Old 05-04-2013   #381
Re: my new project
True. Make sure you learn something when you dyno, that way if something happens on the street you can adjust your tune and save your car.
Or just get the wideband working and wired correctly and have the AEM do it on it's own.
If fuel pressure drops bad though, then no amount of adding fuel to the maps will make a difference. You could wire a fuel pressure sensor into the AEM also and have it adjust the fuel for small fuel pressure drops. Some factory ECUs actually do this. Some cars with factory fuel tanks and poor venting can go lean in the higher gears on a long run due to the fuel pressure dropping because vacuum builds up in the fuel tank and then the often already close to maxed fuel pump has to work a lot harder.
Old 05-04-2013   #382
4seasons69
4seasons69's Avatar
Re: my new project
I would love to learn something while I'm there! but I hate when people sit and look over my shoulder when I'm working on their cars at work lol. So I usually just stay out of shanes way and let him do his thing unless he needs me to do something.
Good luck, hope you can get you goal!
Watch out for the liter bikes there can be a 10-20mph trap difference!
Thanks! I'm not too concerned with whether I win or lose. If I can hang with them I'll be happy. If I lose I lose
As for the wideband being wired in to the aem it supposedly already is. But I'm still waiting to get my new laptop. I'm not sure I trust the old fjo in the car anyway. I want to verify it's readings match up with what your dyno reads. If it does I will make sure to get it properly wired into the aem. If it doesn't then it will be replace and I will get the new one wired in properly.
I have been looking into fuel pressure gauges with a 5v reference and it seems that aem is the only one that makes one. so that is one of those is on my top priority of things to buy for the car.
Old 05-04-2013   #383
Re: my new project
Well there you go, already has a small failsafe.
Old 05-04-2013   #384
Re: my new project
What about one of the AEM failsafe wideband/boost gauges?
Old 05-04-2013   #385
4seasons69
4seasons69's Avatar
Re: my new project
Indeed!
This would be a good Idea but I would want to use it to replace my current boost gauge and it looks as though the aem failsafe only reads to 30psi.
Old 05-04-2013   #386
4seasons69
4seasons69's Avatar
Re: my new project
So I replaced the broken mounting bolt for my alternator today. When the bolt broke the spacer for the alternator relocation kit was lost so I made my own out of washers until I can order a new one from Jay racing. So the car is ready to go for Tuesday!
Old 05-04-2013   #387
Re: my new project
You could just use the failsafe as a wideband and keep your current boost gauge.
Old 05-04-2013   #388
4seasons69
4seasons69's Avatar
Re: my new project
I could but Idk if I could justify spending that much on a wideband that uses the bosch sensor unless I could use the boost gauge too
Old 05-04-2013   #389
Re: my new project
The failsafe features alone would make it worth it, unless your ems can already do that of course.
Old 05-05-2013   #390
4seasons69
4seasons69's Avatar
Re: my new project
I'm on not too familiar with aem so idk what kind of built in failsafes it has. I know Shane said it can adjust fueling based on afr and fuel psi inputs.
Old 05-06-2013   #391
4seasons69
4seasons69's Avatar
Re: my new project
Well I had my buddy bring the car up to db earlier today. Then i went up and took it for a spin tonight. Everything seems good to go. So hopefully goes better than last time ha
Old 05-07-2013   #392
Re: my new project
Is it getting tuned today?
Old 05-07-2013   #393
LingLing
AznKraut
LingLing's Avatar
Re: my new project
Yep, today at 6.
Bring the bike up to the shop Brad!
Old 05-07-2013   #394
Re: my new project
And go-pros.
Old 05-07-2013   #395
LingLing
AznKraut
LingLing's Avatar
Re: my new project
And go-pros.
Yes, lots of go-pros.
Old 05-07-2013   #396
4seasons69
4seasons69's Avatar
Re: my new project
Yep as Jason said today at 6. Hopefully it goes well!
Old 05-07-2013   #397
Re: my new project
Depending on how the day goes I'll try and swing up with a go-pro to get some dyno vids but no bike at the moment.
Good luck either way!!
Old 05-07-2013   #398
4seasons69
4seasons69's Avatar
Re: my new project
Okay sounds good! And thanks!
Old 05-07-2013   #399
Re: my new project
Get a vid from inside the car, I don't get why for the love of god people video cars from outside when on a dyno, its boring as shit.
Get a dash shot and hopefully we can see the RPM/speed and boost!
In for 750whp!! (good luck)
Old 05-07-2013   #400
4seasons69
4seasons69's Avatar
Re: my new project
That would be a cool vid! But unfortunately I'm probably going to be a little sally and be as far away from the thing as I can be hahaha. We'll see how it goes though.
Luck is much needed right now lol!
