Old 01-14-2013   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
where is the best place to get a rod bearing replaced ?
rod bearings went. any good reliable places to get her fixed that you guys recommend?
M1L3S is offline   Reply With Quote
Old 01-14-2013   #2
Re: where is the best place to get a rod bearing replaced ?
Time for a rebuild. DB or MAP would be good places to start.
Old 01-14-2013   #3
Yep, either rebuild or throw a used engine in.
Old 01-14-2013   #4
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
Just rebuild it yourself
ive rebuilt a block and it worked great!!
And was very cheap to do
gsxvince is offline   Reply With Quote
Old 01-14-2013   #5
Trogdor
Trogdor's Avatar
Drives: people crazy
Agreed! Rebuild time! RS, DB, or Map. I've been to all 3 of various things in the last year. All have been great to work with.
Trogdor is offline   Reply With Quote
Old 01-14-2013   #6
M1L3S
M1L3S's Avatar
Drives: 99Gst
Angry Re: where is the best place to get a rod bearing replaced ?
its a 2.3, if it wasent I would just shop around for a 6 bolt
so I would need to get the head cleaned
crank micro polished ? or replaced with another 4g64?
rod honed ? then just measure bearing clearance and reassemble? or is there alot more im missing?
it would be my first rebuild. I honestly want to do it myself for the experience. also I have heard repair cost of 800-2500?
Old 01-14-2013   #7
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
If you do in fact live in Maple Grove as your profile suggests, I'd use DB, closest. Proximity is always nice.
Old 01-14-2013   #8
gsxvince
the dsm mechanic!
As long as you messure right its pretty damn easy
Old 01-14-2013   #9
Everything that has or could have even the smallest bearing shaving stuck in it(oil pan, oil pump, oil filter housing, oil cooler, oil cooler lines, head, etc) need to be replaced or thoroughly cleaned, or else you risk it just spinning a bearing again quickly. Some things like an oil cooler are pretty much impossible to get clean.
Old 01-14-2013   #10
M1L3S
M1L3S's Avatar
Drives: 99Gst
I just moved out to anoka two weeks ago. money is tight like it is for everyone. I would really like to do the rebuild myself, with help from who ever is willing. I have learned that nothing is truly easy when it comes to dsm's. but all in all im hoping for the best. in all honesty I have yet to dig into her . so I truly do not know the extent of the damage. just going off what shane, and a trusted mechanic and my ears heard.
Old 01-14-2013   #11
Need to get it torn apart first to see if the rods and crank are even any good.
Old 01-14-2013   #12
M1L3S
M1L3S's Avatar
Drives: 99Gst
what do i look for? warps, visable scratches, discoloration ?
Old 01-14-2013   #13
Scratches on the crank and discoloration on the rods. If they got hot they are likely warped, at the minimum they will be weaker.
Old 01-14-2013   #14
M1L3S
M1L3S's Avatar
Drives: 99Gst
it spun on the dyno and was not run long after that. im hoping the damage is minimal
Old 02-26-2013   #15
golden763
Drives: 95talon tsi
start doing anything with this lately
Old 02-26-2013   #16
M1L3S
M1L3S's Avatar
Drives: 99Gst
Unfortunately not as much as I wanted to. I dont have a garage right now. So its been tough. I dont want to start pulling things apart and have no place to set things and store them safely
Old 02-27-2013   #17
golden763
Drives: 95talon tsi
o that makes sence i was gonna say i live in anoka to so i could come help i get bored of sitting around all day ha
