Old 11-12-2012   #141
Re: MAP's 2008 Evolution X GSR Build Thread aka Project GGX
Nice powerband, that motor needs to get swapped into something!
DSM...
Old 11-12-2012   #142
Kick-ass powerband for sure.
Old 11-12-2012   #143
Full boost at 3300rpm is amazing on an ef4! Can you elaborate on the dual wastegate setup you're running now?
And still on stock exhaust manifold? Awesome!
HDG6 FTW!
Also what's with the A1000 fuel pump? Stock hanger or are you running a surge tank setup?
Also y u no 3-port bcs? I love the simplicity of a MBC but going to a hybrid setup helped my top end a ton!
Old 11-12-2012   #144
Wow! Those are the kind of numbers I like these days. Looks like a sick street car!
Old 11-12-2012   #145
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Looks like that engine/turbo combo is right in the sweet spot. Damn near the same spool with tad bit more power . Ill have to remember to ride with you to lunch here soon haha.
Old 11-13-2012   #146
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
That is just nasty
2006 WW IX RS 396/404 - SOLD
Old 11-13-2012   #147
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
HDG6 FTW!
I believe the dual wastegate setup is simply the compgate40 external wg on their downpipe in conjunction with the internal gate on the ef4. Basically, use the internal to keep twinscroll, then let external control after wg pressure opens internal for max boost holding.
I saw the A1000 he is using, its pretty cool, wish they could get all the bugs worked out. It's a camaro fuel pump drop in hangar that they modified. Last I spoke with Chris he was going to do something like my setup, but I am sure thats last on his list of things to change at this point.
Awesome looking setup Chris!
Old 11-13-2012   #148
Pretty badass build! May I ask why you're using FIC injectors rather than your own? any plans to add a ported throttle body?
Old 11-13-2012   #149
Mark Leasure
Mark Leasure's Avatar
Awesome power and turbo response for a daily car.
www.maperformance.com
Old 11-13-2012   #150
v8klla
v8klla's Avatar
HDG6 FTW!
Like Murlo said, straight boost source to internal to preserve spool (nearly 1000 rpms lost with only external) and boost control to the external gate. Also as stated, drop in Camaro pump modified for Evo X tank, still has fuel level issues to sort out. Also, I do still have the stock EBCS in line, just haven't gotten a chance to dabble with dual boost controllers however it isn't dropping off too bad.
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 11-13-2012   #151
v8klla
v8klla's Avatar
Been running these since before our injectors, FIC has always had our back in regards to projects and race cars, great company. Throttle body would be an interesting before and after! lol
P: 763-545-3800
Old 11-13-2012   #152
93gtpeater
Drives: cbr 1000rr repsol
It would interesting to see dyno sheet over lay of this car and murlos car. you guys are close in power.
Old 11-13-2012   #153
LOL thats the goodiest shit ive ever heard of! I love it!
I say go back to just internal gate.
Old 11-14-2012   #154
Boost control sounds way more complicated than it needs to be Two wastegates and three boost controllers (1 MBC & 2 electronic solenoids)...
I would like to see how just an internal Turbosmart WGA with a Grimspeed 3-port BCS does.
Old 11-14-2012   #155
v8klla
v8klla's Avatar
Yea it is a bit of a headache lol, but internal with MBC should perform similarly.
P: 763-545-3800
Old 11-14-2012   #156
Great powerband Chris.
Excellent work MAP crew.
Old 11-14-2012   #157
Murlo26
Murlo26's Avatar
Well although it may be overcomplicated, the boost control works. I think straight 3port (or 4 port) is the way to go, but I don't think the dual wastegates is a bad idea, I have seen that make more power over just internal. It overspins the turbo yes, but if you want max power, do it.
I tried using fotoflexer to overlay mine from the dynoday and chris's 4th gear pull. Fotoflexer wasn't working...I was going to post in my thread as to not clog this up. I guess if someone is feeling bored by all means do the overlay. Maybe overlay mine, scheides and chris's for 2.0l vs 2.2 vs 2.4 (really 2.5 I think). Might be really clogged though with all the dynoday runs, would be better to do it at MAP on their comp.
Old 11-14-2012   #158
MAP needs the same online dyno database that Cobb has.
Old 11-14-2012   #159
How do the 2 WG's overspin the turbo? Because it's holding more psi?
Old 11-14-2012   #160
Yup, higher boost in the higher RPM's.
