs on top of the trans would be easy to miss or not get pluged in all the way.
11.35 @ 120mph
Old 08-18-2012   #494
blackrosenova400
I would check the solenoid resistance straight at the tcu, that way you make sure the whole circuit it good.
The best way is to load test the circuit because you could have one strand making contact in the harnessm but as soon as you put a load on it, it becomes a huge voltage drop.
20g Mafia
Old 08-18-2012   #495
How would one do this? I'm useless at electrical diagnosis.
Old 08-19-2012   #497
Saw your fb post, what was it?
Old 08-19-2012   #498
Ok, did some troubleshooting last night went through the guide in the manual and turns out 2 plugs were in the wrong place.
Switched them out and bam! car works as normal.
Old 08-19-2012   #499
Nice! Head straight to the drag track then, you've been waiting long enough! GO GO GO GO
Old 08-19-2012   #500
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
yeah...lets go to the track mister.
