Old 09-04-2012   #41
timschot
timschot's Avatar
Drives: 2008 Evo GSR
Re: Tim's evo x
Had some fun at the amery event.
Picked the twin up last week.
And sounds like the turbo is almost done
Car is at RS getting some love as of this morning! Sounds like the engine will be out today.
timschot is offline   Reply With Quote
Old 10-09-2012   #42
timschot
timschot's Avatar
Re: Tim's evo x
Haven't posted updates on here in a while... copying from evomn
Old turbo...
New turbo and some quieter pads for the street...
Motor ready to be torn into...
Empty car
The motor ended up having some scoring in the cylinder walls, so we were going to just overbore .020 on stock sleeves, but that didn't work out, so off the block went to ERL, and they sent back this... bored and honed for my .020 over pistons. Would've gone a bit bigger bore, but I like having plenty of meat and the extra ci isn't worth a 3 week wait on pistons.
Also picked up the AMS CMC kit... no more plastic CMC. Adapts evo 8/9 oem CMC.
Ron started getting things put together.
Ron noticed this... "T1M"? It was meant to be.
Turns out the block I got from ERL is the newer style with the deleted timing chain oil squirter, which threw us off at first but I guess that's good news. We were also missing two galley plugs from the core, so ERL shipped those up, waiting on those to arrive now.
Old 10-09-2012   #43
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: Tim's evo x
beast of a block man.
ლ(ಠ益ಠლ)
Old 10-09-2012   #44
Re: Tim's evo x
Awesome dude! I highly suggest you get something other than Girodisc Magics though.
Old 10-09-2012   #45
timschot
timschot's Avatar
Re: Tim's evo x
Thanks guys, hopefully not much longer now.
Those are just for street when I'll be doing light cruising and want some quiet. Swapping pads for anything spirited.
Old 10-09-2012   #46
Re: Tim's evo x
Noted, but they are a love/hate pad; people either love them or hate them. I'm personally on the hate side of the fence (tried them on my IX and the ex's WRX). The Stoptech Street Performance pads are much better for a daily-driver, plus they're cheaper (silent, less dust than OEM, etc.). The friction coefficient as they heat up can be downright scary even during a hard highway stop. It's quite strange actually, as they get heated up grip will fade, then they get a little hotter and the grip comes back, and so on... Makes for an interesting fast stop from highway speeds.
I know there are some people on this site who like them, and I hate to sound like I'm bashing, but I seriously couldn't wait to take these things off my IX and my ex bitched about them constantly until I finally replaced them for her.
Old 10-09-2012   #47
timschot
timschot's Avatar
Re: Tim's evo x
Thanks for the info. I'll read up some more on the X pads (if they're any different) before I install them. They're still in the box, so I could probably return them if they're really that bad. I like the pads that are on there now - I belive they're hawk hp plus. They're just squeaky as hell.
Old 10-09-2012   #48
Re: Tim's evo x
Front pads between the 8/9/X are all identical (and the same as STI/35Z/G35/TL/etc.).
The aftermarket pads I've tried on Evos are:
Girodisc Magic
RacingBrake ET500
Stoptech Street
The ET500's are probably my favorites as they nearly dust-free but were a great street/autox pad, but at half the price the Stoptechs are a very good pad too and work fantastically on an aggressively driven DD (this is what the guys at GTWorx recommend too); they've yet to let me down during even fast group cruises.
Old 10-09-2012   #49
Re: Tim's evo x
Forgot to mention, Girodisc actually has a new street pad in the works that should be out soon, but they said it will be dustier than the Magic's compound.
Old 10-10-2012   #50
timschot
timschot's Avatar
Re: Tim's evo x
Thanks Kracka. I'll probably return and go stoptechs before I install them then.
Ron's bringing the turbo to MAP today to do the wastegate flapper/actuator arm swap. Then it's all clear to finish building it I believe.
Old 10-13-2012   #51
timschot
timschot's Avatar
Re: Tim's evo x
I'm told it was started and sounded good!
Ron's figuring out some issues to get it ready to go - airbag light is on, return fuel line popped off, probably clogged in the filter inside the bucket.
Old 10-19-2012   #52
timschot
timschot's Avatar
Re: Tim's evo x
Picked it up yesterday! It's tuned to 20psi right now, the wastegate and blowoff valves are put to work. Definitely a lot more air coming in with the bigger intake and turbo. Going to put 500-1000 miles on it and bring it back for Ron to work his magic and see what we can get out of it.
I put about 100 miles on it, drove home from RS, then to a buddy's to help with a head gasket after the kid was asleep. Really liking the clutch for driving around... super smooth.
I will be at the dyno day, not dynoing but a buddy will be with his GTO, supercharged (but pretty low boost)
Ron sent over a bunch more pictures too.
Old 10-19-2012   #53
Re: Tim's evo x
Very nice.
Old 10-19-2012   #54
Re: Tim's evo x
That is perty!
Old 10-20-2012   #55
Re: Tim's evo x
Whoah, I didn't realize that the entire harness unclips like that--what a time-saver that would be!
Old 02-21-2013   #56
timschot
timschot's Avatar
Re: Tim's evo x
Evo's all broken in and turned up now. Been posting more on evomn, but figured I'd put an update here. Lost about 500rpm spool and gained a bunch of power up top. This is on 1100cc injectors and a dw65c w/ a KB BAP, running e70 tuned rich enough to run e85 when the pumps switch.
I looked back and found a post where I said my goal was 450/390 on Ron's dyno... I guess we were pretty damn close! 454/388
Old 02-21-2013   #57
Trogdor
Trogdor's Avatar
Drives: people crazy
Re: Tim's evo x
Nice!!!
I'm glad you decided to keep it
Also, this makes me hopeful that I can get close to 450 too since you and I have similar bolt ons.
Trogdor is offline   Reply With Quote
Old 02-21-2013   #58
timschot
timschot's Avatar
Re: Tim's evo x
Thanks!
I never wanted to get rid of it - luckily it didn't have to come to that. We got fucked on buying a house in 2007, it's value dropped about 80k.. so even though we've put about 20k into finishing a basement and paid extra on the mortgage for 5 years, we're still going to have to pay a lot on top just to get out of it, IF we can even find a buyer. Plus putting together a down payment for the next place. But we're good now, and in less of a hurry to move anyway.
Yeah, you should make very close to the same numbers. Not much difference in our builds, really. Ron will probably be able to pull up my tune and just tweak it a bit... lol
2008 GSR SSS WW
RS motors built
454/388 mustang dyno on winter E70
ERL sleeved block, MAP rods, Wiseco pistons, MAP EF3, Exedy Twin HD
Old 02-21-2013   #59
Re: Tim's evo x
^Glad to hear you are keeping it.
I was in the same boat as you, i bought in 07 or 06 at the height of the market, fricken blows. Oh well.
That powerband is so badass.
Old 02-21-2013   #60
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Tim's evo x
My personal favorite evo x
2006 WW IX RS 396/404 - SOLD
