Old 03-10-2013   #381
4seasons69
4seasons69's Avatar
Re: GsXtUrBo98's 2G project thread
Alrighty. Sounds good. I'm Monday and Wednesday I'll be free later in the evening, Thursday I think I'm working on the talon, and them Friday I'll probably be free and Saturday after work. I'll text you tonight or tomorrow and we can figure something out.
Old 03-10-2013   #382
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Sounds good man
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 03-11-2013   #383
The factory fuse for the fuel pump usually needs to be upgraded also when you use a BAP.
Old 03-11-2013   #384
GsXtUrBo98
GsXtUrBo98's Avatar
Is this fuse under the dash?
98 GSX (built)
03 BBY EVO dd
Old 03-12-2013   #385
GsXtUrBo98
GsXtUrBo98's Avatar
I replaced both in line fuses and as I thought, they were both good and still no power to the pump.. I would think that the in line fuses would blow before anything else would?
98 GSX (built)
03 BBY EVO dd
Old 03-12-2013   #386
GsXtUrBo98
GsXtUrBo98's Avatar
P.s the terminals accidentally crossed because some moron wasn't paying attention :/
98 GSX (built)
03 BBY EVO dd
Old 04-02-2013   #387
GsXtUrBo98
GsXtUrBo98's Avatar
Ok so my ecu is shit.... I talked to Thomas Dorris from ECMtuning and he sent me a link on what to look for in my ecu and sure as shit! Toast.......
I am in the market for a new EPROM ecu and have a few leads as of right now.
98 GSX (built)
03 BBY EVO dd
Old 04-02-2013   #388
GsXtUrBo98
GsXtUrBo98's Avatar
I also want to thank Shawn (4seasons) and Nick (CornFed2.4) for helping me with diagnosis and information on this. Thanks a lot guys!
98 GSX (built)
03 BBY EVO dd
Old 04-02-2013   #389
4seasons69
4seasons69's Avatar
Sucks dude! And no problem glad we at least got it figured out!
Old 04-02-2013   #390
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Does suck! Still want to see a few quick red 2gs @ proving grounds.
Old 04-02-2013   #391
GsXtUrBo98
GsXtUrBo98's Avatar
I'm trying... haha
98 GSX (built)
03 BBY EVO dd
Old 04-03-2013   #392
GsXtUrBo98
GsXtUrBo98's Avatar
Ok so I picked up a new eprom ecu from 1999gst tonight. Great guy! He pulled it from his running car today and even opened it up for me to look inside.
When I got home I plugged it in just for shits and gigs, not to see if it would start but to see if the fuel pump would turn on. NOTHING!!! FML.. At least I know that its not just the ecu. Next step I think is going to be replacing the stock relay under the radio. Mine is the little black plastic one.
98 GSX (built)
03 BBY EVO dd
Old 04-04-2013   #393
Shitty
Old 04-05-2013   #394
95talonracer
95talonracer's Avatar
Is your BAP bad? Try hooking/wiring it without the BAP and see what it does. You can fry a BAP easy if wires were hooked up or crossed wrong.
Amsoil Dealer
Old 04-05-2013   #395
GsXtUrBo98
GsXtUrBo98's Avatar
I found a fried main fuse. Swapped in a new one and pump works! Now I need to get my new ecu socketed
98 GSX (built)
03 BBY EVO dd
Old 04-05-2013   #396
1999Gst
Drives: 1999 Eclipse,
Good to here you got it figured out .
Old 04-05-2013   #397
95talonracer
So was your ecu bad for sure then or could your BAP be fried?
Amsoil Dealer
Old 04-06-2013   #398
4seasons69
4seasons69's Avatar
His ecu was fried. When you turn the key on the cel wasn't coming on and The ecu wasn't grounding the stock fuel pump relay. When I supplied a ground for the stock fuel pump relay the pumps would come on.
Old 04-06-2013   #399
GsXtUrBo98
GsXtUrBo98's Avatar
Yea thanks shawn. Plus when I opened up the ecu it was blown.
98 GSX (built)
03 BBY EVO dd
Old 04-06-2013   #400
95talonracer
Ok that is good. I read before that the BAP is easy to fry if you cross wires wrong on them at all.
Amsoil Dealer
