Old 12-11-2012   #101
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: My New 98 gsx build
Oh I have been taking what you all been giving for advice.. And it's helped a lot actually.. And I've been trying to figure it all out, Some of you are saying things that others say are pointless and also the other way around.
So stop thinking that I'm just saying yeah oh whatever never mind bullshit.. Cause I'm not. Just trying to figure things out.. So stop bashing on somebody new to all this shit and is trying to piece together a build. Some questions may seem similar, It's just because I'm hearing others say good n bad about it. You guys ain't the ones putting a lot of money into this build, So yeah I'm gonna ask questions and make damn sure it's perfect.
Yiddie is offline   Reply With Quote
Old 12-12-2012   #102
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Man I Call Troll! lol jk man dude i say keep up the project and prove everyone WRONG!
Old 12-12-2012   #103
1999Gst
Drives: 1999 Eclipse,
HAHA
Old 12-31-2012   #104
Yiddie
Yiddie's Avatar
Drives: 98GSX
Update on engine build:
Pistons: Custom Wiseco 1400HD 9.5:1
Connecting Rods: MAP Ultimate Duty Billet Steel; 7/16" ARP2000 Series Fasteners, 22MM Wrist Pins.
85.5MM bore
Side Skirt Coating
ACL Race Series
ACL Race Series Mains
OEM 6 Bolt 2.0 Crankshaft
Kiggly Racing 6 Bolt Main Girdle
ARP Main Studs
Balance Shaft Elimination
OEM Oil Pump Driven Gear
OEM Oil Pump Drive Gear
OEM Oil Pump Front Case
Old 12-31-2012   #105
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Sounds like an expensive short block
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-02-2013   #106
Yiddie
Yiddie's Avatar
Drives: 98GSX
Finally got the head build done w00t w00t!
GSC S2 Camshafts (274/274)
GSC Single Beehive Valve Springs with Titanium Retainers
Kiggly HLA Pressure Regulator
MAP Stage 1 Cylinder Head Preparation
Valves: MAP High Performance Black Nitrided Standard
Valve Seals: Supertech
Valve Guides: Ferrea Guides
Revised Lifters
Old 01-02-2013   #107
Nice motor and head setup, but holy geebus $$$$$ !!!
Old 01-02-2013   #108
Holy balls, map sold you a ton of stuff you didn't need to hit your goal but you got some baller ass parts!
Old 01-02-2013   #109
14b + 300 shot of nawwwz
Old 01-02-2013   #110
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
I make just over 600awhp on MAPs dyno with a stock flanged turbo and I am more than content. I wouldn't hesitate to drive the car daily if I wanted. Good luck with your build. Sounds like you want some massive power on that thing.
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 01-03-2013   #111
Yiddie
Yiddie's Avatar
Drives: 98GSX
I know I went overkill lol but reason I did that is because I'll probably never have to worry about the engine again nor pull it out, I can put it in and leave it alone and then be able to just add to it.
Old 01-03-2013   #112
URV8SUX
URV8SUX's Avatar
You know it a DSM right?
Lots of spendy parts are you street diving this or mostly racing it?
Old 01-03-2013   #113
Yiddie
Yiddie's Avatar
Drives: 98GSX
Mostly street but it'll see many events also.
Old 01-04-2013   #114
oh snap street racerer!!!
Old 01-05-2013   #115
URV8SUX
URV8SUX's Avatar
Awww shit STREET RACER!!!!!
Wouldn't 11.0:1 with a 58mm and E85 make your goal and have a big powerband for your street racing?
Old 01-05-2013   #116
even 9.0:1 would work, i know its enough to take down a low 10 sec transam and thats without good cams or SMIM.
Old 01-06-2013   #117
Yiddie
Yiddie's Avatar
Drives: 98GSX
Oh what a dick! lol
Old 01-23-2013   #118
Yiddie
Yiddie's Avatar
Drives: 98GSX
Update on build..
Shortblock n head currently still being assembled
List of parts I'm planning on getting soon, Any suggestions would be great.
Mishimoto Radiator
Mishimoto Fan Shroud
JM Fab Race Intake
Fidanza Adjustable Cam Gears
FuelLab 828Series In-Line Filter
Aeromotive AFPR Or MAP AFPR Kit
Tial Bov.. Which one I'm not sure yet
I might be stuck using my 16G for a few months with this current setup.. Sadly, But doubt I'll be able to afford a new turbo setup after all this right away, Which if so I'll probably wait to setup SD as well.. I bought dsmlink v3 couple weeks ago also.
Would a 2g fuel rail work for a 1g head? If not I'll probably just buy an aftermarket one.
Old 01-24-2013   #119
Pretty sure the fuel rails are all compatible. If not a 1g one is like $10. No reason to buy an aftermarket one, the stockers are good for buttloads of power.
Nothing wrong with sticking with the 16g a little longer, the last 5 years turbos have been like cell phones, a new flavor every other month and if it's 6 months old its outdated. See what the new technology is once you can afford it and go with that.
Old 02-05-2013   #120
Yiddie
Yiddie's Avatar
Drives: 98GSX
Update on build:
MAP AFPR Installation Kit
Fuelab 515 Series Fuel Pressure Regulator
Mishimoto Radiator
Mishimoto Fan Shroud Kit
JM Fab Race intake manifold
1G n/t TB
TiAL Bov
Fidanza Cam Gear
Prothane Motor Mount Inserts
Pretty much got everything bought now for the GSX, besides some maintenance items. realizing how close I am, I'm getting real excited. This is huge for me, I'm gonna be speechless when it's all installed and ready to go, That first start up and hearing it idle.. Probably gonna bring tears to my eyes and that first cruise will be the happiest moment of my life...
