Old 04-01-2013   #81
Re: joel's build
Nice work!
Old 04-01-2013   #82
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: joel's build
Nice work!
Compliments from GH? You must be doing something right haha
Btw great job man
2006 WW IX RS 396/404 - SOLD
Old 04-01-2013   #83
Re: joel's build
Kick ass man!
Old 04-01-2013   #84
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well it was short lived... there is a odd sound coming from the engin bay, and when I press in the clutch it goes away. This will be a fun one to try and hunt down.
99gsxjoel is offline   Reply With Quote
Old 04-01-2013   #85
Re: joel's build
Loose flywheel. What kind of noise is it?
Old 04-01-2013   #86
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
Turbotalon!?!?!?! Remember when you and Jim came up cause I thought it was blown up. Fixed the tune and could hear sloppiness in the trans and my throw out bearing was toast! Sounds like that.
I stopped over there for a minute and it sounds awesome running when pressure is applied to the pedal (alot of play in the pedal up top).
Our thoughts were in it got bled and adjusted it would hopefully make the noise stop. We will have to see. Worst case scenerio throw out bearing or flywheel bolts.
He used the arp flywheel bolts that Map sells. (Celica kit). I've heard that sometimes they don't go all the way in so maybe
Another note is he said it worked fine until he got to Acapulco in Blaine 15 mins or so of driving then the noise started. So to me it sound like a bleed and adjustment away from being good to go. Crossing fingers.
Old 04-01-2013   #87
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: joel's build
pressure plate rattling some too?
Old 04-01-2013   #88
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
clunking clanky kind of business.
Sounds like broken rod but in the trans.
Old 04-01-2013   #89
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Thanks for explaining it you said it a lot betting than I could. My thought is that there might be air in the line and it isn't disengaging the clutch all the way. There is a large dead spot at the top of the pedal.
Just watched this video on how to adjust the clutch so we will see.
http://www.youtube.com/watch?v=vYJxQyjIhUw
Old 04-01-2013   #90
blackawdtsi
Drives: 2G DSM
Re: joel's build
Did you gob the shit out of red loctite on the flywheel bolts?
That's what my bet is on.
Old 04-01-2013   #91
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
^^^ shouldn't that noise still be present though even when slightly engaging the clutch? As soon as you get past the dead spot in the pedal the noise goes away.
Old 04-01-2013   #92
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Yes I did. And put them in at 110 ft pounds. My guess is if my flywheel was loose I would feel it in the pedal.
Old 04-01-2013   #93
99gsxjoel
Drives: 1999 GSX
Re: joel's build
To be honest its seems to be just like this, and his ended up being the flywheel. witch is weird because mine worked perfect last year. If you watch the video in this link it sounds kinda like that.
http://www.dsmtalk.com/forums/showthread.php?t=238691
Old 04-01-2013   #94
blackawdtsi
Drives: 2G DSM
Re: joel's build
You shouldn't feel anything in the pedal if its the fw bolts. If they're only a little backed out, the noise should go away when you disengage the clutch. If they're backed out a lot, the noise should be present all the time.
Of there's a dead spot, there might be air in the line, but that shouldn't stop it from disengaging. Only engaging.
Old 04-01-2013   #95
blackawdtsi
Drives: 2G DSM
Re: joel's build
But I can only diagnose so much through a computer. You know what you're doing, Nick. Check the easy stuff first.
Old 04-01-2013   #96
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
After reading up on the arp extended lengths what if they bottomed out on the crankshaft? And actualy didnt stop at the flywheel. It says to use a automatic spacer plate or cut them down some. The disclaimer is right on maps website under description.
Old 04-02-2013   #97
blackawdtsi
Drives: 2G DSM
Re: joel's build
I could see that happening. But that would lead to them backing out. Because the head holds the torque.
Also, were the bolts step tightened like headstuds? And was the crank bottom tapped?
May have just toasted a set of ARPs. I've never had trouble with OEMs, honestly.
Old 04-02-2013   #98
99gsxjoel
Drives: 1999 GSX
Re: joel's build
The crank was not bottom taped. But I did tighten in increments of 20 lbs starting at 50 up to 110lbs.
Old 04-02-2013   #99
Re: joel's build
Did you torque the pressure plate? If its not evenly torqued it won't disengage correctly and will make all airts of fun noises when you try.
Old 04-02-2013   #100
Re: joel's build
Pull off trans go from there.
Flywheel/PP issue, sounds like those fancy ARP things you used.
