Old 04-30-2013   #141
Re: joel's build
Shitty man. FP has these. Maybe you can try one of them?
Old 04-30-2013   #142
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Might have to. Depending if they are going to charge a shit ton to make mine work.
99gsxjoel is offline   Reply With Quote
Old 04-30-2013   #143
4seasons69
4seasons69's Avatar
Re: joel's build
Originally Posted by 99gsxjoel View Post
I am so tired of working on it.
I know how you feel!
Sorry to hear it didn't go to well! Just stick with it you'll get it figured out and working how you want
Old 04-30-2013   #144
Re: joel's build
Who built the turbo? I'd be on the phone with them asap to figure out what the deal is.
Old 04-30-2013   #145
4seasons69
4seasons69's Avatar
Re: joel's build
Turbolab built it.
Old 04-30-2013   #146
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Its wasn't the turbo so I cant really blame them for it yet... the wastage they gave me didn't fit with my j pipe, and because I was in a time crunch I just put the one that was on my evo3. It was blowing the wastage open even with it unplugged. So need to get a stronger WG on and then it should be good. I hope.
Old 04-30-2013   #147
Re: joel's build
Shitty.
Old 05-17-2013   #148
99gsxjoel
Drives: 1999 GSX
Re: joel's build
BOOM!!!!! Went the transmission.... dam the just fell apart accelerating in 3rd.
Old 05-17-2013   #149
Re: joel's build
What's the plan now anyways?
Old 05-17-2013   #150
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
He's pulling it apart this weekend check to see if its actually built and fixing.
The way he made it sound built trans just don't break like that, at least at his power level.
Old 05-17-2013   #151
Re: joel's build
^X2
Old 05-18-2013   #152
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Reduild and fix it. Going to start pulling it apart tomorrow.
Old 05-18-2013   #153
LingLing
AznKraut
LingLing's Avatar
Re: joel's build
Dude! Sorry to hear about your trans. I also find it suspect that 4th went like it did. IIRC someone else had an issue with their TRE on here. Maybe they can chime in on their customer service side of things?
Old 05-18-2013   #154
Re: joel's build
Jon is great to work with on resolving issues imo. Since you bought it used, you can't really expect him to warranty anything, but he should be able to identify if its one of his transmissions or not.
Old 05-18-2013   #155
99gsxjoel
Drives: 1999 GSX
Re: joel's build
I think it is going to go to shep.
Old 05-18-2013   #156
Re: joel's build
I choose Shep or Jack's if I had to, probably Jack's.
Old 05-18-2013   #157
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
If this is a poll. I vote jack's.
Blackrosenova could probably get ya back up and have a solid trans to.
Buy jets and swap cases.
Old 05-18-2013   #158
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: joel's build
sorry to hear bad new man :/
2006 WW IX RS 396/404 - SOLD
Old 05-18-2013   #159
blackrosenova400
blackrosenova400's Avatar
Re: joel's build
Thanks for recommending me!
These transmissions are heartbreakers. Its sucks too because 3/4 tend to strip out at high loads and tend to take out other gears with them. You can shim the shafts tigher so the gears have a harder time seperating from each other under heavy load, but it will only help so much, plus more heat is generated with bearing tolerances set tighter.
Jon at Tre Transmissions is a good guy. You can tell he is knowledgable and passionate about his work, and is pretty sold on the idea of shotpeening gearsets.
20g Mafia
Old 05-29-2013   #160
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Trans is out and will be shipped out to shep next week. Its going to be tight on making it to proving groumds. Dont think ill make it.
