Old 10-26-2012   #21
4seasons69
4seasons69's Avatar
Re: my new project
Ok so I got my head back from the head shop today. It's got ferrea springs and retainers, ferrea competition plus +1mm valves, it was ported and polished and port matched to the manifolds. I just need a head gasket and a few other things then I can start putting her back together. Here are some pics.
ID:	12950   Click image for larger version
ID:	12951   Click image for larger version
ID:	12954   Click image for larger version
ID:	12955   Click image for larger version
Old 10-26-2012   #22
4seasons69
4seasons69's Avatar
Re: my new project
Some more pics of the head. Can't wait to start putting this thing back together!
ID:	12957   Click image for larger version
ID:	12958   Click image for larger version
ID:	12960   Click image for larger version
ID:	12961   Click image for larger version
Old 10-26-2012   #23
Re: my new project
Nice. Hopefully this thing will finally see a track next year
Old 10-26-2012   #24
4seasons69
4seasons69's Avatar
Re: my new project
Thanks! And yeah assuming I don't run into any major complications like I did this summer it will see the track at least once :-)
Old 10-26-2012   #25
Re: my new project
Looking good! Would be cool to see the thing make some passes
Old 10-26-2012   #26
4seasons69
4seasons69's Avatar
Re: my new project
Thanks! I'm pretty hell bent on getting this to the track at least once next year. I have no idea what kind of times I'd be able to run or how the t-case or rear diff will hold up but we'll give her hell anyways :-). If the car breaks again I better be at the track when it happens lol
Old 10-26-2012   #27
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: my new project
Looking good man! Keep pushing!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 10-26-2012   #28
Re: my new project
Thanks! I'm pretty hell bent on getting this to the track at least once next year. I have no idea what kind of times I'd be able to run or how the t-case or rear different will hold up but we'll give her he'll anyways :-). If the car breaks again I better be at the track when it happens lol
You'll have to post up when you go!
You doing any other upgrades to it?
Old 10-26-2012   #29
4seasons69
4seasons69's Avatar
Re: my new project
Yeah ill def post up when I go. I'd like to go when there's a few people from here going to.
As for upgrades the biggest addition will probably be the porting and polishing of the head. The block is completely different but I don't know if i would consider it an up grade. I did add a girdle to the block though. I'm toying with the idea of a different turbo. I'd really like a gtx 4294 or 4202 but idk if I want to spend 3k on a turbo lol otherwise it's going to basically be the same setup
Old 10-26-2012   #30
4seasons69
4seasons69's Avatar
Re: my new project
Thanks!
Old 11-24-2012   #31
4seasons69
4seasons69's Avatar
Re: my new project
Here's a little update. Works been slow so it kind of put me on hold for gettng parts but I finally was able to order a headgasket so once that gets here I can start putting things back together. Then I just need a clutch rebuild kit and I'm going to get an upgraded clutch fork and miscellaneous gaskets, fluids, etc. to get her installed.
I also think i got my turbo situation figured out. I can't justify spending what it will cost to fix my current turbo so right now I'm planning on going with a 67mm borg warner s400sx
Old 11-24-2012   #32
Re: my new project
Nice choice with BW, welcome to the dark side. That turbo sounds massive.
Old 11-24-2012   #33
4seasons69
4seasons69's Avatar
Re: my new project
Yup! Thanks for the heads up on bw I never would have thought about them. As for the turbo its the comp and turbine housings are the same as the 4294 I have now so my intake and exhaust will work with no modifications. The comp well is actually a little smaller but it outflows the 4294. Plus it's very reasonably priced! Not sure what a/r on the turbine housing I want to go with yet though
Old 11-24-2012   #34
Re: my new project
The BW appears to be more durable but that's about it, otherwise slower spool and less power.
So this will be on the road come spring?
Old 11-24-2012   #35
4seasons69
4seasons69's Avatar
Re: my new project
Idk about slower spool or less power. It's essentially one of bws versions of a gt42. All the info I can find on the turbo it seems to be a pretty wicked turbo. If you have any actual info on this not being a good option for me I would like to see it. I haven't purchased anything yet so am still open to options
Old 11-24-2012   #36
Re: my new project
It's a fantastic option, I'm at work so i can't find the video, but sound performance tested a BW S3xx against the 6266 and the 6266 made more power, but the BW spooled up better.
On evom the supporters of BW stuff agree that the spool and transient boost with the BW turbo is superior to PTE but in sacrifice for max power.
I'd say get the BW stuff and not have any doubt about the turbo eating its face, worth the 30-40whp you might give up.
I'm just not a fanboy of it as I haven't seen anything but market hype for the ETT and EFR stuff.
http://www.spracingforum.com/forums/...ESTING-RESULTS
http://www.youtube.com/watch?v=iVqiUhAv01c&hd=1
Old 11-24-2012   #37
4seasons69
4seasons69's Avatar
Re: my new project
Okay I gotcha. Yeah i like the pte stuff but their versions of the gt42 are 3k and their other turbos I'd have to have a new intake and exhaust fabricated. The BW is 1400 and seems to out perform the Garrett I have now. The BW just seems to be the best compromise of performance and price. Oh and yes it will definitely be on the road come spring time!
Old 11-24-2012   #38
Re: my new project
Heads up that the turbine housing are massive. I went with .91 divided t4 I think. Don't let the number deceive you, its just a ratio. Id bet if you put my .91 BW housing next to a larger number pte/garrett housing, you will see how much larger it is.
Old 11-24-2012   #39
4seasons69
4seasons69's Avatar
Re: my new project
Okay good to know!
Old 11-24-2012   #40
Re: my new project
^I know a guy selling a S400 turbo
