Old 03-26-2013   #61
golden763
Drives: 95talon tsi
Re: joel's build
gotta put the tensioner in a vice and slowly squeeze it in is much easier if you do it slow
Old 03-26-2013   #62
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Hahaha thats the other issue. No table vice.
99gsxjoel is offline   Reply With Quote
Old 03-26-2013   #63
golden763
Drives: 95talon tsi
Re: joel's build
lol that could be an issue. Um can also use a big channel locks?? done that before
Old 03-26-2013   #64
blackawdtsi
Drives: 2G DSM
Re: joel's build
Actually, you HAVE to do it slow. If you go too fast, you'll rupture a seal.
What city are you in, Joel?
I've used a car and jack before... Not the best way but it gets the job done.
Old 03-26-2013   #65
99gsxjoel
Drives: 1999 GSX
Re: joel's build
In Linwood by wyoming.
Old 03-26-2013   #66
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Thanks for the floor jack idea... lol
Old 03-26-2013   #67
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Timing belt is installed. only thing I am worried about is the tension. Should be good I am always over worried.
Old 03-26-2013   #68
Re: joel's build
Did you do the drill bit check to see if the tension is right?
Old 03-26-2013   #69
99gsxjoel
Drives: 1999 GSX
Re: joel's build
I did using allen wrenches.
Old 03-29-2013   #70
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Everything is all assembled and ready to go back into the engine bay. Going to try and get most of it done tomorrow. And have it running and driving sometime this weekend.
Old 03-29-2013   #71
Re: joel's build
Looks good! Hope to see it pick on some more v8 cars this summer
Old 03-29-2013   #72
Re: joel's build
Good job!
Old 03-30-2013   #73
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Big update tonight.
Installed the clutch and trans, and dropped it in the bay
Got all the wiring and vacuum lines hooked up. Starter and axles installed. It is getting close to being ready to start.
To do list.
Transfer case
Down pipe
Oil feed and return lines
Radiator
Intercooler
And fill all the fluids.
Thanks Nick for all the help.
Old 03-30-2013   #75
99gsxjoel
Drives: 1999 GSX
Re: joel's build
The trans that I am going to have you look at is the one I broke last year. The one in the pic is a tre stage 3
I got all caught up in finishing my car I didn't get a chance to pull those calipers for you. I hope to have them pulled mon.
Old 03-30-2013   #76
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
So much for going right to sleep! Did get alot done though.
Old 03-30-2013   #77
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Laying in bed I thing my dog is going to have a heart attack because of the lighting.
Old 03-30-2013   #78
Re: joel's build
Nice work, can't wait to see it done.
Old 03-31-2013   #79
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
Re: joel's build
I need to find me some of that motivation.
punxnotdead185 is offline   Reply With Quote
Old 04-01-2013   #80
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well it is finished. Everything went to plan. started right up, and no leaks. this was the first start up started running rough at the beginning, and cleared up after a few seconds.
The excitement I get after tearing it all the way down to the short block and putting it back together and it working perfect is amazing.
Big thanks for the help Cornfed2.4
https://www.facebook.com/photo.php?v...30897824253440
