Old 01-18-2013   #61
Re: Rebuilding motor, need suggestions
Originally Posted by EVOJ View Post
Ohhh my Christ isn't that what I said pretty Fucking much to begin with. Your a piece of work you know that. Pretty god damn funny you never agree with anyone unless a mod or proven member says the say damn thing
I asked that you stop with the lies, but I know its tough.
I usually bump heads with everyone, because I'm one of the few that will post my opinion on here and not just talk shit behind everyone's back.
I also agree with steve on this about the head design and I know that I'll take a 2g head over a 1g and I'm 100% sure that mitsu somehow improved their head design/cast from 1995 to 2003 and later.
Old 01-18-2013   #62
Old 01-18-2013   #63
The secret to a 2.4 Evo is the headgasket you use.
Old 01-18-2013   #64
Interesting fact: I get administrator emails as a post was reported .
Back on topic to the OP:
You really need to be realistic with the intentions of the vehicle and your goals, realistic goals. Many builds have been delayed to a poorly designed "map to success" to where money dries up or vehicles are without supporting mods. Nothing worse than a built motor that needs frequent refreshing and is slower than a stock motor car + turbo upgrade.
Old 01-18-2013   #65
All drama now belongs here: http://www.mitsustyle.com/forums/showthread.php?t=32543
Bans come to those who continue it in this thread.
Old 01-23-2013   #66
tmosser
Drives: 06 Evo IX
Well a update
Pretty dead set on a 2.3 looking at map stage 1 2.3 with stage one head assembly etc BUT Im looking at a tad over 6,000 for that plus i wanna refresh my t case and rebuild my twin (needs to be done) plus need misc items rotors coils turbo etc.
Anyone got any other suggestions to save some $ 6k is a lot!
14 PB GSR
tmosser is offline   Reply With Quote
Old 01-23-2013   #67
Do a leakdown test. Could just be the head. These cars seem to get gunky valves every 50k or so for some reason.
Old 01-23-2013   #68
tmosser
Drives: 06 Evo IX
Yeah but since it has 115k wouldnt ot just be best to rebuild the whole thing?
14 PB GSR
Old 01-23-2013   #69
See what the leakdown shows first I say.
Old 01-23-2013   #70
This is chukee's old car? A few of us were discussing in the shoutbox the other day, I think I remember they said it had valve problems before, I would not be surprised if the bottom end was perfectly fine. Get the leakdown and hopefully it tells you the low compression is due to valves.
On another note, I can't believe stage 1 long blocks are going for $6k these days, I thought I was crazy for spending $3k on a really nice 2.3 like 5 years ago, ported head, radius valve job, line honed, the works.
Old 01-24-2013   #71
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
yeah you can spend 8k on motor and head pretty quick.
2006 WW IX RS 396/404 - SOLD
Old 01-24-2013   #72
Is that for installation labor and all of that? Or just for parts? Christ, if I was gonna spend that much I'd send it to Buschur or AMS or English Racing, etc
Old 01-24-2013   #73
Where does 6k come from anyways? Looking at MAP's site quick, I came up with ~$3900 with a stage I 2.3, stage I head w/ new valve guides and seals, H11's, and an OEM head gasket.
The extra ~$2k has got to be labor. Why not pull it and re-install it yourself?
Old 01-24-2013   #74
4seasons69
4seasons69's Avatar
I would definitely say have map do the block but go else where for the head. I paid $1500 for my head parts and labor with porting and polishing (I reused my cams and valve springs). It would have been at least $2500 from map. Don't get me wrong they do great work but can be pricey
Old 01-24-2013   #75
tmosser
Drives: 06 Evo IX
Nope the extra 2k comes from assembly of block, i am taking it out and putting it back in. Comes from assembly oem master basket set timing belt kit head studs etc. Bunch of little shit that you might as well replace.
Yes this is chuckees old car i know i read on evom that he had problems thats what made me do the compression test.
After sleeping on it, i think i will save a buck if it is just valves i will just do a new head valve springs retainers seals head gasket and studs.
14 PB GSR
Old 01-24-2013   #76
Wow, page 4 and all this drama......and you don't have a leakdown test results yet? Sorry man but you are literally spinning yourself in circles (I've done it too) until you do a leakdown and know for sure.
This was years ago so I hope nobody gets upset of I spill the beans here but let me tell you about what happened to the engine in that car years and years ago. (note, this is from memory, so do NOT take it as fact please!) It was low on compression in one cylinder. A leakdown test was performed and a few cylinders were a little low and one was really low, but it was purely leaking down from the valves. So, the head came off, it got disassembled, machined, and reassembled. Leakdown tests were the same! The same! So off came the head again and in a moment of what I can only imagine is a mix of frustration and dedicated troubleshooting, the oil pan comes off.
Oil pan off, one of the cylinders is removed for inspection. Maybe all of them? I don't know. Everything looks peachy keen super nice, no issues. I do not recall if fresh bearings & rings were used but the bottom end was then re-assembled. The head as it was was then re-installed, but as it was being torqued down they did leakdown test to try to find the problem. Leakdown was *perfect* until the final torque sequence....somewhere somehow the head had basically been warped. Even though it had been cleaned prior to this (again to what extent, idk) it still leaked on final assembly. SO they yanked the head again, had the machine shop go through it with a fine toothed lathe (lol) and re-assembled with fresh gaskets and everything--voila, a healhy 'stock' motor.
So, do a leakdown test, it really will tell you everything, as long as you are careful and do it right.
As far as the $6k goes, if you plan on doing the bottom end and even touch the head you will break $5k pretty quick. Don't skimp on anything, do it right and do it once. If your crank is in good shape, there's nothing wrong with a good 2.0! That being said, you can sell your good crank to help offset the cost of a different one.
Old 01-24-2013   #77
On your DSM right? I think this guy has to pay Evo tax.
Old 01-24-2013   #78
$3k get will get you a nice stage 2 shortblock in your choice of displacement (2.0-2.4). All this guy really needs is a stage 1 so he can do either a 2.0 or 2.3 for under $2,500. Like Scheides mentioned above though, this car has always had recurring head issues so I'm sure that's where it lies; which he can do anywhere from $500 to $2k.
Old 01-24-2013   #79
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
good luck buddy, hope its an easier fix than tearing the whole damn motor down. lmk if you need any help. I'm home quite a bit during these winter months
Old 01-24-2013   #80
Yeah, I probably spent $6k myself for that Evo 2.4 build I did, Evo's are quite a bit more expensive for everything compared to a DSM engine build. I had MAP do all the machine work and I bought a lot of the parts from them, but I did all the engine assembly. Glad to be back to my cheap DSM.
